Old November 6th, 2019, 18:26   #31
Rrusse11
"One of the things I miss most about my mk6 is that 6-speed transmission."
Siracha
I too had a MkVI with the 6spd. I prefer my 02J, better ratios.
My .717 5th is a proper overdrive IMO, leastways with my setup.
RC Stage 4: 11mm pump, 17/22, .230 nozzles, 3barMAP,EGR Delete, PD150Intake,SMIC,2.5" Exhaust: Koni Sp Reds, Wagon Springs, ~1"/2"lift:VR6 fr swaybar, Top strut & rear tie bar: 215/55ZR16 GMax AS05's, 10mm/20mm spacers, 35# @: skid plate: 02J, SBC2 End, .717 5th, Peloquin LSD, Fluidampr: TT Short Shifter: : VR6 fr, TT rr Brks
Rrusse11 is offline   Reply With Quote
Old November 7th, 2019, 06:34   #32
Rrusse11
http://johnmaherracing.com/calculators/gear-ratio-calculator/
Here's an excellent calculator for working out what various gear ratios do for speed and revs.
Old November 7th, 2019, 12:28   #33
sriracha
Fuel Economy: 40mpg+/-
I never directly compared the two and at this point have kinda forgotten, in what way do you prefer the 02J ratios?
2005 Jetta Wagon 5mt Graphite Blue Metallic, Malone Stage 1.5 w/ Dynamic EGR
sriracha is offline   Reply With Quote
Old November 7th, 2019, 21:01   #34
Rrusse11
I just felt the 1-6 gears were unnecessarily close. With my admittedly heavily modded ALH the spread between gears is better. If we had no
speed limit autobahns, where you could cruise at 100+mph, then perhaps
it would be usefull. In 6th at highway speeds of 70, I feel that really the motor wasn't working enough.
Like IBW, I actually prefer the driving experience of the ALH. Simpler,
easier to work on, more durable, and much cheaper to mod. Hell, even I can manage some of the mechanicals myself. I like being in contact with
the road. Lol, I suppose the kids would call me "retro".
Your Mileage WILL Vary.
Old November 8th, 2019, 06:49   #35
PakProtector
The 46/33 tooth, .717 gear set should be here today...
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is offline   Reply With Quote
Old November 8th, 2019, 16:25   #36
Rrusse11
Douglas,
Let us know what you think. I have no experience with a PD. I do find myself using 4th more cruising the secondary roads at 55mph.
I can run 5th, but for passing, I'll hit 4th.
Cheers,
R*2
Old November 8th, 2019, 18:27   #37
PakProtector
Douglas,
Cheers,
R*2
Will do. Heck, I'll drop by and let you drive it...meet me at Dutch haven, I'll be grabbing a Shoo Fly Pie... They don't seem very available in MI.
cheers,
Douglas
Old November 9th, 2019, 07:47   #38
Rrusse11
Shoe Fly Pie, unique to the area, basically molasses in a crust. That and sauerkraut are the 2 things that stand out to me as local specialty foods.
Lol, neither appeal to me, but hey, there's no accounting for tastes.
If you get close to my area, drop me a line. {:o)
Old November 10th, 2019, 13:54   #39
boertje
boertje's Avatar
Cruise will work on an ALH.
Where did you find the .700? I ran a .717 for years and liked it, had a .681 before. .681 wasn't suitable for me. .700 would be sweet.
When I had a five speed in my bug I installed a .681. I found it a little too tall for my liking and would have preferred the .717.
'01 and a 2nd '01 and a '03 NB TDI with 6 spd manual. '06 NB GLS TDI DSG.
All with Malone tuning of course.
Auto to 5/6 spd manual swap with wiring instructions for MKIV. Click here.
boertje is offline   Reply With Quote
Old November 10th, 2019, 16:15   #40
I've had both in my car. Same impression of the .681 as you. I just wish the .717 is a bit taller, especially when running at 80+. That's why I wonder if the .700 may be the sweet spot for road trips.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old November 10th, 2019, 20:55   #41
VW Ron
I just found this RPM Chart on an old trend looking at the .681 and .658. Well the .681 is no longer available but it gives some interesting numbers on the .658.
In my opinion 1600 RPM at 53mph would not be lugging the engine at all . Sure you would not want to slam it but it should be fine if your just light with the go pedal. I also think 73mph 2200RPM would be in the sweet spot. Please feel free to comment.
