Old November 16th, 2019, 16:32   #1
Baratis
Fuel Economy: 35-45
Default Engine wiring harness compatibility
So lately I've been running into loads of issues with wires in the engine harness basically just disintegrating. I'm at the point where I just want to get the whole thing replaced. Haven't found any early alh harnesses on the web so I'm just wondering if the later harness is compatible. If not, where does one buy an earlier harness?
Baratis is offline   Reply With Quote
Old November 16th, 2019, 17:44   #2
eddieleephd
Fuel Economy: 38mix / 47@70-75
You need to call VW and ask the part number then search it
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Bosio DLC 1020's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old November 18th, 2019, 08:50   #3
wonneber
The only problem there might be if the harness you buy is as old as your it may be as fragile as yours.
If they wrap it up to ship it that alone could break up the insulation.
If you are up to it if you did get a used harness cheap enough you could peal the sheeting off and change the wires one by one.
You would need several roles of different wire, the tool to remove the wires from the sockets, a soldering pencil, and good solder.
I always swore by Radio Shack solder. (one of the few things they had that I liked)
Do not use acid core solder, use rosin solder.
Acid core is for plumbing.
You would be able to re-do the used one while still driving the car.
Old November 18th, 2019, 11:01   #4
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
The 1999 ALHs are a bit different than the later cars, and there is an early and late version of the '99!
I doubt either are still available new, but you can certainly call a dealer and have them run a locator:
038-971-610-AP or 038-971-627-A (need to verify with VIN, I just assumed your '99.5 is a German Golf with a manual like mine ).
oilhammer
www.cardocautomotive.com
Old November 19th, 2019, 06:05   #5
eddieleephd
Out of curiosity I searched the numbers and the second was available through VW. $200.00 not so bad. Even if it is different it should be similar enough to justify changing any plugs, or adding any wiring necessary to make it work...
FS: 99.5 ALH Engine Wiring Harness & ECU (Engine swap harness) Celco Private TDI Items for Sale/Wanted 1 March 5th, 2019 09:46
How to remove the B4 engine wiring harness connector? Glow plug harness content 914rrr VW MKIII-A3/B4 TDIs 11 March 4th, 2010 15:50
Engine wiring harness JPR VW MKIV-A4 TDIs (VE and PD) 2 September 10th, 2008 16:03
Engine Wiring Harness Question...Swap a Mk3 Harness for a B4? G60ING VW MKIII-A3/B4 TDIs 2 August 10th, 2007 10:18
ECU and wiring harness compatibility in 1Z or AHU Trailnewt VW MKIII-A3/B4 TDIs 2 May 29th, 2007 23:40
Page generated in 0.16774 seconds with 11 queries
[Output: 69.76 Kb. compressed to 61.91 Kb. by saving 7.86 Kb. (11.26%)]
