garciapiano
Help me understand this thing - this is a windage tray which is designed to help catch the oil flung off the crankshaft and pistons. It is also advertised as a baffle to help prevent oil starvation during cornering.
How does this baffle work if it is installed above the oil pickup? All the pictures I have seen give me no indication that it would perform any function of acting as an oil baffle. Does it actually work?
The reason I ask is that I have gotten the oil buzzer on long, sweeping, aggressive right turns on my car and I really would prefer not to ruin my engine simply from driving aggressively. I'd like to autocross sometime for sh*ts and giggles but the dreaded oil buzzer is a bit of a deterrent. And yes, before you ask, I have proper oil pressure and the correct oil level.
The only true baffle solution I have seen is this SportTuned baffled oil pan. Does anyone have firsthand experience with this? It's a bit more than I'd prefer to spend but if it does the job then it does the job. But I'd like to try the OEM solution first.
