Old November 5th, 2019, 07:19   #1
dcjkrueger
TDI(s): 2003
Fuel Economy: 51 MPG Winter, 57 MPG summer
Default Fuel Filter reccomendations....
What fuel filters would you recommend for a 2003 Jetta ALH TDI ? I have been getting mine thru NAPA, but I am concerned that it may not be good enough. A lot of knockoffs out there. Thanks in advance.
dcjkrueger is offline   Reply With Quote
Old November 5th, 2019, 08:11   #2
tikal
Fuel Economy: 37 MPG (~ 45% city)
Default Options to purchase trustable TDI parts
Some options for you: from the dealer or online from our trusted TDI merchants (see this link for more info).
tikal is offline   Reply With Quote
Old November 5th, 2019, 08:11   #3
Giberish33
I usually get mine (and most maintenance parts) from rockauto. Mann or Mahle either one is good. I've heard good things about napa filters fuel/oil/air. I believe they are WIX filters.
Seeing as you are in the USA, I recommend you checkout IDparts. They have all the right stuff and shipping / parts cost should be much better for you than me in Canada. I used to buy from IDparts but they no longer have a cheap shipping option to Canada so rockauto is my goto.
Giberish33 is offline   Reply With Quote
Old November 5th, 2019, 10:03   #4
Lightflyer1
Lightflyer1's Avatar
I second IDParts. Just ordered a bunch from them myself. Very good place to do business with!
Old November 8th, 2019, 08:41   #5
ahldailydriver02
Fuel Economy: 48ish
You could always to do a fuel filter conversion and use a Cat, Baldwin, Donaldson or Wix filters. They are generally cheaper, last longer and filter better, oh and a lot easier to change too. Just a thought nothing against the stock filters just something to consider.
ahldailydriver02 is offline   Reply With Quote
Old November 8th, 2019, 09:40   #6
I use the UFI filters (sometimes packaged as Sofima) on my MKIVs. They're less expensive than MANN, and were OE on the cars when assembled.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
2003 1.9 diesel fuel filter reccomendations dcjkrueger Fuels & Lubricants 7 July 14th, 2017 13:14
Fuel filter looks white inside when i look thru the return fuel hole. Is my filter ok Pcar993 TDI 101 5 February 18th, 2010 15:32
FS: Power Service, oil filter, fuel filter, air filter greg6.7 Private TDI Items for Sale/Wanted 2 September 1st, 2009 17:36
Leaking fuel filter O-rings, did I get the wrong fuel filter? dalchri TDI 101 14 March 26th, 2008 14:47
FS: Elf 5-40, MKV Oil filter, Fuel filter, Cabin Filter BTL Private TDI Items for Sale/Wanted 1 October 24th, 2006 15:02
Page generated in 0.14057 seconds with 11 queries
[Output: 73.23 Kb. compressed to 64.24 Kb. by saving 9.00 Kb. (12.28%)]
