Old May 18th, 2020, 09:05   #1
caminuvik
Default 02J transmission
On the bottom there is a badged VW plate, with 2 screws, what is hiding behind this? Can't seem to identify this in my Bentley. Having a drip there. Thanks
caminuvik is offline   Reply With Quote
Old May 18th, 2020, 09:10   #2
mr.loops
Thatís your receiver for the selector tower. You can remove it and apply a liquid gasket (RTV) to the mating surface.
Keep in mind, you will loose fluid when you drop the receiver so make sure you have some transmission fluid at hand. (it might be a good time to replace the fluid if you havenít ever done it)
mr.loops is online now   Reply With Quote
Old May 18th, 2020, 10:09   #3
caminuvik
Thanks, Hope to find transmission oil Tuesday, trying to brace myself for the shock of the price. Bought the wagon 4.5 years ago in Calgary, not sure it has ever been changed,
Old May 18th, 2020, 10:21   #4
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Transmission oil... Syncromesh (any brand).
Shove in at least 2.1 liters.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old May 18th, 2020, 13:54   #5
eddieleephd
Fuel Economy: 38mix / 47@70-75
Or VW spec for $30ish
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old May 18th, 2020, 21:12   #6
Rrusse11
https://shop.advanceautoparts.com/p/...rm=synchromesh
Keep it simple, this stuff works.
RC4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,SMIC,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr, TT rr Brks: Catchcan
Rrusse11 is offline   Reply With Quote
Old May 20th, 2020, 14:12   #7
pkhoury
That guy with the goats
pkhoury's Avatar
02J requires GL-4. I ordered mine from FCP Euro. I don't remember how much, as I ordered about $95 worth of it (I have a 02J on the Golf, 02J that will be on a 5 speed swap, and 2 02Q that use the same fluid).
2013 JSW 02Q - Malone Stage 3, CR170, rawtek 3" straight pipe, PolarFIS, Panzer plate, front fogs, Bosal towhitch, Neuspeed 28mm swaybar, Sachs racing clutch, Peloquin LSD, dieselgeek shortshifter, CP3
2004 Golf GLS 02J - Malone Stage 4, VNT17, DC Stage 2 clutch, darkside 2.5" downpipe/intercooler/TIP MFA cluster swap
2003 Jetta GLS 01M - EGR cooler delete, Melett VNT17, Darkside SMIC. Future Ute/02J project
pkhoury is offline   Reply With Quote
Old May 20th, 2020, 16:46   #8
Jetta2005TDI
from my experience stick with oem gearbox oil they had recent updates get that one (silver bottle) Best shifts in winter.
Jetta2005TDI is offline   Reply With Quote
Old May 21st, 2020, 06:54   #9
jokila
jokila's Avatar
Once the trans gets higher mileage you will find out that the OEM stuff is not as good. Notchy shifts in certain gears that let the synchros grind a tad.
I used OEM for about 250K and after that found from others here the syncromesh works really well. I am at 465K and wouldn't dare go back to the OEM lube.
Old May 23rd, 2020, 07:03   #10
caminuvik
Well, lo and behold, needed breaker bar to remove fill plug, stuck finger in and was full, or so close to it would not be an issue. Having whining sound, when in gears, nothing in neutral or when is clutch in. Starting to think it might be the throw out bearing. Bought pennzoil oil $20 a liter, friend got it on a discount for me, $16.50. Will keep it for future use. Thanks for the help.
Old May 24th, 2020, 05:51   #11
Powder Hound
Powder Hound's Avatar
Seems to me that if the throwout bearing is going, then you'd only hear it when your foot is pushing on the pedal. Otherwise, there is no pressure on it, so it wouldn't be making noise. That said, I'm not a transaxle expert either.
Cheers,
PH
Thinking outside the box is difficult for some. They're afraid they'll fall off the edge of the box and be lost to oblivion.
Powder Hound is offline   Reply With Quote
Old May 24th, 2020, 06:25   #12
eddieleephd
The front carrier bearing in the transmission. Mine stopped with the new transmission.
Old May 24th, 2020, 07:19   #13
mjydrafter
mjydrafter's Avatar
Interesting, my son's '03 wagon is leaking at that spot. We have the fluid ready, just need to get under there and do it.
mjydrafter is offline   Reply With Quote
Old May 24th, 2020, 07:46   #14
Blacktree
Blacktree's Avatar
Fuel Economy: 44-45 mpg (mostly city)
Just FYI, Valvoline Synchromesh is GL-4 rated. Here's the spec sheet: https://www.valvoline.com/our-produc...ynchromesh-mtf
Walmart.com has it listed for $8.99. O'Reilly Auto Parts has it for $9.99. You'll need 2 bottles for a complete drain and refill on the 02J gearbox.
Blacktree is offline   Reply With Quote
Old May 24th, 2020, 08:45   #15
eddieleephd
Incorrect terminology, sorry, input shaft bearing.
Or maybe it's main shaft bearing, always question what different manufacturers call parts.
https://forums.tdiclub.com/showthread.php?t=322006
02j transmission ? Gmerrell TDI 101 2 June 10th, 2017 16:46
02j transmission question r.korey VW MKIV-A4 TDIs (VE and PD) 14 April 4th, 2016 04:25
wtb 02j transmission jetta385 Private TDI Items for Sale/Wanted 3 September 3rd, 2012 18:59
02J Transmission Justler Private TDI Items for Sale/Wanted 3 June 13th, 2006 09:09
02J Transmission... RedRotors VW MKIV-A4 TDIs (VE and PD) 4 October 4th, 2005 21:03
Page generated in 0.17349 seconds with 13 queries
[Output: 124.84 Kb. compressed to 104.03 Kb. by saving 20.81 Kb. (16.67%)]
