Old November 12th, 2018, 16:53   #91
gmenounos
Originally Posted by blkhatsilhouette View Post
Hey everyone, I'm in the middle of swapping an '00 ALH/5 speed into an '03 1.8t/automatic (both were jetta's).
I'm having trouble with the T14a connector that the pin out is shown on this thread. In the 1.8t jetta, I'm missing pin 3 (green) and pin 10 (black with green stripe).
I also see on the diagram that pin 10 should go to the load reduction relay. I traced this black/green stripe wire to fuse 10 (small fuses) on the 2000 wiring, but it doesn't seem to exist on the 1.8t. The bottom blade of the load reduction relay traces continuity to fuses 20, 21, and 36 on the 1.8t, but those also exist on the TDI, so I need that extra wire...
Pin 88 of the ECU goes to pin 10 of T14a which then goes through a 5A fuse to the fat black wire with red stripe that goes to the load reduction relay. Your 1.8t jetta will not have that 5A fuse so you'll need to add it. You could probably just add an inline fuse - that's what I did to make my glow plugs work on my ALH conversion.
https://www.bitfab.com/tdi
gmenounos is offline   Reply With Quote
MK4 ALH alternator pinout? A4-TDI TDI 101 9 April 27th, 2013 20:43
68 pin 98 jetta TDI pinout Goldguru VW MKIII-A3/B4 TDIs 13 April 25th, 2011 03:23
"THE" ALH pinout? onlyn8v TDI Conversions 3 March 6th, 2011 09:19
98 TDI pinout 98GTDI OBD Scanners 0 November 27th, 2005 08:04
TDI-ECU Pinout RonnyH VW MKIV-A4 TDIs (VE and PD) 0 January 27th, 2001 15:05
Page generated in 0.12091 seconds with 13 queries
[Output: 50.63 Kb. compressed to 47.78 Kb. by saving 2.84 Kb. (5.62%)]
