Old November 9th, 2019, 22:09   #1
CGDoig
CGDoig's Avatar
Fuel Economy: 40 mpg avg, 50 best
Default Help Diagnosing Clutch Issue
Hey guys, been a loooong time. I guess it's not a bad thing considering the car has been so bullet proof the last couple of years.
Today I was driving on the highway, shifted from 4th to 5th like any other time, as I was letting the pedal go I felt a sort of ping through the pedal, I knew right away something was wrong. The pedal got stiff and would no longer disengage the clutch. The spring action of the pedal is still all there, but it definitely feels different, almost more stiff. I was an hour from home a was lucky enough to be able to limp green lights to make it home.
My guess before taking a look in the next week. Clutch Fork, slave or master. The clutch is a SB Stage 3 with single mass conversion, it's not that old but I haven't been nice to it. Any other suggestions and easier things to check into before cracking the case open?
2005 GLS || Malone Stage 5 || VNT 17/22 || PD130 Injectors || Eurojet FMIC
2.5" TT Downpipe / 2.5" Back || Koni FSD's || Eibach Pro-kits || Sb Stage 3
CGDoig is offline   Reply With Quote
Old November 9th, 2019, 23:30   #2
Meister Kraft
TDI(s): 2001 Jetta
Fuel Economy: 40 avg
Inspect the clutch spring on the pedal - most likely not the issue but itís easy
Remove the clutch pedal resivour and press the clutch - if fluid acts like a fountain then ya found a bad master cylinder
Locate the slave unit and watch for the piston movement if none, remove it and check again. Be careful not to blow it out so put a 2x4 piece behind the clutch pedal so the spring doesnít slam it to the floor.
I would think the pressure plate or fork went out just yet but letís start with the simple stuf first.
Meister Kraft is offline   Reply With Quote
Old November 11th, 2019, 06:56   #3
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
You can pull the slave out and attach a restraint across the end and you should have a very stiff pedal - that will rule out the hydraulics. (I have a garage door bracket with the perfect spacing I use to prevent accidental damage while it out that works nicely).
Everything else is internal and should be obvious once removed. I have run across one broken throwout "arm" in the past.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old November 12th, 2019, 08:24   #4
CGDoig
CGDoig's Avatar
Thanks guys. There's currently half a foot of snow on the hood in front of the house. I'll have to let it dry a little and try and push start it to get her in the garage before looking. I'll update with what I find when I get there though.
Old November 15th, 2019, 13:12   #5
CGDoig
CGDoig's Avatar
Update. I pulled the cylinder out and clamped it. My wife did the pedal because the first time I damn near shot it across the garage. She said pedal feel was normal, not stiff. Not sure but I'm thinking I might bleed the system here and see if something comes of that first.
Old November 15th, 2019, 13:38   #6
steve6
If you have the slave out.. check to see if the pressure fork looks ok, it should be 1/4 inch or less away(approx.) from the housing, it almost sounds like you wore a hole in it where the pivot ball is (maybe) or bent it.
steve6 is offline   Reply With Quote
Old November 15th, 2019, 19:26   #7
CGDoig
CGDoig's Avatar
Well I took the plunge and pulled the transmission. After a couple more trys at bleeding and other things I figured why not. Found a broken spring on the bottom of the fork or "arm", and a couple bent fingers on the pressure plate, although those may have been me being a little rough with the input shaft. Would a broken spring cause those symptoms?
Last edited by CGDoig; November 18th, 2019 at 12:47. Reason: Tried editing photo links
Old November 15th, 2019, 19:32   #8
ToxicDoc
TDI(s): 2001 Jetta
image too small to see well
ToxicDoc is offline   Reply With Quote
Old November 15th, 2019, 19:35   #9
CGDoig
CGDoig's Avatar
Try that. Should just be links to the photos. No idea why I'm having such trouble linking these pictures
Old November 18th, 2019, 10:40   #10
CGDoig
CGDoig's Avatar
The picture of the pressure plate above shows the fingers bent a little and out of place. Pulled the plate off and layed on a straight edge and they are all proper and true. Maybe something is putting pressure on it from behind the wrong way in one spot? I've been in contact with south bend now. Sending them some proper photos tomorrow but still looking for possible things to check. I'm clueless.
Old November 22nd, 2019, 09:22   #11
CGDoig
CGDoig's Avatar
Would the broken pivot retaining spring cause this to happen? I feel like the arm and bearing not having that pivot point would be enough to cause a no release situation. Anyone else agree?
Old November 25th, 2019, 10:51   #12
gforce1108
gforce1108's Avatar
Somehow this one still shifted decently... DMF was shot too.
Old November 25th, 2019, 12:32   #13
jokila
jokila's Avatar
Fuel Economy: 52/45/40
How does the throwout bearing look? Was it binding against the input shaft sleeve?
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Need help diagnosing a heater issue.... ItsADiesel TDI 101 16 December 31st, 2015 17:44
Help diagnosing bogging issue... mwhite1206 VW MKV-A5 Golf/Jettas 5 July 17th, 2015 11:51
Need help with diagnosing Jetta issue onebadaxe VW MKV-A5 Golf/Jettas 18 December 2nd, 2012 21:44
Diagnosing Transmission Issue daedalus VW B5 Passat TDIs 1 February 12th, 2011 09:10
Help diagnosing steering issue Landgolier TDI 101 9 August 10th, 2006 20:12
Page generated in 0.18408 seconds with 11 queries
[Output: 115.78 Kb. compressed to 96.64 Kb. by saving 19.14 Kb. (16.53%)]
