VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta (99.5-~2005), Golf(99.5-2006), and New Beetle(98-2006). Both VE and PD engines are covered here. |
November 17th, 2019, 15:26
#1
Replaced brake light switch and fuse 13, still coding with bad switch
Hi guys, I just replaced my brake light switch and changed fuse 13, my brake lights are now working but the glow plug light is still flashing and when I scan with my VAGCOM, it still gives me a bad brake light switch.
Any idea what's wrong?
November 17th, 2019, 23:57
#2
Did you try just clearing the code?
Some codes go away on their own after so many miles, too.
2003 Jetta TDI 1.9L 5-speed
Malone Dynamic EGR ~ cooler delete ~ Euro pipe ~ ventectomy
Search Tip: search this site best by using Bing: tdiclub topic
November 18th, 2019, 13:23
#3
Yes I tried, many times. I keeps coming back.
Today it stopped and came back later on  !
November 18th, 2019, 13:58
#4
What exactly is the code?
Whatever. Just use your darned blinker. And stay off your phone.
November 18th, 2019, 19:27
#5
I don't have the exact fault message from VCDS but it's:
Brake Light Switch (F): Implausible Signal
November 19th, 2019, 03:32
#6
November 19th, 2019, 06:19
#7
Originally Posted by Tdijarhead
Yup!!
November 19th, 2019, 10:52
#8
not-a-mechanic
First thing in the wiki-
Possible Causes
- Wiring and/or Connectors faulty
November 22nd, 2019, 08:43
#9
I just went through this. My solution was fuse 43 was missing. But that seems to be uncommon.
More common fixes are fixing brake light bulbs that went out, and making sure you have the right bulbs in the tail light.
Ensuring proper function of the switch with a multimeter. One red wire gets 12v and the other connects to it when the brake is pressed. The white wires are connected when the brake is released, and disconnected when the pedal is pressed.
Sent from my Pixel XL using Tapatalk
