Old January 7th, 2019, 16:36   #16
xerootg
Originally Posted by Rob Mayercik View Post
As to the AW4, I wonder if the challenge is in the fact that most of the swaps seem to be the 97+ body style, and in most of those, the TCU is integrated into the ECU (I think that happened in 98 or 99, but I'm not 100% sure). Earlier models like my '92 have a standalone TCU box that might be a solution for the swap crowd.
This actually was never the case (I have a 2001 TCU sitting on my workbench). You have to replicate the 0-5v throttle position to keep the TCU happy though. The 97+ AW4 have an extra sensor, but can be driven with a pre-97 tcu with a bit-o-logic that Kastin on naxja came up with. I built a PCB for this a while back but never had good luck with Kastin's circuit. The 00-01 TCUs have a lower WOT shift point that should be right at 5k. I'd stick with that.
xerootg is offline   Reply With Quote
Old January 9th, 2019, 15:35   #17
JeddaDeezl
Great info on the AW4 guys! Goes to prove the info is out there if youíre looking for it...which I obviously was not! To be honest Iíd have to really dislike stick (for me itís the opposite) to put that much effort into retaining a 4 speed automatic. But good to know it can be done for those that must!
I just cleared out a very stubborn glow plug today which Iíve been working on all week. Finally got it all out of there so now I can put this engine in my Jeep confidently. Always easier to do this kind of thing with the engine out of the vehicle!
I also got a different coolant flange for the back of the head which will simplify coolant hose routing a bit. You may notice I cut my hard coolant pipe as well, with it being from an auto it had an extra tee off it for the trans heat exchanger that I will not need.
Crappy pic I know, but I am running the above pictured flange flipped 180. In order to make sure it would still seal and flow properly I traced the opening and centers of the mounting holes on a piece of clear plastic. Held over the new flange it shows the seal is still 100% in contact with the head surface, though the hole is slightly misaligned but Iím OK with it.
JeddaDeezl is offline   Reply With Quote
Old January 13th, 2019, 17:34   #18
JeddaDeezl
Default ALH into 2001 Jeep Cherokee XJ
Frame side mounts are gusseted and complete. Engine is in again.
I thought I was out of the woods on this. Had a stuck broken glow plug. During the extraction the tip of the plug dropped out into the cylinder. Thankfully the smallest magnet pen I could find grabbed the piece out through the injector hole. I Finally got it extracted but the threads were compromised. Looks like a ReCoil Kit is recommended per Frankís write up. Anyone used a Time-Sert kit on a VW head?
Im planning on adapting this port on the oil filter housing for my Jeep oil pressure sender to feed my dash gauge.
The Jeep sender fits but the thread pitch is wrong, Jeep sender is 1/8Ē NPT pipe thread and the VW port is M10x1.0. I found a $45 remote sender unit adapter kit that allows you to mount 2 senders to the one stock port but itís $45. A hard adapter for the port I have the Jeep sender in for the picture is $8, I just need to make sure I have the clearance to the engine mount to make it work.
Old January 13th, 2019, 19:52   #19
A-man930
Lookin good! Keep the updates coming!
-What are you doing for A/C?
-what steel pan did/do you have that's deeper than the stocker?
-what are you doing about the starter clearance issue?
A-man930 is offline   Reply With Quote
Old January 14th, 2019, 11:57   #20
JeddaDeezl
Thanks! Absolutely will keep the updates coming. Also, I am filming this and when I have enough progress under my belt will be editing and rolling out on a popular YouTube channel for Jeeps, so I'll post a link to that when it drops.
To answer your questions: For A/C I am going to have to look into a passenger side mounted AC compressor. I am not worried about that until stage 2 of my build. Stage 1 is get it running/driving and all kinks worked out.
I have a steel pan I picked up from a guy selling it on a Facebook group. It is for the ALH engine. It is not significantly deeper, but it sticks down about an extra 1/2" and though it's the same basic shape as the cast aluminum one, it's not as crisp of a bend as that so it definitely would cut down on track bar clearance. I have some lift components now to boost this XJ up about another 2" so I am going to do that soon here and see what that looks like.
Starter clearance is solved by clocking the engine in the center hole of the adapter which is roughly vertical but still leaning slightly to passenger side (the way it normally leans in the Jetta). I was just showing how tight it is with the engine set to "full passenger side tilt" on the adapter. Randy (EVGuy1) told me that he is no longer going to make these with the same 3 holes like mine has because a lot of people want to drill theirs out for a different clocking position anyway, which makes sense. Realistically you could clock his adapter any way you wanted by drilling your own 6 holes in the transmission side of the adapter.
