Old November 11th, 2019, 14:19   #1
Davegsm82
Fuel Economy: 57MPG (Golf) + 42MPG (T25)
Default PD150 ARL Engine, smoke/shuddering on start.
As per the title, my ARL engine golf seems to be having a bit of a hard time Idling smoothly on start up.
It smokes for a good while on startup too, smells 'dieselly', both the smoke and the shuddering pretty much stops once the engine gets up to about 35-40 degrees C, as read from both the engine CTS and the Instrument cluster on VAGCOM. I have had similar issues caused by the 4 pin coolant temp sensor perviously, but this one is reading fine so I think something else is amiss. The shuddering also goes away if you raise the revs slightly, but the smoke continues until it warms.
I thought perhaps it was the valve guide seals worn, as the engine uses a small amount of oil between changes.
I fitted a replacement Cyl head to this engine about 30,000 miles ago, as it had HGF and eroded the old head. No history on the new head unfortunately.
Any suggestions for anything to try/diagnose?
Davegsm82 is offline   Reply With Quote
Old November 11th, 2019, 15:04   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Be sure the glow plugs are glowing.
BobnOH is online now   Reply With Quote
Old November 11th, 2019, 15:49   #3
Davegsm82
I'll be sure to check that tomorrow, pretty confident they are fine as I replaced them less than a year ago along with half the harness as it shattered when I attempted to remove it.
Old November 12th, 2019, 02:40   #4
Zak3
It can be a faulty injector or faulty injectors loom.
Zak3 is offline   Reply With Quote
Old November 12th, 2019, 04:26   #5
Davegsm82
I'm not getting any error codes related to the injector loom, what are the symptoms you would expect from a failing loom?
I have a spare set of injectors for this car, but they will require new seals etc before fitting.
Old November 12th, 2019, 11:14   #6
Rrusse11
"they will require new seals etc before fitting."
The copper crush washers can be re-annealed, rendering them soft again.
Heat to red, quench immediately in cold water. A propane torch and
a bit of coathanger wire will do it.
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,SMIC,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr, TT rr Brks
Rrusse11 is online now   Reply With Quote
Old November 12th, 2019, 12:21   #7
Davegsm82
Yea, I'm quite happy annealing the copper washers but the PD injectors have a series of O-rings on the body which seal against ports in the bore. They frequently burst through unfortunately so it's not recommended to reuse them.
Old November 19th, 2019, 10:30   #8
Davegsm82
Checked the glow plugs today, all absolutely fine, however I smashed my GP connector loom getting it off them, this will be the second one I've put on this car due to it going brittle with age.
Old November 19th, 2019, 20:20   #9
Rrusse11
Oops, sorry. No experience whatsoever with PDs. I stand corrected.
Cheers!
Old November 20th, 2019, 04:21   #10
Davegsm82
So today a couple of times I noted a slight hesitation on acceleration in 3rd gear when pulling hard. This has happened in the past but simply went away of it's own accord.
Again is this a sign of injector loom failure or something else obvious?
Cheers!
No worries
Old November 25th, 2019, 16:16   #11
Davegsm82
Tracked the poor idle/smoke down to the GP relay in the relay panel, relay number 167. Relay coil was open circuit, reading 500 ohms (snubber resistor only), instead of ~50ohm for a good relay, made the ECU think the relay was still good.
Car has also been slow to catch on startup, noticed battery voltage was down at 11.9v before I even turned the key, battery even though new was bad.
Also tracked an oil leak to somewhere on the rocker cover, has had new seals but still leaking as per the link below.
https://youtu.be/QC5TwUqTQRI
PD150 ARL Engine conversion package r44ms k Private TDI Items for Sale/Wanted 0 August 25th, 2015 06:14
FEELER: ARL PD150 engine with very low miles in MD/DC/VA manics01 Private TDI Items for Sale/Wanted 1 August 12th, 2015 15:19
pd150 engine bits for sale - ARL code devonutopia Private TDI Items for Sale/Wanted 3 March 2nd, 2011 01:56
FS: ARL (pd150) Engine bits devonutopia Private TDI Items for Sale/Wanted 0 March 8th, 2006 08:56
Page generated in 0.16051 seconds with 11 queries
[Output: 103.30 Kb. compressed to 88.02 Kb. by saving 15.28 Kb. (14.79%)]
