Old November 11th, 2019, 02:21   #1
fergyp
Default Crbb ea288 cam upgrade
Do the cuaa cams in the bitdi passatt have more lift then the crbb engine 150hp
fergyp is offline   Reply With Quote
Old November 11th, 2019, 14:50   #2
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Yes, they do.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old November 12th, 2019, 16:41   #3
adjat84th
adjat84th's Avatar
You'll need a lot more than just the cams to make it work though
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old November 13th, 2019, 01:15   #4
fergyp
What else is needed?
Old November 13th, 2019, 05:53   #5
adjat84th
adjat84th's Avatar
Cylinder head, pistons, cam cover. Possibly some other things I'm unaware of. I'm planning to do something like this in the spring, have done quite a lot of parts cross referencing to check fitment but without actually having done it there could be some unknown obstacles.
Sent from my Pixel 2 using Tapatalk
Old November 13th, 2019, 06:32   #6
fergyp
Surely you can just swap the cam module only thing I can think of if there's any valve to piston clearence issues
Old November 13th, 2019, 06:33   #7
adjat84th
adjat84th's Avatar
Different valve layout entirely as well as valve reliefs in the pistons to match. I'm assuming your CRBB is comparable enough to the CRUA 150hp sold over here though.
Old November 13th, 2019, 11:01   #8
fergyp
Not sure if the CRUA is the same as crbb, so there's no chance of swapping cams easy as I thought, I think the CUNA has variable cam timing whether there's any look with that
Old November 13th, 2019, 22:30   #9
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Isnt the CUA cyl head a straight upgrade for the CRB-CUNA?
CP3 Upgrade
Macradiators.com is online now   Reply With Quote
Old November 14th, 2019, 16:44   #10
adjat84th
adjat84th's Avatar
Cross referencing part numbers is the key here and will tell you most of what you need to know.
Crbb ea288 cam upgrade fergyp TDI Power Enhancements 0 November 11th, 2019 02:09
Crbb ea288 cam upgrade fergyp TDI Power Enhancements 0 November 11th, 2019 02:08
Cam upgrade? Ct-csrt TDI 101 7 March 16th, 2014 15:15
Which MK4 Cam Was A Upgrade Over the MK3 Cam? D_Bat TDI Power Enhancements 11 September 15th, 2008 06:00
Page generated in 0.17089 seconds with 11 queries
[Output: 98.87 Kb. compressed to 84.05 Kb. by saving 14.82 Kb. (14.99%)]
