Old May 8th, 2019, 13:52   #1
nezhinskyt1
Default 2.0l cr(cjaa) tdi swap into 2008 audi a4 b7 questions??
I have a 2011 vw golf wagon with a cjaa 2.0l cr tdi and i would like to put it into my 2008 audi a4 b7 quattro 2.0 tfsi.
My question is how do i mate the two wiring harness and get the cjaa ecu to communicate with the Audi, and the stock gauge cluster.
nezhinskyt1 is offline   Reply With Quote
Old May 8th, 2019, 14:09   #2
Owain@malonetuning
VW's main tech website will have all the wiring diagrams you'll need, could log on for a day and download the lot.
https://erwin.vw.com/
You might be best off purchasing a month subscription to use the iwire feature rather than just downloading all the PDFs, but either way will want to pull some spreadsheets from the data for all your pinouts since the way the factory lays it out will have you sifting between pages to trace wires.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old May 8th, 2019, 20:54   #3
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
What you trying to do is almost impossible bacuse you have k-line car vs CAN ECU. ECU in VW communicate with separate CAN Gateway module, You Audi ECU communicate via Cluster.
USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic,
I do any repair on all models,
ECU TUNING/PROGRAMING-MK6 Needle Sweep,MK5 with MK6 Cluster
https://www.advancedcarelectronics.com/
jetta ,97 is offline   Reply With Quote
Old May 9th, 2019, 14:03   #4
nezhinskyt1
So what your saying is that there is no way for me to mate the systems to work together
Old May 9th, 2019, 15:50   #5
QuickTD
I do not believe it is possible either. The natural choice for a B7 would be a PD engine. A bhw will bolt in with minor wiring changes and the use of a European ECU and engine harness. I have done several of them.
If you want to swap the CJAA into an audi, a B8 would be a better choice. You will still need a European ECU, engine wiring harness, injectors and glow plugs, but euro common rail diesel electronics can be made to work with the B8.
QuickTD is offline   Reply With Quote
Old May 9th, 2019, 16:03   #6
Owain@malonetuning
BHW would be a much better option.
Old May 12th, 2019, 23:27   #7
nezhinskyt1
Okay thanks appreciate it, so if I go with a BHW engine what else would I need
Old May 13th, 2019, 07:11   #8
QuickTD
Wiring harness and ECU from BPW or similar engine (make sure ECU is Quattro, part number ending in KM or KN). Flywheel and clutch, dual mass setup is highly recommended. You'll also need a starter to go with the dual mass setup. An accessory bracket from a BPW will be needed as well as the belt tensioner. You'll need a tune to get rid of the DPF function in the ECU and you might want to add some power anyway.
Audi A4 B7 BRD couple upgrade questions DDCS TDI Power Enhancements 2 September 4th, 2017 01:11
help audi a4 b7 avf 1.9tdi swap a4b7tdi TDI Conversions 6 December 18th, 2015 23:08
2.0T TDI motor swap into B7 Audi A4? tbone1989 TDI Conversions 3 April 6th, 2013 21:29
WTB: PD170 complete swap for B7 Audi A4 vanagonturbo Private TDI Items for Sale/Wanted 12 March 1st, 2012 21:22
Audi A4 B7 engine/tuning questions. TheoSweden TDI Power Enhancements 3 August 9th, 2011 11:42
Page generated in 0.13380 seconds with 11 queries
[Output: 86.17 Kb. compressed to 74.61 Kb. by saving 11.56 Kb. (13.41%)]
