Old November 7th, 2019, 13:01   #16
turbobrick240
turbobrick240's Avatar
I knew a guy who would warm up his older 5 series bmw with the pedal to the floor. It warmed up fast, but he only got two winters out of it.
Old November 7th, 2019, 15:57   #17
Owain@malonetuning
Isn't that the expected life cycle of an E60?
Owain@malonetuning is offline   Reply With Quote
Old November 7th, 2019, 16:24   #18
eddieleephd
Fuel Economy: 38mix / 47@70-75
Lol
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Bosio DLC 1020's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old November 7th, 2019, 17:51   #19
TDI smile
TDI smile's Avatar
Location: Edmonton, Alberta (b4 BC - LOWER MAINLAND = Chilliwack)
START the engine and drive right away.
TDI smile is offline   Reply With Quote
Old November 7th, 2019, 18:27   #20
Smarten101
Thanks for all the replies. I guess I've been doing things wrong all this time! Time to change how I do things.
Smarten101 is offline   Reply With Quote
Old November 7th, 2019, 18:47   #21
These cars really aren't that much different from gassers. Besides not letting them idle to warm up, you can treat them like any other engine.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old November 7th, 2019, 19:10   #22
scooperhsd
Yes - with the correct oil in them, the oil will be everywhere it needs to be within 15 seconds (even at -40). Idle long enough to get most of the roughness out and all cylinders firing and go....
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old November 7th, 2019, 19:48   #23
Mongler98
2 things
it will not warm up if you dont drive it and the turbo wears MORE at idle than when operating at pressure, has to do with how it sits against the journal bearing.
all you need to know is that you want to change the oil before it starts getting cold. keep up with it, 10K miles between oil changes, 6K if its that cold still but its probably unnecessary.
Start it up and drive it after you get your seatbelt on and adjust the mirrors.
dont bother with babying it at all, just don't drive it hard until warm. Drive normally.
Old November 8th, 2019, 10:43   #24
fouillard13
1. are you saying to put in fresh oil before winter, or different oil before winter? is old oil in the cold harder than fresh oil in the cold?
2. why are you guys needing to adjust your mirrors every time you get in the vehicle?? I adjusted my mirrors once in 2016 when I bought the car and havnt touched em since....
fouillard13 is offline   Reply With Quote
Old November 8th, 2019, 10:53   #25
Giberish33
lol I adjust my mirrors at every red light, gotta keep them optimally aimed /s
Fresh oil will flow faster / better when its new than when its soot loaded so yeah same oil just fresh oil before winter is the best case scenario.
Giberish33 is offline   Reply With Quote
Old November 8th, 2019, 10:54   #26
fouillard13
hmm, interesting. I didnt know that. im about 60-70% due for an oil change and its going to start getting cold soon here. maybe ill dump it a bit early so I got fresh stuff for the winter.
thanks.
Old November 8th, 2019, 16:40   #27
Mongler98
you guys must be the only drivers of said car. wife and i share our daily, mirrors get adjusted ALL THE TIME
Old November 9th, 2019, 03:35   #28
vwexpress
Without starting a new thread, about idling, I idle my car a lot. Is that hurting this little diesel? In hot weather, during lunch, often an hour straight, just sitting there.
I don't adjust the mirrors much.
vwexpress is offline   Reply With Quote
Old November 9th, 2019, 05:55   #29
scooperhsd
Just sitting and idling is not great for the TDI.
Old November 9th, 2019, 06:01   #30
red16vdub
red16vdub's Avatar
TDI(s): 03 JSW 5spd
I donít see any evidence idling hurts Tdiís.
I usually get to work an hour and half early to beat traffic, so that means I idle until itís time to start my shift, weather it running AC or heater . Iíve been doing itís for years and Other than hurting the O-Zone maybe,I donít see the problem.
Mk1 Gti /scIROCco 16v Eaton Supercharger /A4 Avant sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV 5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, Rosten Rods, Arp Studs, Race Valve springs, McNally boost/egt, Euro FIS full Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3" turbo back, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is offline   Reply With Quote
How to properly break in a TDI tikal TDI 101 12 September 2nd, 2002 20:39
TDI not running properly Scott Daniel TDI 101 1 July 27th, 2002 19:51
warm weather warm TDI engine hard starting wpeets TDI 101 23 February 2nd, 2002 21:54
How to properly drive a TDI ? Kevin VW MKIV-A4 TDIs (VE and PD) 10 May 15th, 2001 16:28
HELP, I'm new to TDI's and I don't know how to maintain them properly. Damien VW MKIV-A4 TDIs (VE and PD) 4 August 7th, 2000 09:53
Page generated in 0.16657 seconds with 11 queries
[Output: 126.99 Kb. compressed to 106.26 Kb. by saving 20.74 Kb. (16.33%)]
