Old November 14th, 2019, 10:20   #1
PakProtector
Default No fuel 2000 ALH
Yesterday afternoon, my Son's Jetta quit on him. Got to him, and found a big bubble in the fuel line. Removed and replaced the fuel filter. Both lines were empty. Plugged in the Mighty-Vac on the return line from the IP and commenced pumping. It took forever to fill the filter and a vacuum of 15+ inches to do it.
At this point I became suspicious of something further back in the lines.
Dragged it home with Lurch, and poured in most of a bottle of PS 911. Came back 2 hrs later and still found it nearly impossible to draw fuel from the tank. am tempted to try blowing backwards through the supply TO the fuel filter...but since it is now above freezing I don't know what I'd do if it flows easily( with the tank open ).
Any suggestions? I'd really like to figure out just what happened so it can be dealt with and not have to worry about him later.
Thanks!
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is offline   Reply With Quote
Old November 14th, 2019, 10:29   #2
eszut
Fuel Economy: 42/40/38
I see your location is MI could have water now frozen in fuel line. Check the top of the fuel sending units. (under back seat there is an access panel) There is a mod to drill out the roll over check valve.
I also once had some bad fuel with water literally had an inch of water/Ice in the bottom of my tank and ice clunking around in my fuel filter
Ed
eszut is offline   Reply With Quote
Old November 14th, 2019, 10:29   #3
KLXD
There's a check valve in the fuel pick-up in the tank that has been known to cause problems. Some guys drill it out.
You want to make sure the rest of the system is air tight if you do since it makes it easier to loose prime.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old November 14th, 2019, 14:23   #4
Jetpilot2112
Jetpilot2112's Avatar
I've had the same issue, I think. Twice so far this season, my ALH Golf has quit on me about 200 yards beyond my driveway. The first time it happened, I had it towed to a shop and they had to mightyvac the lines. I think I have an air leak somewhere but I'm not sure where. The most recent instance was yesterday morning, 10F outside with the cold snap here in Ohio. Same thing, same spot on the road.
My first thought was that the fuel had gelled with the cold snap due to me not having added any winterizer yet. But now I'm thinking no, it's not a coincidence. I must be getting air but not I'm not sure where. I think in both instances, I hadn't driven the car for a while.
Thoughts? Where should I look first? I see some suggestions mentioning the sending unit and a mod. Could anyone point me toward a tutorial?
Sent from my SM-N960U using Tapatalk
2001 Golf TDI 4dr 5spd silver/black stock
2010 Golf TDI DSG white/gray
2006 Jetta TDI gray/gray 5spd (SOLD)
2002 Jetta TDI black/gray 5spd (SOLD)
Jetpilot2112 is offline   Reply With Quote
Old November 14th, 2019, 15:58   #5
PakProtector
I think I shall have a look after that confounded check valve. Hopefully shortly.
Thanks,
Douglas
Old November 14th, 2019, 17:03   #6
Jetpilot2112
I think I'll do the same... Though I'm not sure how the check valve causes issues. I'll have to read up some more.
Old November 15th, 2019, 03:29   #7
caligta
I had a very similar issue and it was something (dead beetle or fly) lodged behind the check valve that was restricting fuel flow.
caligta is offline   Reply With Quote
Old November 15th, 2019, 09:52   #8
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Since you seem familiar with these cars, I'm guessing you've looked at most of the "dumb stuff". It might be worth looking in the tank to see if the fuel pick-up is clear.
Then there is this thread concerning early ALHs, posted 2004-
Cold Weather Design Flaw, Secret Recall from VW? - TDIClub Forums
Old November 15th, 2019, 16:10   #9
PakProtector
The main plastic screen was clear. There was a fair bit of crud in the bottom of the cup. I took it apart, and took a while to figure out where exactly that damn check valve was...and then I took the drill to it, re-assembled and re-installed. Pulled a wee bit o' fuel through the filter, opened the injector nuts and cranked it a bit. Then closed it up and it lit...
I thank y'all for your assistance. Hats off and three cheers...
cheers,
Douglas
What's the difference between a 2000 alh motor and a 2003 alh mcarthur70 VW MKIV-A4 TDIs (VE and PD) 6 October 8th, 2018 14:37
Anyone need a 2000 ALH auto wiring harness? Fuel cooler? turbovan+tdi Private TDI Items for Sale/Wanted 5 February 22nd, 2017 15:33
? Fuel filter/fuel mielage? 2000 Beetle TDI FranticFrank TDI Fuel Economy 12 September 18th, 2012 22:26
(2000 Jetta TDI) Ran out of fuel, now lots of air bubbles in fuel line.. won't start! Bunnah TDI 101 21 March 6th, 2012 08:06
FS Fuel System parts ALH 2000 Golf TDI forgottenzone Private TDI Items for Sale/Wanted 7 December 16th, 2010 23:07
Page generated in 0.14769 seconds with 11 queries
[Output: 91.49 Kb. compressed to 78.30 Kb. by saving 13.19 Kb. (14.42%)]
