Old May 11th, 2017, 18:32   #706
ToddA1
Fuel Economy: Dismal
I'm running "classic" plates on my truck and ran the plates on a Rabbit, that I since sold.
DMV only cared about stock appearance. They wanted pics of the exterior, but never asked for pics of the bay.
In NJ, there are limitations on usage...
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old May 12th, 2017, 10:50   #707
Hasenwerk
Hasenwerk's Avatar
-Todd
In British Columbia they ask for photos of everything . . . I really think it would make sense to allow an engine swap to make classic cars more environmentally friendly . What happens 50 years when fossil fuels will be illegal? Answer nothing - you won't be allowed to drive yourself either, so what's the point.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old June 4th, 2017, 16:10   #708
vw_nut
I'm having an issue with my hydraulic clutch, no leaks anywhere, brakes are solid, no leaks there, I took the slave out and its dry, I've bled the clutch, no bubbles but in driving or letting it sit it goes away, if I pump the clutch it will come back, the master for the clutch is new maybe 100 miles on it, no leaks its weird I guess ill replace the clutch master anyone have this happen
My 1Z Rabbit Truck Conversion http://forums.tdiclub.com/showthread.php?t=281944(2013 Tdi Fest Radical Class Winner)
bv43a, pd150 intake, r520's, 11mm pump, BHW pistons, integrated rods, stg 5 Malone tune, port n polish head (whitebread), stg 2 cam, SB stg 2 clutch,
vw_nut is offline   Reply With Quote
Old June 8th, 2017, 12:19   #709
vw_nut
Well I ordered a stainless steel clutch line for my clutch, I think maybe the rubber in the mk4 line may be old and its expanding to where I'm loosing my clutch, I'll start there before I replace my clutch master cyl
Old August 19th, 2017, 13:46   #710
vw_nut
Took her to vag fair
Old April 25th, 2019, 05:38   #711
vw_nut
I havent posted in a long time, getting her ready for Bugapoluza this weekend, then im off to Vag Fair on the 10th of may
Old May 21st, 2019, 04:41   #712
G60ING
G60ING's Avatar
It was great seeing this at Helen Ga
G60ING is offline   Reply With Quote
Page generated in 0.17788 seconds with 12 queries
[Output: 80.21 Kb. compressed to 69.47 Kb. by saving 10.75 Kb. (13.40%)]
