Old November 1st, 2019, 06:43   #16
WildChild80
WildChild80's Avatar
Yes
Sent from my Pixel XL using Tapatalk
WildChild80 is offline   Reply With Quote
Old November 1st, 2019, 10:08   #17
Tdijarhead
Car fully warmed up and the hammer mod. I forget you can adjust it with vcds.
Tdijarhead is offline   Reply With Quote
Old November 1st, 2019, 10:16   #18
mr.loops
If you have a VCDS and can advance or retard the IP pulley, is the hammer mod even necessary?
The only time I can think of needing to do this ( hammer mod) is if your injection timing is waay out of spec
mr.loops is online now   Reply With Quote
Old November 1st, 2019, 10:21   #19
WildChild80
Hammer mod is for iq, the pulley is for timing
Old November 1st, 2019, 10:23   #20
Nero Morg
Nero Morg's Avatar
Originally Posted by turbotuff View Post
I've already bypassed the thermostatic tee and have a filter mount for a standard spin-on filter. All the lines under the hood are new with the exception of the injector return hoses, which are next to be replaced.
Another culprit can be the o ring at the quick disconnect fittings next to the firewall. They dry up over time.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old November 1st, 2019, 10:27   #21
turbotuff
I thought about those along with the ones at the fuel sender. Know where I can get new o-rings?
turbotuff is offline   Reply With Quote
Old November 15th, 2019, 02:56   #22
turbotuff
Slight update. I've changed glow plugs, tried some hot shots fuel additive, and still have the same issue.
My group 13 numbers seems decent
I'm seeing a slight fluctuation at idle but this is pretty close for the most part
1: -0.14
2: 0.28
3: -0.05
4: -0.09
Cylinder 2 is a little higher but I shut it off then fired it back up and cylinder 3 was closer to 2 and the values are lower.
Another thing I've noticed is that at hot idle sometimes idle will get a little rough for a few seconds and will drop to 880 and then it'll come back to 903. Only thing I've noticed is while it does this, IQ drops and then rises back up after it runs smoothly again. There doesn't seem to be any rhyme or reason. It'll just happen randomly at a stop light of something. And it's not very noticeable.
I'm at a loss! I will try bumping IQ but with my hot IQ being around 3.2ish, is that really too far off?
Old November 15th, 2019, 03:34   #23
Tdijarhead
No it’s not far off and some cars run fine at that number, but one size (value) doesn’t necessarily fit all. Try bumping it up a bit and see if there is any improvement. You can always return it back to its current value.
Old November 15th, 2019, 11:06   #24
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Did a quick read of the whole thread, think we may have got side tracked. Seems you've ruled out fueling, glow plugs, injectors (unless they're just wore out). Since it's a newly acquired, I would check timing. Verify engine at TDC, cam slot aligned, IP pin close to hole. Then with VCDS, fine tune so it's in the window. Also with the VCDS check if any of the various temperature sensors are reading whack (check when cold, check when hot).
Old November 15th, 2019, 13:09   #25
turbotuff
I've checked timing and temp sensors via VCDS and everything is right where it should be. I haven't checked mechanical timing as I don't have the specific tools.
Old November 15th, 2019, 13:51   #26
BobnOH
not-a-mechanic
You can check it without tools, cam is a bit tricky, you have to remove vacuum pump to see align slot. Simply rotate to TDC mark on flywheel and check the other 2. Just don't try to change it without tools.
Cold start issue on ALH Metalnerd VW MKIV-A4 TDIs (VE and PD) 27 January 19th, 2018 07:27
ALH TDI "Cold" Start Issue AceTdi VW MKIV-A4 TDIs (VE and PD) 27 October 24th, 2017 19:03
ALH Cold Start Issue T_J_C TDI 101 9 February 16th, 2017 00:15
ALH Cold Start Issue Schuttsr1 VW MKIV-A4 TDIs (VE and PD) 2 August 29th, 2014 09:48
Cannot figure alh cold start issue 2002tdi VW MKIV-A4 TDIs (VE and PD) 6 May 5th, 2014 14:03
Page generated in 0.14663 seconds with 11 queries
[Output: 103.76 Kb. compressed to 88.23 Kb. by saving 15.54 Kb. (14.97%)]
