Old November 5th, 2019, 07:46   #1
dobeonguard
dobeonguard's Avatar
TDI(s): 98 Jetta TDi
Default Error Service message
Last week I was driving on the highway in my 2015 Golf TDI and I heard a loud beep. I looked down at the dashboard and saw the orange triangle with exclamation mark along with a message. I only got as far as error service.... then it disappeared. Any ideas? I donít have VCDS, would this alert be retained still kn the ECU? Bought her in February with 9,000 miles, I have 17,000 miles now.
dobeonguard is offline   Reply With Quote
Old November 5th, 2019, 09:11   #2
Jbwoo
No idea with out a present error light, and codes.
15 GSW DSG and Kerma tuned 80k miles
06 Jetta DSG BRM no mods just maintenance 275k miles
04 Dodge 2500 Built auto trans, Cummins 50hp injectors, Firepunk HPTuning 160k miles
08 E450 Motorhome V10 powa, suspension mods
Jbwoo is offline   Reply With Quote
Old November 5th, 2019, 09:21   #3
TDI73
TDI73's Avatar
Did you try "Car" button on the radio?
15 Golf TDI 6MT
Past:
06 Jetta TDI 5MT (BRM)
99 Jetta TDI MKIII 5MT(ALH)
97 Golf MKIII 5MT
TDI73 is offline   Reply With Quote
Old November 5th, 2019, 09:35   #4
ProfBrown
Fuel Economy: In the sig
Yeah every time that triangle is on the dash, hit the car button on the radio and the car will default to give you the message of whatís wrong.
2015 GSW TDI SE DSG
DON'T TRACK THIS ANYMORE
ProfBrown is offline   Reply With Quote
Old November 5th, 2019, 10:41   #5
740GLE
prob gear shifter issue, is a very common issue. Code should be stored.
Old November 5th, 2019, 13:22   #6
dobeonguard
The message disappeared within two seconds, so did the warning light. I checked the Car section on the infotainment system and no messages.
Old November 6th, 2019, 08:55   #7
740GLE
VCDS will find it, don't worry.
Old November 14th, 2019, 05:01   #8
dobeonguard
Found the culprit, well two of them. Took it to the dealer and they scanned it. There were two instances of the gear shift sensor thatís been recalled, and the most recent one was the battery in the remote was going bad. This begs the question why the alert isnít displaying for more than a second? 🤔
Old November 14th, 2019, 09:17   #9
740GLE
prob just the gear shifter as being the cause of the error displayed and the dealer just wrapping it into the key fob as well.
did they want you to buy a new key?
Old November 14th, 2019, 13:35   #10
Martin Winterkorn
So is the issue being covered under the recall for free? Took mine in last year for the same issue and they said it was only "select" VINs... Obviously its happening to vehicles outside their specified VIN range.
Martin Winterkorn is offline   Reply With Quote
Old November 15th, 2019, 05:33   #11
dobeonguard
My apologies if I wasnít clear. There is an active recall on this problem but there is no part available yet. I was told by the dealer that Volkswagen expects the part to be available in mid December. They printed off the code and the recall that the vehicle was under, but I have not received any notice in writing from Volkswagen. This was from the dealer.
The separate code was a low battery in the keyfob. They replaced that for me and sent me on my way without charge.
Old November 15th, 2019, 19:18   #12
sloinker
sloinker's Avatar
The recall has expanded. Originally my car wasn't on the list but I received a notice recently stating it is now on recall and awaiting parts.
sloinker is offline   Reply With Quote
Error Message Jimy VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 0 January 18th, 2018 06:55
G 80 error message PeeWee VW MKIII-A3/B4 TDIs 4 December 26th, 2013 23:20
fatal error message! tditom TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 7 October 5th, 2006 08:00
Vag-Com error message - help! JetWag03 OBD Scanners 4 November 23rd, 2003 09:05
error message tditom TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 1 February 2nd, 2003 21:14
Page generated in 0.17467 seconds with 11 queries
[Output: 106.06 Kb. compressed to 88.91 Kb. by saving 17.15 Kb. (16.17%)]
