tverhoeven
- Joined
- Nov 21, 2005
Hello all....I thought my problems were solved when I got the new IP but there seems to be a lingering issue.
I was able to set everything up TDC and get the timing setup to around 55 a couple of weeks ago. Keep in mind it was cold out and the VAG told me that the engine was not hot enough though the fuel temp was around 130.
Anyway...about a week later I had a hard time starting the car at work. I drove home, about 80Km at a speed of about 120kph (hope there are no cops here). when I got home I set up the vag and it told me that the timing was at about 17. I adjusted the pump to 55 again...tightened everything to spec and all seemed to be fine until the past Tuesday. Another hard start at work...got the car home and again timing was around 15. This time I made sure to check that everything was still tight at 18ft/lb. No problems.
I set the timing again....it was snowing out and vag said engine not warm enough. Fuel temp was around 125. I checked the timing yesterday when I dropped a coworker off and it was around 46 with fuel at 138. This morning I arrive at work and check the timing and I am at 38 with fuel temp around 148.
Yesterday was a warm day and today it is about 50 and raining here in detroit.
I am at a complete loss at this point. What could be the problem? The IP is rebuilt from VW. I have been using GUNK fuel conditioner for the past 2 fill ups. The timimg belt was changed back in January.
If anyone can help I would greatly appreciate it.
thanks
1999 A3 Jetta
340000km
thanks
1999 A3 Jetta
340000km
