Have power steering leak in steering rack. Do they have steering rack replacement seal kits or does the rack require replacement?Would be nice to fix the issue without dropping the subframe.
Interesting, seems I remember the rack on my old 99.5 was easy, don't recall removing anything but the rack, tie rods, fluid lines. A good rebuild kit may be tough to find, but would be all that's needed. The whole rack is not terribly expensive.
