Old April 14th, 2018, 10:56   #1
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk2's about 48mpg, mk3 ~43mpg thats @(near)80mph(-/+).
Default this question is on shift linkage
so my other mk3, for a bit it was having a time getting into 1st, at times, also at times it would 'miss' reverse. so a few months later i lost 1st and reverse. so im stuck, just coming out of my driveway, cannt reverse back to turn. so i figure out, i find 1st in reverse, 2nd is down from reverse, other shifter problems, i also lost 5th. in shifter/linkage.
take it to my guy, i donno, got a good bill for it, so now i have everything from 1st to 4th, and reverse works. just got fixed or (just) adjusted, so i ll see. but i dont have 5th. how do you adjust linkage here? i figure my guy did (just)an adjustment. id like 5th back. thanks guys.
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old April 14th, 2018, 16:43   #2
Mongler98
You need to adjust it, its not difficult, its a bit of rinse and repeat the steps to get it just right but trust me, you can do it.
No need to let a shop charge you for something you can do with a few hand tools easily.
im going to asume its a O2A trans
here is a great link for the bushing repair.
works for both O2J and O2A
http://forums.tdiclub.com/showthread.php?t=277786
there is a ball on the end of a bolt on the trans shifter tower and trust me, unless your willing to spend $$$ on a part that is 6 months our back order from a VW dealership in Germany, your not going to find it. i tried looking and calling around. the part is extinct unless you get lucky. so dont bother. try and just pack it back up with grease but chances are your internal tower cup is worn down really bad too. this part will not truly efect your shifting gear selection but will make it harder to get into gear, more effor needed to move the shifter to the gear set. Good luck on that part.
Now on to your adjustment,
here is the link. print it out and go do it.
http://www.houseofthud.com/shifting_gti.htm
Also doing a trans fluid change can help a bit but not in the area of getting into the right gear like you have, just makes things a bit smoother, make sure you get the right stuff, you have brass syncros and will be damaged if not the right fluid. I use Red Line (50304) MT-90 75W-90
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old April 15th, 2018, 00:58   #3
iluvmydiesels
TDI(s): AHU
wow, thanks for the info, that one link is a lot of tinkering with adjusting, have to try it as soon as i can. my tranny fluid is a-ok, its better than that redline stuff, and its not close to needing change. 100kmiles is low miles for my fluid.
other vw interests
Old April 16th, 2018, 09:38   #4
Jetta SS
Jetta SS's Avatar
TDI(s): '98 Jetta
Fuel Economy: 48
Similar thing happened to me, no reverse and one gear couldn't find at times. ended up pulling the trim/console from around the stick and finding the plastic bushings were bad. Changed those and everything worked again.
Jetta SS is offline   Reply With Quote
Old April 17th, 2018, 05:46   #5
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Just change the linkage over to the newer 02J style - worlds more precise. Did this with my B4V, and would make it the first mod if I ever got another.
The original 02A linkage is like shifting a carrot in a food processor.
Proudly installing things where they're not supposed to go since 1996!
Windex is online now   Reply With Quote
Old April 17th, 2018, 08:55   #6
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
Hahaha
I'm going to have to borrow that term. Thanks!
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old April 17th, 2018, 18:06   #7
Jetta SS
Jetta SS's Avatar
TDI(s): '98 Jetta
Fuel Economy: 48
Wish I ran across this idea back when I was having trouble. So did you dig one out at a junkyard, or does a vendor have them?
Old April 18th, 2018, 05:00   #8
Windex
Windex's Avatar
You generally need to get the bits from a salvage yard - the shift tower / cables / brackets / golf club are fairly common, and can be found on both gas and diesel MK4's.
The more challenging piece is the shift/sector shaft that goes down into the transmission - not all junkyards are willing to part with that piece separate from the trans.
For that piece it's easiest to find a junk trans and salvage that part.
Old April 18th, 2018, 06:16   #9
iluvmydiesels
TDI(s): AHU
looks like i ll be shifting carrots. haha. good info tho,
hopefully before i get done with work i can try the adj in that link, in monglers post. looks like a pita, then again having the shifter miss gears is really worse.
other vw interests
Old April 18th, 2018, 17:57   #10
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
I custom rebuilt mine rather than swapping to 02j.
Took it out and found all the sloppy points and replaced them with hand ground chunks of scrap iron and added welds and did some tweaking until it worked just right... it took an afternoon but I didn’t have to buy anything or change the shift box/cables.
my old passat shifted better than my current 03 Jetta... but you had to know the secret handshake... lol
2003 Jetta TDI - 11mm IP, “stage 1ish” DIY tune.
1996 Passat TDI - "Red Death" RETIRED but still owned. Had a Malone stg 1 tune, 11mm pump, R520, GT15/17 hybrid and more
1997 Passat TDI wagon - Im not really sure why i bought this... anyone want a running donor car??? body is rough.
ketchupshirt88 is offline   Reply With Quote
Old April 18th, 2018, 22:50   #11
Ol'Rattler
Ol'Rattler's Avatar
And know I'll bet it shifts like a frog in a blender.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old Yesterday, 04:50   #12
Abacus
That helpful B4 guy
Abacus's Avatar
Fuel Economy: And the miles just keep ticking away
The plastic shift assembly on the transmission is normally the cause. I’ve replaced it rehabbed many over the years but they don’t tend to fail again. I’ll bet this is the issue and it’s sasily fixed.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
'96 B4V: 356,000 miles Malone 2+, PP520's, 6 speed, 02J short shifter, E-Codes, G60 brakes, Evo plate, DMF, stainless exhaust, heated leathers, cold weather package
BUG*PWR 2013 Award Winner
Abacus is offline   Reply With Quote
Old Yesterday, 05:05   #13
oilhammer's Avatar
Fuel Economy: fantastic
It is amazing how awful the early cable shifters are compared to the newer ones. My 2000 Golf with 540k miles feels better and more precise than my 1999 Golf with 200k miles, and my '98 Jetta was even worse. If I still had that car I would for sure be upgrading it to the later style. I found out a few years back that most all of the A3's cable shifter bits are obsoleted. I had to weld a broken shifter box back together with some gussets and supports. It was a mess, but the car was a rusty turd and was falling to pieces. The engine was as healthy as a horse, though.
www.cardocautomotive.com
6 speed 01E Shift linkage question mogly VW B5 Passat TDIs 8 October 22nd, 2013 02:13
Early shift linkage to late shift linkage shagin'wagen TDI 101 10 September 7th, 2012 14:26
Shift Linkage Adjustment Question! Green Golf VW MKIV-A4 TDIs (VE and PD) 5 October 3rd, 2010 12:04
1996 Passat, loose shift linkage tightened, now difficult to shift to reverse!!! Help NoReserveBiker VW MKIII-A3/B4 TDIs 1 August 14th, 2008 17:41
Question on VW shift linkage cage VW MKIV-A4 TDIs (VE and PD) 10 February 2nd, 2002 03:47
Page generated in 0.16647 seconds with 12 queries
[Output: 119.14 Kb. compressed to 100.36 Kb. by saving 18.79 Kb. (15.77%)]
