Old June 21st, 2010, 17:50   #16
Moltenburn
Moltenburn's Avatar
Fuel Economy: 43 MPG
neat project and doing a real nice job.
Current TDI: 2013 Platinum Grey SE TDI 6M
SOLD: 2010 CW Golf 4dr TDI. 6M, Moon, Cold Weather
Avg MPG
Moltenburn is offline   Reply With Quote
Old June 25th, 2010, 19:27   #17
punkvideo81
Looking good!
punkvideo81 is offline   Reply With Quote
Old June 26th, 2010, 19:23   #18
vw_nut
Well Today i worked on the Brake lines, i got the ECU Mounted and installed the fuel tank, the fuel tank is aluminum and its a 30 gal tankhttp://i168.photobucket.com/albums/u...oject003-1.jpg
vw_nut is offline   Reply With Quote
Old July 4th, 2010, 07:28   #19
dieselherb1
Corrado dash into a Rabbit? Passat heater/evap. cores in a Rabbit?
dieselherb1 is offline   Reply With Quote
Old July 4th, 2010, 15:30   #20
vw_nut
Yes dieselherb I wanted to keep the cluster and make it look factory and not have to cut up my dash to get it in ill have pictures hopefully this next week with it in. I'm also going hydraulic clutch which I almost have that all done also I think this next week it will be done
Old July 12th, 2010, 07:42   #21
G60ING
G60ING's Avatar
Nice. I might eventually build something similar so please take pics of the dash swap and HVAC install.
G60ING is online now   Reply With Quote
Old July 15th, 2010, 03:26   #22
vw_nut
I will Frank I'm working 7 days a week right now trying to keep up with work, I'm not complaining just no time to work on truck
Old July 15th, 2010, 07:46   #23
G60ING
G60ING's Avatar
I fully understand that. Spring time is my crazy work season where all family and car projects get put on hold.
Old July 18th, 2010, 08:22   #24
vw_nut
Well i have been working 7 days a week for the last 5 weeks with only 1 sunday off, and its been 100 to 106 with the heat index so it make it tought to work in the heat then come home and work in a oven of a shop so i have been rounding up parts, i have most of the A/C lines and have it pretty much all figured out what i have to do for that, and i am having the lower radiator pipe made at my local shop, i have to have some tig work done on the A/C lines and some shortened, i got both new axles in and have to grease them up and put them on, i am getting the back brakes changed to disk and the rear springs and beam powdercoated i havent got it off yet but hopefully this weekend i can, its all a very tight fit no room for much, im glad i am putting the battery under the truck cause it wont fit upfront
Old July 25th, 2010, 04:26   #25
vw_nut
Default A/C lines
Old July 25th, 2010, 04:28   #26
vw_nut
This is one of the lines i have to rework, i talked to a guy who tig welds and hes gonna look at it, monday im gonna go to a Hose and belt place in nashville and see if i can find another fitting thats straight
Old August 1st, 2010, 17:41   #27
8v-of-fury
Guest
I am actually looking in to a 1Z/AHU in to an 81, this thread has been helpful
Old August 2nd, 2010, 02:21   #28
vw_nut
well not much done to the truck this week, i have had sinus problems and my weekend was on the couch, i have made progress on the A/C Lines i hope to have them back this week along with the lower radiator hose, i got the leaf springs blasted and the rear beam, im getting the rear disks ready to put back on and finish the brakes.. will see were suppose to be in the high 90's again this week
Old August 14th, 2010, 04:48   #29
vw_nut
Well with over 100 heat index for the last 2 weeks im over my sinus infection but its been miserable to work in the shop so i have let it sit i waiting for my A/C lines to be finished up so i can pick them up this week and hopefully my axle beam also i think its suppose to cool down a little this week
Old August 15th, 2010, 19:44   #30
dieselherb1
Not sure if I asked but what type of trans-eng mounts are you using(bought, homemade?) And clutch(cable hydra?) Pedal assem. from ? if you are using hydraulic.
Page generated in 0.15956 seconds with 10 queries
[Output: 116.96 Kb. compressed to 96.58 Kb. by saving 20.38 Kb. (17.43%)]