Ron
Sorry for the cut and past job but it goes as follows:
RPM4th MPH RPM5th StockMPH .681MPH .658MPH
1000 21.25 1000 29.39 32.11 33.23
1100 23.38 1100 32.33 35.32 36.56
1200 25.50 1200 35.27 38.53 39.88
1300 27.63 1300 38.21 41.74 43.20
1400 29.75 1400 41.15 44.95 46.53
1500 31.88 1500 44.09 48.17 49.85
1600 34.00 1600 47.03 51.38 53.17
1700 36.13 1700 49.96 54.59 56.50
1800 38.25 1800 52.90 57.80 59.82
1900 40.38 1900 55.84 61.01 63.14
2000 42.50 2000 58.78 64.22 66.46
2100 44.63 2100 61.72 67.43 69.79
2200 46.75 2200 64.66 70.64 73.11
2300 48.88 2300 67.60 73.85 76.43
2400 51.00 2400 70.54 77.06 79.76
2500 53.13 2500 73.48 80.28 83.08
2600 55.25 2600 76.42 83.49 86.40
2700 57.38 2700 79.36 86.70 89.73
2800 59.50 2800 82.30 89.91 93.05
2900 61.63 2900 85.23 93.12 96.37
3000 63.75 3000 88.17 96.33 99.70
VW Ron is offline   Reply With Quote
Old November 18th, 2019, 10:32   #42
Just ordered the 0.700. I have a 0.717 in an older transmission that I was going to put in the transmission that's currently in my Wagon, but the step up was small enough (it's a BEW transmission) that I hadn't bothered. But I miss it. the 0.700 will be a better step up. I typically run at an indicated 75-78 on trips, which should be right around 2400 RPM with the 0.700. Looking forward to that.
Old November 19th, 2019, 17:21   #43
Rrusse11
"I typically run at an indicated 75-78 on trips, which should be right around 2400 RPM with the 0.700." IBW
With my oversize tires, IIRC 25.3" vs 24.9" stock diameter, I am doing
75mph when my speedo reads 75 (referenced with GPS). With my 02J, sorry can't recall what exact code my tranny is, I am doing that 75 mph
at 2400rpm with a .717 5th.
Had a discussion with Jeff of RC at what he felt was the optimum revs were for the ALH; "2500rpm". My butt dyno tells me 2400-2600. IBW likes 2400, hey, sounds like we're in the same "sweet spot" ball park. {:o)
Old November 19th, 2019, 19:18   #44
I agree that 2400-2600 is the sweet spot. With the .717 and stock diameter tires, 2600 was just under indicated 80, or about 76 actual. I would usually run at 75, which was right around 2500 RPM. But as time has gone by I've realized that people drive faster than they used to. Driving across Michigan sticking at 75 is risking getting run over. 80-85 is better. That's why I want taller gears.
Old November 19th, 2019, 19:49   #45
Rrusse11
"sticking at 75 is risking getting run over." IBW
I hear ya'! Most of my long distance miles out west have been towing my
teardrop. I found that with a .658 it was loosing torque around 65, a sane
speed with a 1200# load, 2 people, a couple of dogs and miscellaneous accoutrements. Now with the .717, no danger of lugging and spiking EGTs.
Turbo obviously plays into the above equation as well, my 17/22 doesn't hit
it's straps till the 22-2400rpm range. On good roads and no traffic I have to
watch my speed with the camper. At 75 I can blip the throttle and I'm at 80
to pass that big truck, hills or the Rockies? no problem. Mileage?, lol, I don't care after
chatting to others in the campgrounds. Almost universally they are in single
digits.
MK4 Jetta 5th Gear choice VW Ron TDI Fuel Economy 2 November 3rd, 2019 18:40
5th gear swap/repair .. 5th locking collar gear adjustment sam2007 TDI Fuel Economy 0 May 15th, 2016 04:18
WTB TDI 5th Gear set any ratio or the pinion gear for a .681 5th gear set G60ING Private TDI Items for Sale/Wanted 0 November 11th, 2007 08:42
WTB: mk3 tdi 5th gear....or blown trans with good 5th soccergk Private TDI Items for Sale/Wanted 4 March 2nd, 2007 19:22
Lost 1st gear,2nd gear,5th gear, and reverse Glen_Pratt VW MKIV-A4 TDIs (VE and PD) 11 December 10th, 2003 21:21
Page generated in 0.12366 seconds with 11 queries
[Output: 140.86 Kb. compressed to 119.52 Kb. by saving 21.35 Kb. (15.15%)]
