Old November 14th, 2019, 11:31   #1
Nero Morg
Nero Morg's Avatar
Default Oil filter cap seepage
Well I've got an odd one. Seems my oil filter cap may be pushing oil. It was like that when I changed my oil last, so I cleaned it up. This was a few months ago. Was looking over my engine last night, and it's oily again. It's definitely the cap area, as it's seeping just down the front of the filter housing, starting at where the cap meets the housing.
I always pre lube the o rings before installing the filter. Are these caps known for cracking or leaking? I haven't pulled it off yet to inspect it further.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old November 14th, 2019, 12:11   #2
ahldailydriver02
Fuel Economy: 48ish
I would make sure you have your o ring still in place. Also I had one of the caps go bad on me before. I couldn't see any crack in it but it did the exact same thing that you are experiencing right now. I replaced my cap 150,000 miles ago and no problems since then.
ahldailydriver02 is offline   Reply With Quote
Old November 14th, 2019, 12:33   #3
Replace the filler cap gasket. If that doesn't work, replace the cap. But it's usually the gasket.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old November 14th, 2019, 12:42   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
That big o-ring can get deformed or out of position, especially if over tight. Just take it off and have a look.
Old November 14th, 2019, 16:53   #5
jettawreck
jettawreck's Avatar
I've only replaced that big cap o-ring a few times on each of the TDIs over their lifetimes (so far). Never had a leaker yet and had trouble on the occasion I replaced it with a new one. Seems like every VW I've come to own or work on has the cap way overtightened.
2004 Cadillac SLS (wife's)
Old November 14th, 2019, 18:23   #6
[486]
TDI(s): 02 golf ALH
you get the hengst filter with the white o-ring?
they aren't actually oil-compatible
leave one in solvent overnight, it'll be 6x the size it was and mushy
[486] is offline   Reply With Quote
Old November 14th, 2019, 19:24   #7
Nero Morg
Nero Morg's Avatar
No I've always used either Napa Gold or Mann filters, they both come with the black o ring. I'll pull the cap soon and see what's going on, it's due for an oil change anyways.
Old November 15th, 2019, 07:16   #8
Genesis
Fuel Economy: 53/48/42
The Mann filters (which I use) all have come with both the cap O-ring and the little one for the "stick"; I replace both with the filter.
If a new O-ring doesn't fix it then the cap has almost-certainly cracked where you can't see it. While it's POSSIBLE the housing is scored (which would prevent a seal) I very much doubt that happened.
Genesis is offline   Reply With Quote
Old November 15th, 2019, 12:52   #9
Nero Morg
Nero Morg's Avatar
Well popped the hood and took a closer look, very slight bubbling here. Oh boy. I think I'll just order a cap to play it safe, because I always replace both o rings each time I do the oil.
Old November 15th, 2019, 14:45   #10
Ground Beef
Fuel Economy: 45
I had this problem once. The guy who changed my oil didn't take the old O-ring off, so I had two. I drove it for months before it suddenly started leaking profusely. Took off the extra one and everything was good.
Ground Beef is offline   Reply With Quote
Old November 15th, 2019, 20:01   #11
Genesis
Note that you should never use ANY tools on that cap when removing the old O-rings. It's plastic -- score the groove where that O-ring rides and seals and it's done.
I just squeeze it with my fingers to get enough gap to grab, and off it comes. Ditto with the bottom one for the same reason.
no place to snap oil filter onto oil cap 06 jetta brm tdi narftroz VW MKV-A5 Golf/Jettas 1 February 24th, 2017 14:57
Oil Filter Cap / filter problem? Wont screw, feels like filter too tall? BBB129 VW MKIV-A4 TDIs (VE and PD) 5 January 12th, 2016 17:55
oil leakage/seepage from oil filler cap reynolcj TDI 101 4 August 31st, 2010 13:12
Oil Filter Cap Leaking? High Oil Pressure? Jeepmb VW MKIV-A4 TDIs (VE and PD) 16 January 20th, 2010 05:42
oil seepage around fill cap? oj1111 VW MKIV-A4 TDIs (VE and PD) 3 April 16th, 2006 15:51
Page generated in 0.14380 seconds with 11 queries
[Output: 103.49 Kb. compressed to 87.77 Kb. by saving 15.72 Kb. (15.19%)]
