Old November 18th, 2019, 22:29   #1
Skimaster
Default P0381 Glow Plug/Heater Indicator Circuit
I just acquired a 2003 TDI Jetta wagon. Noticed the check engine light and glow plug light wouldn't light up ever. pulled the dash apart and found TP shoved in the MIL hole and the glow plug light desoldered on one side. I resoldered the glow plug light and removed the TP. Now both the lights work.
I am getting a "P0381 Glow Plug/Heater Indicator Circuit" code. Everyone seems to get the P0380 code, so I checked the glow plugs and they all have exactly .4 ohms of resistance and look brand new. I checked the harness and contacts look brand new. I pulled the relay and it also looks brand new.
I'm guessing the previous owner chased this issue and couldn't figure it out and just desoldered the one LED and put tissue paper in front of the MIL light.
The code states "indicator". Is it referring to the LED in the dash? I cannot find anybody online with the P0381 code in an MK4. I cannot register the vehicle here in utah till I get this fixed. Any input on a direction to go would be very helpful
Skimaster is offline   Reply With Quote
Old November 18th, 2019, 22:40   #2
Vince Waldon
Vince Waldon's Avatar
Just checking: you cleared all codes after your repair?
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is online now   Reply With Quote
Old November 18th, 2019, 22:49   #3
Skimaster
yes. the code doesn't come back immediately, it seems to take few drive cycles.
The glow plug light is also blinking.
Are you supposed to feel the glow plug relay click when you turn the key on? Because I disconnected the temp sensor to make it turn on and I cannot feel it click.
Old November 18th, 2019, 22:56   #4
STDOUBT
STDOUBT's Avatar
First, P0381 is not a VCDS code so you're using a generic scanner.
If any of these guys are still around, they can scan it properly and get you a better
idea of what's wrong:
Autobahn Service Center
1358 West 400 South
Orem, UT 84058‎
(801) 374-0012
Alpine Foreign Repair
341 East 900 South
Salt Lake City, Utah 84111
(801) 355-6459
Dan @ The Car Doctors
(801) 766-4449
2158 Redwood Rd
Saratoga Springs, UT 84045
In the mean time, you really should inspect carefully all the ridiculously delicate wiring VW put
in your car connecting the GPs to the rest of the system. Most likely you're looking at a short to
ground or power.
OTOH............have you tried just clearing the code? (nm)
2003 Jetta TDI 1.9L 5-speed
Malone Dynamic EGR ~ cooler delete ~ Euro pipe ~ ventectomy
Search Tip: search this site best by using Bing: tdiclub topic
STDOUBT is offline   Reply With Quote
Old November 18th, 2019, 23:38   #5
Skimaster
I didn't realize the generic code reader would yield such different results. I connected my knockoff vcsd cable and read the codes after clearing them. These both both come back on immediately after clearing them.
2 Faults Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
19561 - Shareware Version. To Decode all DTCs
P3105 - 35-10 - Please Register/Activate - Intermittent
I'm guessing the 16955 is why my cruise control isn't working. Probably the brake switch?
The 19561 probably explains why there's a funny noise when I shut off the vehicle?
Why would the Glow plug light keep blinking indefinitely?
Other than that, all my emissions readiness monitors are complete and no EOBD related dts are set, so I am good to pass utah emissions tomorrow I think!
Old November 19th, 2019, 00:04   #6
STDOUBT
STDOUBT's Avatar
Yep, 16955 is one of many reasons for a flashing GP light
among many others:
http://forums.tdiclub.com/showthread.php?t=67848
You can search codes on ross-tech and read the "possible solutions" sections
https://www.ross-tech.com/Search-Results.html?q=16955
It might simply be your brake switch after all there was a recall on them way back.
Old November 19th, 2019, 03:26   #7
Tdijarhead
If the former owner was chasing a flashing glow plug light, thinking it was the glow plugs he was probably barking up the wrong tree.
Here is a list of possible problems that make that little light flash.
Flashing glow plug light
The flashing glow plug is sort of a super "check engine light". It flashes when the ECU detects that certain very important components are out of spec.
Per a post by MoGolf, the codes that cause a flashing glow plug light are below.
00741 Brake pedal monitoring - implausible signal
01044 Control unit incorrectly coded
16705/P0321 Engine speed sensor - implausible signal
16706/P0322 Engine speed sensor - no signal
16955/P0571 Brake light switch (F) - implausible signal
17653/P1245 Needle lift sender (G80) - short to earth
17654/P1246 Needle lift sender (G80) - Implausible signal
17655/P1247 Needle lift sender (G80) - Open circuit/short to positive
17762/P1354 Modulating piston movement sender (G149) - electrical fault in current circuit
17969/P1561 Metering adjuster (N146) - control difference
17978/P1570 Engine control unit blocked
18020/P1612 Control unit incorrectly coded
18026/P1618 Glow plug relay (J52) - short to positive
18027/P1619 Glow plug relay (J52) - open circuit/short to earth
18040/P1632 Accelerator position sender - voltage supply
Here is the Ross-tech wiki for that code.
http://wiki.ross-tech.com/wiki/index...5/P0571/001393
Tdijarhead is offline   Reply With Quote
Old November 19th, 2019, 07:12   #8
Vince Waldon
Yuppers, the brake light switch will be the likely cause of the flashing glow plug light.
Old November 19th, 2019, 10:42   #9
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Or someone jammed the wrong bulb in the back. Given the previous owner's doofus approach to repairing the cause of the light in the first place, that is entirely possible.
oilhammer
www.cardocautomotive.com
Old November 19th, 2019, 12:07   #10
Skimaster
I replaced the brake switch and cleared the codes and it come right back on immediately.
The third brake light was out so I pulled it apart and found some bad solder joints. Resoldered the joints and the light now works. Cleared the codes and it still comes right back on again.
Found out both the 5007 bulbs in the rear for the running lights were out, so I replaced those. Cleared the code and it hasn't come back on yet.
Now onto the 19561 code. Probably check the wiring first since that will supposedly wear out.
The engine takes a while to get up to temp, but won't hold temp when at highway speeds. I'm guessing the thermostat is stuck open.
Once it gets up to temp, the engine has a hiccup/misfire feeling every couple seconds. I know all the injectors were rebuild by DBWllc recently. What direction should i go with this? Will the 19561 code have anything to do with that?
Old November 19th, 2019, 16:14   #11
Tdijarhead
As is typical of a generic code reader that does not speak VW. Even a chinese knockoff has trouble with VW. The real vcds site has this for a 19561.
http://wiki.ross-tech.com/wiki/index...1/P3105/012549
P0381 Glow Plug/Heater Indicator Circuit atl630 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 January 10th, 2015 19:07
P0380 Glow Plug / Heater Circuit A snagster VW MKIII-A3/B4 TDIs 2 December 22nd, 2011 10:40
GLOW PLUG/heater circuit ELECTRICAL FAULT IN circuit rcatbiddle VW MKIII-A3/B4 TDIs 1 December 30th, 2006 10:06
What is a Glow Plug/Heater Circuit? NB TDI VW MKIV-A4 TDIs (VE and PD) 20 September 25th, 2002 00:38
Glow Plug Heater Circuit jermurs VW MKIV-A4 TDIs (VE and PD) 5 April 14th, 2000 19:19
Page generated in 0.16903 seconds with 11 queries
[Output: 105.43 Kb. compressed to 89.47 Kb. by saving 15.97 Kb. (15.14%)]
