Old November 5th, 2019, 06:57   #16
1bean
Opened lower IC line at hose clamp. About 1 qt of black oil drained into bucket. No signs of moisture. That's all I have done. Im located close to Modesto. I have all paper work that has been done, but purchased from private, who purchased from Dealer. I will call local vw and see if they cover?
1bean is offline   Reply With Quote
Old November 5th, 2019, 09:18   #17
flee
flee's Avatar
Fuel Economy: 40-ish
Good idea. Let us know.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old November 5th, 2019, 09:56   #18
andreigbs
Shouldn't matter where you purchased from, the extended emissions warranty is transferable to subsequent owners as long as the fix was done.
If local dealer waffles, you need to reach out to corporate. VWoA should make sure to cover it.
2014 Jetta TDI // 44xxx miles // 38 MPG & 2014 GLK 250 // 109xxx miles // 34 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is offline   Reply With Quote
Old November 6th, 2019, 11:26   #19
Metal Man
Metal Man's Avatar
Make sure you have the silver sticker on the bottom of the hood indicating the fix was done.
For parts and timing belt tool rentals www.metalmanparts.com FREE shipping on most orders over $75. Free shirt by request with order.
https://www.metalmanparts.com/produc...&categoryId=89
Metalmanparts Facebook page
https://www.facebook.com/metalmanparts
Metal Man is offline   Reply With Quote
Old November 6th, 2019, 11:58   #20
Franko6
X3 What Metal Man said...
For a measly $100, we do a pre-purchase inspection. It is very seldom that we don't find WAY more than $100 wrong with the vehicle.
More than likely this is something that would have likely shown up with inspection. We have found this issue with turbo on one of the re-released cars. Unfortunately, we know darn well that that particular car was given it's check list. They checked everything on the list and then went to find the car the check list belonged to... Oh yeah, that helps.
To protect yourself, you had better be able to show oil change, with the correct oil. Otherwise, you could be on the hook for repairs. For future reference, when a turbo pops, you STOP, QUICKLY. DO NOT START UNTIL CONFIRMED and REPAIRED. You can wreck the rest of the engine by running it out of oil.
Franko6 is offline   Reply With Quote
Old November 14th, 2019, 21:51   #21
1bean
Thanks for everyone's comments and advice.
I did take to VW service and it was determined there was evidence that the turbo went out and then had internal damage, bending rods in #2 and #3 hole. I was surprised to hear that the first steps from service tech was to install 3 quarts of oil and try and start. Then open glow plugs to see if oil pumped out? I told them that I had already discovered oil in lower IC line, but was told that was the procedure to follow from VW.
After giving them service records and basic maintaince records, showing receipts of oil and filters from fuel and air, they told me that I was indeed covered through the emissions warranty that went with this car until 2023 or 180k.
VW is providing a new long block and Turbo. Also gave me a loaner 2019 Jetta to use until all work is completed!
Today was first day I drove to work in the Jetta. Was very impressed with the comfort, power and fuel mileage from that little turbo gas 1.4. Appears that it may get better than 40 mpg on freeway!
Old November 15th, 2019, 08:40   #22
flee
flee's Avatar
That is about the best outcome for your situation.
Old November 15th, 2019, 08:58   #23
andreigbs
Agreed, that's a good ending to what started out as a sad, scary story.
All the best.
Old November 17th, 2019, 11:07   #24
Metal Man
Metal Man's Avatar
Nice.
Radiator puking it's guts.... BootsNTrucks VW MKIV-A4 TDIs (VE and PD) 13 November 3rd, 2016 06:28
Waste gate puking oil CFIMuncie VW MKIV-A4 TDIs (VE and PD) 2 July 31st, 2013 09:24
Oil feed line to turbo popped off (I think) puter VW MKIV-A4 TDIs (VE and PD) 28 January 28th, 2010 09:21
Puking oil and soot. menachite VW MKIV-A4 TDIs (VE and PD) 14 October 17th, 2004 14:29
Page generated in 0.13733 seconds with 11 queries
[Output: 91.60 Kb. compressed to 78.38 Kb. by saving 13.22 Kb. (14.44%)]
