Old February 13th, 2019, 08:10   #31
CR-Snow
TDI(s): BHW
Right on man, thanks for the info on the alternator. I suppose I could look
Up the flow rates and pressures for VW power steering pumps and compare. Ill be tuning into the bleepin jeep for sure
CR-Snow is offline   Reply With Quote
Old February 27th, 2019, 04:34   #32
JeddaDeezl
I went live on BleepinJeep this week! This is my priority but I promise I will complete this build thread even if slowly
https://youtu.be/P017g3phWXU
JeddaDeezl is offline   Reply With Quote
Old March 4th, 2019, 08:53   #33
JeddaDeezl
Ive been working on fitting up the intercooler. I got a 25x11x3 core with same side I/O which are 2.5 and I am reducing them directly off the IC to 2 and running all 2 tubes. I also had the Map sensor bung welded into the race pipe on the intake. I am going to change how the tube is routed between the intake and IC so that I have more room in front of the engine and dont have to modify the hood support at all.
I moved the radiator toward the engine 1 to make more room for this intercooler. Very minimal trimming to grille and surround.
How I have it for now:
This is more or less what Im changing it to, but with a 45 bend in the vertical tube.
Old March 8th, 2019, 06:07   #34
JeddaDeezl
Because I could not find a (reasonably priced) 97+ manual pedal assembly I had to make a clutch master support bracket. No big deal.
Heres what I ended up with to mount the VW throttle pedal. Basically just an adapter to go to the stock XJ throttle pedal bolts.
Finalizing the coolant system. I kept the stock oil cooler, capped the one 5/8 tube that comes out by the thermostat. This tube is for a mustang 2.3 turbo, but in hindsight I should have just made this out of a piece of steel tube and painted it. I ended up using a black pipe elbow at the back end of it anyway and tapping a 5/16 barb fitting into it to connect in that 5/16 hose fitting that comes off the back of the head. The top radiator hose is a 2001 TDI lower radiator hose cut down a bit, it is 1.25 on both ends.
This should be a good spot for the frost heater
A little more bendy than I wanted but it works out pretty well. Napa #8698 with about 4 cut off the radiator end and maybe 3 off the thermostat end. I used one of those stainless coils inside the thermostat end to help the hose keep its shape. The thermostat end is 1.25 the radiator end is 1.5
Old April 19th, 2019, 18:47   #35
JeddaDeezl
Time for a long overdue update! I made a hard push to the end and have been driving it now for 2 weeks. A stage 1 tune, stock injectors, stock turbo, and it was incredibly capable. Really not lacking in any area whatsoever. Of course knowing it could be better I upgraded the injectors to ones I had MecEvo rebuild with his 764 nozzles. I am working with Malone to get the tune dialed in but I think I also have some mechanical issues to worth through, namely timing and fuel lines. I wont jump ahead to the end with pictures youll have to wait for that so my next post will be picking up where I left off!
Old April 24th, 2019, 15:50   #36
Rob Mayercik
Can't wait to see the updates!
My Jeep Club's local chapter is having their annual "official" event at Rausch Creek in Tremont, PA the end of June - if you're interested, PM me and I'll send you the details if you think you and the truck will be up for some trail action...
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
400K miles as of Dec 2019!
Rob Mayercik is offline   Reply With Quote
Old May 19th, 2019, 12:16   #37
A-man930
This build is quite inspiring! Thanks for sharing!
A-man930 is offline   Reply With Quote
Old June 14th, 2019, 11:46   #38
89vr6
TDI(s): 2000 base
Updates?
89vr6 is offline   Reply With Quote
Old September 23rd, 2019, 17:40   #39
xjjeeper
xjjeeper's Avatar
Yeah! Updates?????
Sent from my LG-H873 using Tapatalk
1999.5 alh soon to be installed in a 1999 jeep xj
xjjeeper is offline   Reply With Quote
Old September 23rd, 2019, 21:40   #40
bigsexyTDI
bigsexyTDI's Avatar
Would love to have one of these TDI swapped
Diesel smoke kicks gas!
'98 NB, Sprint .205s, Upsolute, Eibachs, Bilstein HDs, Mufflerectomy
'04 Jetta, Black on Black, completely stock, desperately needs a tune
bigsexyTDI is offline   Reply With Quote
Old September 24th, 2019, 10:22   #41
89vr6
TDI(s): 2000 base
Im gathering parts now to do mine 🤘🏻
ALH Jeep XJ Swap xjjeeper TDI Conversions 39 October 5th, 2019 17:14
Jeep XJ Cherokee and BEW TDI Olsenkmark TDI Conversions 3 November 16th, 2018 08:30
2.0tdi into xj cherokee 89vr6 TDI Conversions 0 October 2nd, 2017 18:36
1999 Jeep cherokee, ALH swap Muffinman TDI Conversions 208 February 9th, 2015 17:26
building an ALH for a lifted Jeep Cherokee sardo_67 TDI Power Enhancements 17 May 4th, 2013 19:35
Page generated in 0.14888 seconds with 11 queries
[Output: 102.07 Kb. compressed to 86.75 Kb. by saving 15.32 Kb. (15.01%)]