Old January 14th, 2019, 12:04   #21
JeddaDeezl
Iíve got a Nictane MK4 TDI fuel filter kit coming in and I am thinking at this point of using the stock XJ fuel pump as a lift pump, regulated by this adjustable regulator from Summit.
I will install it pre-filter and have a pressure gauge on the Nictane housing. The Jeep fuel pump is internally regulated so in theory it will switch off automatically when the 4.0 spec line pressure is met and turn back on to pressurize again whenever that drops to the triggering pressure. If the pump burns up quickly I have a spare, if that burns up quickly again I will try either removing it altogether and letting the injection pump do itís own lifting or figure out another solution. Unless someone has a better idea to start with!
Old January 15th, 2019, 07:56   #22
ManicMechanic
For your oil pressure sender Autometer makes an adapter that will let you use an 1/8npt sender. The part number is 2265 and they sell for like 15 bucks. It's what I'm using for my manual gauges.
For your fuel pump I would just remove the fuel pump from the tank all together. Take the sender out and take the fuel pump off it and replace the pump with a section of pipe. The ALH runs fine with no lift pump and putting pressure in the system could cause some problems.
ManicMechanic is offline   Reply With Quote
Old January 15th, 2019, 11:51   #23
JeddaDeezl
I found an adapter on eBay for $8.99 shipped, so I am trying that. It's M10x1.0 male to 1/8" NPT female and comes with a crush washer. I looked up the Autometer PN and it's available on Amazon for $12.32 with free Prime shipping, so if the eBay one doesn't work out I'll definitely order the Autometer.
Thanks for the input on the fuel pump, I'll go with that then and see how we do! I am not making big power with the ALH, theoretically I will be at 135 horse now, I will probably bump up to VNT17, larger nozzles, and step up the tune once I have it all shaken down. At that point maybe it makes sense to run a lift pump of some sort.
Old January 18th, 2019, 20:38   #24
JeddaDeezl
I have mainly been working on the fuel system lately. I got the floor above the fuel tank heavily rust protected using Chassis Saver and then Eastwood Rubberized Rust Encapsulator.
I then modified the fuel pump assembly to be a simple fuel pickup. Tomorrow I will pick up a fitting and drill a hole to install a return. The evap fitting will just be a vent then.
I bought a Nicktane Uber filter setup with a Donaldson P553203 Fuel filter/water separator and I will run the Donaldson water bowl on the bottom.
Old January 21st, 2019, 12:00   #25
JeddaDeezl
Spent most of the day doing fuel system things. The tank is done, supply and return plumbed in it! I made a baffle of sorts for the return, let me know your thoughts. I just didnít want the return to agitate the fuel a lot or create a swirling effect. The box is 3.5x3.5x8Ē and the ends are 2Ē tall. I removed the anti siphon ball from the filler as well and built a bracket for my filter.
Plumbed the return out the fuel pump assembly
And the tank is back in, fully plumbed up to the filter
Old February 9th, 2019, 19:13   #26
JeddaDeezl
Primed the filter and fuel lines. Working on electrical and intake piping now. Hope to start it up by end of February!
Upgraded battery cables from Mean Lemons, theyíre 2 gauge. Yes I tore apart the factory harness to weed out what was unnecessary, and ran some of my TDI engine harness along with it before wrapping it back up. Really I think I just have the glow plug, N75, Map, and alternator added in.
Old February 12th, 2019, 20:19   #27
JeddaDeezl
Spent most of the day working on wiring. I got the relays mounted inside, I didnít like the look of them on the firewall and didnít like the idea of them anywhere else in the engine bay so I put them through the boot that the TCU wires used to go through and mounted them to the bracket that the TCU used to live on. My OBD II port also talks to my VW ECU (Jeep port is just getting tucked up in there somewhere)
Old February 12th, 2019, 21:04   #28
CR-Snow
TDI(s): BHW
Hey man, finally read through your whole thread. Weíve been talking a bunch on the swapped trucks page. Iíve got the red XJ with a BHW going in. I wish I had thought of telling you about these relay boxes I make and sell on the jeep forum. Could have maybe helped a ton with keeping the wiring clean and waterproof. Check these out when you get a chance. They can be configured any way you want essentially. 5 relays, 5 hot circuits, 80amp total capacity. Just check the ad out. Tons of info there.
https://www.cherokeeforum.com/f73/cu...-boxes-226241/
Iíve got a couple questions for ya though. Accessories- are you using all VW stuff? Iím fine with AC compressor being VW but what about power steering and alternator. Iíve got a dual battery setup with a nice alternator and a WJ PS pump that is a bit better than the XJ pump.
