Old July 23rd, 2016, 20:28   #1
xjjeeper
xjjeeper's Avatar
Default ALH Jeep XJ Swap
Hey guys. My name is David. Living in Chilliwack BC. I've been into jeeps for about 5 years now. I have always dreamt of a diesel jeep. My dreams have started to come true I have a 1999 jeep xj with the 4.0 and auto (will be 5 speed swapped). Back in February I picked up a 1999.5 golf tdi with a "blown transmission" (5 speed) for super cheap. Plastic shift linkage was just broken. 30$ piece later I'm driving it for 20k kms.
I've spoke a bit with Randy (evguy) and Matt Whitbread with the direction of the build.
I've been following many other builds like Reddok's
Today I spent a few hours stripping the harness out..
1999.5 alh soon to be installed in a 1999 jeep xj
xjjeeper is offline   Reply With Quote
Old July 23rd, 2016, 20:32   #2
xjjeeper
xjjeeper's Avatar
Not sure how to upload pictures from my phone....
Old July 23rd, 2016, 21:15   #3
bubbagumpshrimp
bubbagumpshrimp's Avatar
Good luck with your build. I had a '97 XJ 4.0 with a 5 speed. I had a LOT of fun with it. I used to take it off-roading (had a Rubicon Express 3.5" lift). I managed to tear one of the mirrors off on a tree one time. The BANG sure woke me up, lol.
bubbagumpshrimp is offline   Reply With Quote
Old July 23rd, 2016, 21:24   #4
xjjeeper
xjjeeper's Avatar
Thanks! They are great all round camping, daily driving, offroading vehicles. I've got the same lift too!
Old December 27th, 2018, 18:05   #5
xjjeeper
xjjeeper's Avatar
BIG UPDATE!
I kinda forgot I had this going. Anyways.. engine is in with with td conversions adapter and mounts. Center force high inertia flywheel.
Arp head studs
.260 nozzles
Gtb1756vk on passat manifold.
Fast forward harness with Malone stage 5 tune. And cruise.
Still being built. Been posting more to Tdi Swapped Trucks on Facebook
Old December 27th, 2018, 18:20   #6
xjjeeper
xjjeeper's Avatar
I'll be taking more pictures as the build progresses
Sent from my SM-G386W using Tapatalk
Old January 19th, 2019, 12:29   #7
xjjeeper
xjjeeper's Avatar
Like update. Put an advance adapters slip yoke eliminator in the transfer case the other evening. Hope to have the engine in for good soon!
Old March 11th, 2019, 22:29   #8
xjjeeper
xjjeeper's Avatar
Been slowly picking away at the wiring harness and modifying the coolant hard pipe. Picked up a brm coolant flange and flipped it for a coolant pipe to run above the exhaust manifold.
Also found a $89 intercooler that Jeddadeezl used in his xj build. Will fit perfectly behind the xj grille.
Old March 11th, 2019, 22:34   #9
xjjeeper
xjjeeper's Avatar
Next up is intercooler piping.
http://www.siliconeintakes.com has awesome quality parts with good prices. I've ordered stuff from them before. Very quick shipping to Canada too
Old March 11th, 2019, 22:36   #10
xjjeeper
xjjeeper's Avatar
Wired up the cruise control buttons.
Old April 6th, 2019, 09:59   #11
xjjeeper
xjjeeper's Avatar
Due to clearance issues with the track bar, the ac compressor had to be removed and mount ground down. A Subaru belt tensioner with a dodge 2.4 idler pulley works really well.
Old April 6th, 2019, 10:10   #12
xjjeeper
xjjeeper's Avatar
Pretty much plumbed up the intercooler and pipes. Radiator moved back about an inch. $6 harbor freight wire crimpers make good bead rolling pliers
Old April 9th, 2019, 10:57   #13
A-man930
I'm beginning to dread struggling with the track bar... I REALLLLY don't want to fuss with it
A-man930 is offline   Reply With Quote
Old April 11th, 2019, 19:39   #14
xjjeeper
xjjeeper's Avatar
That's not really an issue. Get an adjustable one with a drop bracket
Old April 12th, 2019, 22:01   #15
xjjeeper
xjjeeper's Avatar
Friend of mine welded up my custom manifold the other day. Basically an alh manifold with a 2" 1/8" wall aluminum tube welded to it. Along with a map sensor flange.
Also made a steel coolant pipe for the flange at the back of the head to reach the rad. Welded a 3/8" npt bung in for the Jeep coolant temp sensor.
Jetta Wagon Jeep XJ Spring lift boise outlaw Upgrades (non TDI Engine related) 10 November 7th, 2019 10:59
ALH 1.9 TDI engine, 02J 5 speed manual trans, whole donor car for Jeep, Caddy swap.NH concours TDI Cars for Sale/Wanted 0 September 17th, 2015 09:39
1999 Jeep cherokee, ALH swap Muffinman TDI Conversions 208 February 9th, 2015 17:26
2.0? looking at a jeep swap Jakx1331 TDI Power Enhancements 34 December 14th, 2014 17:12
Jeep swap?? wetskier2000 TDI Conversions 38 September 28th, 2011 12:39
Page generated in 0.17375 seconds with 11 queries
[Output: 127.86 Kb. compressed to 105.91 Kb. by saving 21.95 Kb. (17.17%)]
