Old November 1st, 2019, 13:48   #1
Fblokland
Default turn signal suddenly stops working
The turn signal suddenly stopped working on my 2005 Passat TDI. I imagine I will need to replace the switch. I am just wondering, might a shot of w40 make it work again? Or does that only work for weird clicking? I checked the fuses, they are fine. Also the hazard lights work.
Fblokland is offline   Reply With Quote
Old November 3rd, 2019, 09:17   #2
ekkoh99
mine was on the fritz for a while, clicking fast until I sprayed keyboard cleaner on it. helped for a while and then i replaced the unit.
2005 Passat WGN TDI "Balance shaft upgrade by OilHammer on 3/27/2009" NGK-09 plugs in Jan 2011
ekkoh99 is offline   Reply With Quote
Old November 5th, 2019, 10:40   #3
imo000
imo000's Avatar
Fuel Economy: Good enough
I've strayed electronic contact cleaner is the base of the stalk and that fixed the weirdness.
imo000 is offline   Reply With Quote
Old November 11th, 2019, 16:35   #4
Fblokland
Well, changing the emergency flasher relay fixed my turn signal. Reading other threads on this forum helped me figure it out. Thanks!
Right turn signal only working sometimes brownnugen VW MKIII-A3/B4 TDIs 3 December 24th, 2016 18:53
intermittently, rear right turn signal stops working baminem VW MKIV-A4 TDIs (VE and PD) 6 May 11th, 2016 23:59
turn signal stops flashing after a couple flash now TurboBugger VW MKIV-A4 TDIs (VE and PD) 7 April 23rd, 2010 20:40
Turn signal not working sporadically on left turn? kooyajerms VW MKIII-A3/B4 TDIs 12 February 8th, 2007 16:08
turn signal not working chartmeier VW MKIV-A4 TDIs (VE and PD) 3 October 19th, 2006 05:39
Page generated in 0.11423 seconds with 11 queries
[Output: 61.94 Kb. compressed to 55.29 Kb. by saving 6.65 Kb. (10.74%)]