Iím concerned the VW pump was never intended for big tires. Do you know the amp output of the VW alternator. Iím assuming plenty of VW guys put big ass subs in their cars, so maybe someone makes a nice high output alternator that fits the VW mounts.
Last question, I noticed on the gussets for the motor mounts you donít run the bead all the way back to the corner. It looks intentional to me. Whatís the idea behind that? Iíve been welding for a couple years but havenít ever seen that specifically that I can recall. Does it make it less prone to cracking? Also, how worried are you about engine vibration with that little rubber mount?
Thanks much. Iím following along closely.
CR-Snow is offline   Reply With Quote
Old February 13th, 2019, 04:20   #29
ManicMechanic
CR-Snow not sure how many amps your looking for but you can get factory VW alternators that are 90 or 120 amps.
Old February 13th, 2019, 05:54   #30
JeddaDeezl
Hey, thanks for the info on the relay boxes, that might actually be exactly what I need for my Grand Wagoneer project. The relays I was talking about here though are part of the custom TDI wiring harness from Fast Forward Automotive and they control the glow plugs only. These are water resistant (proof, maybe?) and definitely could have been mounted in the engine bay, I just didn't like the look of that and IMO they aren't any less accessible under the dash.
Accessories will be all VW. I am not even thinking about AC until "Stage 2" of my build, but it will have to be mounted on the passenger side. I am not aware of a way to run the Jeep accessories other than by using the Cotybuilt Trussmember. Even that I think they say is for TJ 4 cylinder accessories so that may be different than your upgraded 4.0 stuff anyway. The stock alternators from an ALH are Bosch and either 90 amp or 120 amp. Mine being from an automatic is a 90 amp, but either when I have some $ for it or when I need to replace mine I will go with a 120 amp which is from a manual transmission ALH. The manual trans cars had a higher amp alternator because they used coolant glow plugs to bring the car up to operating temperature more quickly. The automatics used a heat exchanger on the transmission for that. As far as the power steering, I'm not worried about it. Biggest tire I will run is a 33, right now I'm on a 245/75-16 (31") and will bump them to 245/75-16 (32") next time around. I think the VW pump is adequate, I plan to run a reservoir off a Chevy Astro which holds about 1 quart of fluid. I'll need to make a custom bracket for that. Keep your eye on BleepinJeep's YouTube, I'll be making videos about that kind of thing there.
As for the gussets, good eye! I made them that way simply so that they don't always hold debris and moisture there creating a corrosion point. Also the bracket is not a crisp hard corner so I would have needed to round the corner of the gusset anyway. I can't imagine they are any stronger/weaker either way, I just thought to make them that way so I don't have to think about them trapping moisture.
I think the small rubber mounts are plenty for this little engine. They are good and soft, and with the through bolt and washers they are captive (won't let the engine go in a rollover). TD Conversions used to supply a polyurethane mount which I don't think to many people complained about, but my experience with poly and gas engines is that they like to rattle things, so I asked Randy about it and he offered me these soft ones that he has been using in his personal XJ for a while now. I'll certainly give feedback on them once driving.
Thanks for following along, should be live on BleepinJeep in the next few days :-)
ALH Jeep XJ Swap xjjeeper TDI Conversions 29 June 9th, 2019 08:37
Jeep XJ Cherokee and BEW TDI Olsenkmark TDI Conversions 3 November 16th, 2018 08:30
2.0tdi into xj cherokee 89vr6 TDI Conversions 0 October 2nd, 2017 18:36
1999 Jeep cherokee, ALH swap Muffinman TDI Conversions 208 February 9th, 2015 17:26
building an ALH for a lifted Jeep Cherokee sardo_67 TDI Power Enhancements 17 May 4th, 2013 19:35
Page generated in 0.16540 seconds with 11 queries
[Output: 132.71 Kb. compressed to 112.44 Kb. by saving 20.27 Kb. (15.27%)]
