Old November 8th, 2019, 20:25   #1
jptbay
jptbay's Avatar
Default Quick BEW limp like pointers
Went into limp like state right away after starting when I left to drive home this morning after nightshift. Tried a dozen or so restarts on the way home, but would not resolve.
Was acting similarly this spring and I deleted the EGR by going to PD150 intake manifold and retaining the ASV. Seemed to resolve issue and have had no trouble for 6 months.
No codes. Checked vnt operation with VCDS, all good. Changed fuel filter, went for a ride and back to normal, full power. There are no boost leaks. Have doggie collar, vnt17 and upgraded intercooler. Went to bed.
Left for work tonight, car had full power. Was snowing so I was driving easy. Went into limp like state again sometime while I was putting around on a city street. Stopped at a light and was limped out.
Some ideas for things to check?
No codes is annoying. Thinking fuel. New VW lift pump last winter, seems to be working good. Car has about 335ooo km. Still on original tandem pump, but I have a new one on hand. Put in new Bosch MAF this spring too when I did the manifold.
2003 Beetle, 18/56, 3 Bar MAP, 11mm pump, Bosio R520's, Cat fuel filter, PD lift pump, Kerma OMI, Kerma tune, IDParts lower boost pipe, Tyrolsport SMIC, Turbo S fender liner, PD150 intake w/racepipe, IDParts 2.5" stainless downpipe & 2.5" straight exhaust, ARP headstuds, ASV Pistons, I.E. I-Beam rods, BFI stage 1 mounts, Spec stage 3+ clutch/18lb flywheel, R axles, VR6 spindles, GLI big brakes F&R, 17" Enkei RPF1's, Koni FSD's, Evolution skid plate, McNally 30 PSI boost/EGT gauge, OEM HID's ...
jptbay is offline   Reply With Quote
Old November 8th, 2019, 23:19   #2
jptbay
jptbay's Avatar
Thinking about it more, I checked and forgot that BEW and ALH MAF's are different. Been working fine until now, but maybe with colder weather it is out of range.
I'm going to try unplugging it in the morning and see what happens with a default value.
Old November 9th, 2019, 06:40   #3
jptbay
jptbay's Avatar
Well that was a slow ride home...
Unplugged the MAF and no improvement. I ordered a new one so it would be correct. Going to have to dig some more when I have time.
Old November 9th, 2019, 08:46   #4
JB05
Fuel Economy: 43/41/40
Does no boost leaks include the IC connections down under?
JB05 is offline   Reply With Quote
Old November 9th, 2019, 15:15   #5
jptbay
jptbay's Avatar
Yes. Took a good look. I changed the oil when I changed the fuel filter and had the car up in the air with the skid plate off. When I installed the upgraded SMIC I swapped all the lower boost pipes to ALH ones.
Further, if there where boost leaks I would expect a code for deviation from requested.
Been reading a lot of old threads and there seem to be a few things to look at. I am going to more thoroughly check the N75 and turbo, as well as change the tandem pump that I have been meaning to get to for a while because of a leak.
Welcome other avenues look at too. Don't be shy, throw out your ideas please.
Don't think it could be the cat plugged, due to the intermittent nature of this issue.
Old November 11th, 2019, 06:30   #6
jptbay
jptbay's Avatar
So it wasn't the tandem pump. At least it won't be leaking any more.
Will look at it more tonight.
Old November 11th, 2019, 15:41   #7
wonneber
If it looses power while you are driving (limp mode) you have to scan for the code before you shut the car off.
It self resets when the ignition shuts off.
Old November 11th, 2019, 16:41   #8
P2B
P2B's Avatar
No, you don't. Limp mode resets when the ignition is cycled but any stored code remains until cleared with a scan tool.
Simon
Jettas for 35 years, TDIs for 16.
2003 Silver Jetta TDI GLS 300K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 230K PP520 RC2
2000 Canyon Red Jetta TDI GLS 560K
P2B is offline   Reply With Quote
Old November 11th, 2019, 17:32   #9
jptbay
jptbay's Avatar
No time tonight unfortunately to look at it, but appreciate any brainstorming ideas.
Old November 12th, 2019, 08:04   #10
jptbay
jptbay's Avatar
Checked a bunch of things this morning and it looks like my three bar map is the issue.
Click on thumbnails for larger picture.
In measuring blocks in VCDS, both idling and engine off, boost is showing 2196 mbar. When engine off specified is supposed to be 192. Idling specified is just over 1000.
Also group 22 shows charge pressure system malfunction.
Funny how no fault codes were logged.
Ignore the MAF readings. It's not working because as I previously mentioned it's the wrong one, and clearly not working, so a new proper BEW one is on it's way.
Going to order up a new map and see what happens.
Old November 16th, 2019, 15:43   #11
jptbay
jptbay's Avatar
MAP sensor ended up being faulty.
Pretty happy car again. Got some love with the proper MAF finally, no more leaking tandem pump, and got the winter tires on.
Old November 18th, 2019, 08:15   #12
wonneber
Glad you resolved it and posted the fix.
It may help others down the road.
Couple of quick questions on glow plugs BEW OlyTDI VW MKIV-A4 TDIs (VE and PD) 8 October 4th, 2019 18:49
quick question on BEW golf strikeraj VW MKIV-A4 TDIs (VE and PD) 1 December 3rd, 2012 05:52
quick bew cam repair question daniel_mad Ontario 1 April 20th, 2010 17:23
Quick Q: How quickly will overboost set limp mode? Victor Huge TDI 101 9 December 17th, 2009 10:15
HELP!!! -- Does "limp mode" = Relay 109 problem? -- need quick help BIGJOHNO VW MKIV-A4 TDIs (VE and PD) 18 October 20th, 2000 06:59
Page generated in 0.17769 seconds with 11 queries
[Output: 112.50 Kb. compressed to 95.00 Kb. by saving 17.50 Kb. (15.56%)]
