Old November 13th, 2019, 15:05   #1
AGreen
Default Rearview mirror upgrade?
My rearview mirror is in bad shape. Rather than simply replacing it, has anyone upgraded to a newer mirror with auto dimming? Perhaps even something from a non-VW with homelink and compass?? Seems like I can tap power from the dome light fairly easily.
AGreen is offline   Reply With Quote
Old November 13th, 2019, 16:02   #2
Nero Morg
Nero Morg's Avatar
I know people have taken MKV mirrors that have auto dimming and compass functions in them and put them in MKIVs, looks pretty nice too. Not all MKVs came with them though.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old November 13th, 2019, 18:17   #3
volmaniac
volmaniac's Avatar
TDI(s): 02 Golf GLS
Fuel Economy: around 50 mpg
Here is MoGolf's OEM+ how to.... but it requires the (GLX/GTI/GLI) windshield with the proper mount.
http://forums.tdiclub.com/showthread...ht=autodimming
2002 gls golf
Originally Posted by foxracer1 View Post
Wars are fought over religion, money, land, and brand of injectors for a TDI
volmaniac is offline   Reply With Quote
Old November 13th, 2019, 18:21   #4
Genesis
Fuel Economy: 53/48/42
I put a homelink one in mine - was a bit of fun to get switched and unswitched power for it, but definitely worth it.
Genesis is offline   Reply With Quote
Old November 14th, 2019, 05:14   #5
RexNICO
TDI(s): None
The easiest to find is an auto-dimming compass from an Audi A6/C5. Though the A4/B7 & A6/C6 with the hidden compass display is pretty neat.
The main challenge with any aftermarket with Homelink, etc is the windshield mount. Though there are twist to slip mount adapters.
I still have lots of different mirrors (whole units and parts) if you’re interested.
This covers adding both auto-dimming and a rain sensor, which admittedly is a much more complex (& expensive) undertaking.
Recently relocated from OH to GA, let the warm weather begin!
MK4 ALH Pop-off engine cover kit
RexNICO is offline   Reply With Quote
Old November 14th, 2019, 08:44   #6
AGreen
Thanks for the replies. MoGolf went more than knee deep on his upgrade - impressive.
Integration into the car (rain sensing) besides power is too much effort/cost for this car. Iím looking for easiest. Dimming and compass for sure. Homelink would be nice, but I donít want to turn this into a project. In our 2015 Passat, homelink is in the sunvisor. I could add that later. Is homelink possibly in the mirror on the Audi?
Trying to use the existing MKIV twist mount on the windshield limits my choices, but thatís ok. I broke a windshield once while trying to pry the mirror mount off for another project, so Iím reluctant to try that again. That glue is tenacious.
Genesis - I was thinking I would tap into the overhead light which I assume is unswitched since you can turn on the light when the car is off. Is that correct?
Old November 14th, 2019, 09:00   #7
Genesis
You need both switched and unswitched power for the mirror technically, although switched is actually enough. The reason is that the Homelink works with the ignition off, but the light, auto-dim (which it has) and compass you do not want on when the ignition is off. It wants both power leads.
If I remember correctly I got an adapter for the mirror mount as I didn't want to screw with trying to take the other one off, and that was successful. There is only ONE manufacturer for Homelink mirrors -- they have a patent, so no matter where you get it they're all made by one company (which is why they all look mostly the same too.)
OE VW has the Homelink buttons and transmitter on the sunvisor. I couldn't find one at the local scrapyards, so I went that direction with the mirror some 10+ years ago, and like it a lot. The auto-dimming rear view mirror is a nice bonus doing it this way.
Old November 14th, 2019, 09:12   #8
RexNICO
TDI(s): None
This is old, so ignore the pricing and availability, but should give you an idea of options.
And as far as I know, there was not an Audi with Homelink.
On a somewhat related note, I just picked up a Nexx garage NXG-200 that gives me phone based control, alerts & geofencing.
That said, I've never used Homelink in 1 of my cars, I just use the sliding function of the visor in my MKIV
Old November 14th, 2019, 09:43   #9
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Does the MkV auto-dimming mirror work any better than the MkVII?
As far as I can tell the auto dimming feature is useless. It never dims when I would want it to. When I drive my wife’s car at night I have to flip the mirror up so I can’t see anything.
MkIV forever!
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old November 14th, 2019, 10:03   #10
Genesis
The one I have is a "generic" and it dims just fine when someone is blasting you with headlights from the rear at night.
Old November 14th, 2019, 10:28   #11
RexNICO
TDI(s): None
As far as I can tell the auto dimming feature is useless. It never dims when I would want it to. When I drive my wifeís car at night I have to flip the mirror up so I canít see anything.
MkIV forever!
I've never used an MKVII (unless a 2014 Tiguan counts), so I couldn't say.
Have you tested the mirror to make sure it works at all? If you use a bright LED flash light, you can make it dim during broad daylight. Cover the front sensor and shine the flashlight directly into the sensor on the glass side.
Old November 15th, 2019, 17:49   #12
Mike_04GolfTDI
Maybe I'll have to give that a try. The mirror has been exactly the same since the day the car was new. It either never worked, or that's just how it is.
My wife is not bothered by it. She claims it works.
I mean, I have seen it kind of go slightly dimmer under certain circumstances, but much later than I would have liked, and not dim enough. Maybe that's just how it is?
I think it sucks, but I drive it like 1% of the time, and it doesn't bother her, so whatever. I have just made a mental note to never buy one if I buy a new car one day. Or at least I need to see it work before I buy.
reassembling a rearview mirror Woodworker VW MKIII-A3/B4 TDIs 5 June 13th, 2014 13:10
Rearview Mirror Adapter for Gentex Mirror jntsfan TDI 101 0 September 26th, 2012 07:48
Rearview mirror kwkerrick TDI 101 3 August 19th, 2009 18:19
WHERE TO GET A REARVIEW MIRROR CONTROL? jettadude38751 VW MKIV-A4 TDIs (VE and PD) 2 July 12th, 2002 11:34
rearview mirror Rosie General VW Discussion 12 January 19th, 2001 02:04
Page generated in 0.14980 seconds with 11 queries
[Output: 110.42 Kb. compressed to 93.18 Kb. by saving 17.24 Kb. (15.61%)]
