Old November 11th, 2019, 12:14   #1
arwolc
Default EDC16 Injection Durations(Passat 2007 1.9TDI 105
Hello. Could someone help me, please?
I want to remap VW Passat 2007 1.9TDI(105) with DPF a little bit. There is stock hardware and want stg1(remap to 60mg/str), but I cannot understand Duration maps - there are 43.85 degrees duration(60mg and 5000rpm) on stock map. Why so big diff with 2005 Passat 1.9TDI(non DPF)? There stock values for that map are 26-27 degrees and remaped are 28-29.
How much can remap max duration? I think 43 degrees are very much. There could be difference in nozzles?
arwolc is offline   Reply With Quote
Old November 11th, 2019, 13:06   #2
Zak3
AFAIK There’s no need to modify duration for a stage 1.
Remember, more fuel needs more air.
Zak3 is offline   Reply With Quote
Old November 11th, 2019, 13:11   #3
arwolc
Boost I set up to 1,3bar. Now I changed limiters to 60mg, but in real life there is no much power gain. I read that, that Duration max aproxx 35*, but why Bosch calibrated to 43* possible? And why other 1.9TDI passat with 105 engine are so big difference in duration?
Old November 11th, 2019, 15:15   #4
QuickTD
Injection nozzle size has a large influence on quantity vs duration. The DPF version is probably using long duration and small nozzles to trade soot for lower cylinder pressure/heat and reduced NOX.
QuickTD is offline   Reply With Quote
Old November 21st, 2019, 07:11   #5
duke21
TDI(s): 2.0 TDI BMN
Fuel Economy: 7.0L/100km
Same difference in maps of 2.0 16v PPD tdi BKP (Passat 140hp nonDPF Siemens) and BMN(170hp DPF Siemens)
BMN durations around 35-40@4500rpm, BKP durations 26-28@4500rpm. So as QuickTD said its due to DPF.
duke21 is offline   Reply With Quote
2007 MK5 1.9tdi cutting out issue Georgeb97 VW MKV-A5 Golf/Jettas 0 February 16th, 2019 13:41
2007 Golf TDI 105 DPF nokivasara Golf TDI Picture Gallery 25 July 23rd, 2017 10:35
58 plate golf 1.9tdi 105 bhp grating noise. burton876 TDI 101 0 February 23rd, 2015 23:42
skoda octavia 1.9tdi pd edc16,problem power Prke Bg TDI Power Enhancements 2 February 23rd, 2015 15:41
Cam Durations & LP Injection DaveFromSiberia TDI Power Enhancements 10 November 25th, 2000 04:31
Page generated in 0.12933 seconds with 11 queries
[Output: 66.66 Kb. compressed to 59.12 Kb. by saving 7.55 Kb. (11.32%)]
