Old November 15th, 2019, 05:17   #1
jbuddy
TDI(s): 03 Jetta TDI
Default studder at idle
I replaced my fuel pump on my standard 2003 jetta alh with an 11mm pump and now the car idles really rough most of the time. Group 1 IQ shows 0.8
I tried adjusting the IQ with vcds to bring it up but just made it worse so
put it back to stock. I changed fuel filter and preheater valve as well.
Did a diesel purge. I"m puzzled, any ideas what I should try next.
thanks
jbuddy is offline   Reply With Quote
Old November 15th, 2019, 08:00   #2
jokila
jokila's Avatar
Fuel Economy: 52/45/40
It needs to go up. It is too low.
Where did you get the pump? Used or new?
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old November 15th, 2019, 09:00   #3
csstevej
Yeah you need to raise it up to about 4-4.5.
If you cannot do it through VCDS than you may need to do the hammer mod.
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old November 15th, 2019, 12:06   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Never seen one that low, (0.8). Car wants to see Injected quantity: 2.2 - 9.0 mg/H, ECU takes over from there. Most factory set at 2.2, don't know if that's any different for 11mm pump, shouldn't be. This has been discussed ad nauseam, most like a number around 4, but it should operate anywhere within range.
Seems counter intuitive, but hammer mod seems to work best in cases like yours. Loosen, hit it (youtube has video), tighten, then fine tune with VCDS as you like.
Old November 16th, 2019, 09:26   #5
Mongler98
0.8 is crazy low, i cant belive it actually runs. i would suspect your timing might be off a bit and thus it can run this low. the most i have seen is 1.4 to run properly at idle. I ran 1.2 to 1.4 on my AHU but it did shudder now and again randomly at stops but not enough to give 2 s's
Old November 16th, 2019, 09:27   #6
Mongler98
You need to hammer mod your IP. look it up. its easy to do.
Old November 21st, 2019, 19:55   #7
jbuddy
So it was a used 11mm pump. I loved the power but fuel mileage dropped
and of course at idle it was really rough. I put another 10mm pump on
and it idles perfectly however on a hill under load it went into limp mode.
It hadn't gone into limp mode for the month I was driving it with the 11mm
pump. I don't understand that, any ideas? Fuel mileage is more important
to me so now I have to determine why limp mode. Code p0299 came up.
Underboost. Timing is retarded and needs to be advanced which I will do
this weekend. If 11mm pump would have idled properly and mileage not so
bad I think I would have stayed because the power was awesome.
Old November 21st, 2019, 20:38   #8
Prairieview
Why didn't you put an ounce of effort into the 11 pump as the responders encouraged you to do?
Prairieview is offline   Reply With Quote
Old November 22nd, 2019, 19:06   #9
csstevej
SERIOUSLY......have you not read the previous posts ???
The fix would have taken you about 10 mins........ not a couple of hours to swap out pumps and retime the engine.
Small studder rf2009 VW MKIV-A4 TDIs (VE and PD) 2 December 22nd, 2013 06:07
Studder / Stumble at idle NWA-TDI VW MKIV-A4 TDIs (VE and PD) 5 April 19th, 2013 08:40
idle studder... at odd times Jesse_Boyer VW MKIV-A4 TDIs (VE and PD) 15 December 12th, 2009 16:04
Engine shake/ studder at idle after driving billmn VW MKIV-A4 TDIs (VE and PD) 1 April 17th, 2006 20:53
Engine Studder Boone VW MKIV-A4 TDIs (VE and PD) 2 November 6th, 2002 11:59
Page generated in 0.15666 seconds with 11 queries
[Output: 88.74 Kb. compressed to 75.94 Kb. by saving 12.80 Kb. (14.42%)]
