Old May 1st, 2019, 14:10   #1
Sidekick swap
TDI(s): 1997 1z
Default TDI 1z in deep water
Hi all. Looking to see if anyone has experience with deep water crossings running a TDI. Trying to decide if I need to go with a manual injection pump set up. I would like to stay with the electronics if its possible. This will be installed in a Suzuki Sidekick with a snorkel. Thank for any help!
Sidekick swap is offline   Reply With Quote
Old May 2nd, 2019, 10:55   #2
A-man930
No experience here but any diesel should be better in wet environments as there is no high voltage necessary for ignition... just seal up the connections to everything to prevent long-term corrosion and you should be golden.
My biggest worry is the turbo.
A-man930 is offline   Reply With Quote
Old May 2nd, 2019, 11:07   #3
PickleRick
PickleRick's Avatar
A hot turbo and turbo manifold might not like the cold water.
Might be worth googling what the 4bt guys do for water crossings
Nobody exists on purpose. Nobody belongs anywhere. Were all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old May 2nd, 2019, 17:59   #4
[486]
TDI(s): 02 golf ALH
turbo don't care
my dad killed a stanadyne DB2 pump submerging it while hot and running, no idea how VP pumps compare in durability, they do have the advantage of the distributor rotor being the plunger itself, rather than separate components which might facilitate running a tighter clearance in the distributor section on the DB2
anyways, the low voltage wires on the engine side will be fine, the go pedal will get wonky, and the ECU isn't particularly well sealed for submersion. Cluster (and therefore immobilizer) is right out the window.
if you run a barebones harness with the ECU and pedal in the roof or whatever, with a normal throttle cable running up to the pedal assembly
Or run a mechanical pump if you're fine with a reliable limit at 100 hp or so
[486] is offline   Reply With Quote
Old May 18th, 2019, 00:36   #5
Sidekick swap
TDI(s): 1997 1z
I always cool down before crossing.
Old May 18th, 2019, 00:45   #6
Sidekick swap
TDI(s): 1997 1z
I think at this point I’m going manual pump. To much crap to deal with. I spoke to Gile with performance diesel injection and he’s going to build me a pump. 1750 seems high but everyone highly recommends him.
G60 water pump pulley on 1Z TDI lucassayers7 TDI Conversions 2 November 29th, 2018 10:42
Just drove through knee-deep water. sisyphus VW MKIV-A4 TDIs (VE and PD) 16 July 24th, 2016 17:28
Can ECU get wet when driving through deep water? dajo VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 14 April 10th, 2014 18:10
Went Through Some Deep Water Cameron TDI 101 13 October 29th, 2006 11:41
deep rain water woes braunfels_tx_tdi VW MKIII-A3/B4 TDIs 10 September 9th, 2003 19:22
Page generated in 0.17305 seconds with 11 queries
[Output: 72.85 Kb. compressed to 63.86 Kb. by saving 8.99 Kb. (12.34%)]
