Old October 31st, 2019, 14:50   #1
turbotuff
Default ALH cold start issue
Hi there! I have a rough start issue first thing in the morning with my newly acquired 03 Jetta with 192k miles. The car takes only a couple seconds of cranking to start but runs rough for about 10 seconds and then smooths out. This doesn't seem to make a difference whether it's 40F outside or 60F. I've eliminated the thermostatic tee, drilled out the check valves in the fuel sending unit, ran new fuel lines under the hood, new fuel filter, new updated MAF, ohm'd all glow plugs to be 1.9 ohms, tested glow plug harness, verified coolant temp reads the same as intake air temp and fuel temp. Timing is dead on, IQ is ~3.5 at hot idle. No engine codes in the VCDS. Not sure where else to look. Any help would be appreciated!
turbotuff is offline   Reply With Quote
Old October 31st, 2019, 15:11   #2
mr.loops
My freshly built ALH had a bad cold start stumble first thing in the morning ( lasted around 8 seconds). Starting it warm, I had no issues what so ever
Turns out my static timing was out a tad. Your belt might be stretched causing this rough start.
How do you confirm yours? Did you use the proper tools (cam plate and IP pin) or did you just do a visual check?
mr.loops is online now   Reply With Quote
Old October 31st, 2019, 15:17   #3
turbotuff
Turns out my was my static timing was out a tad. Your belt might be stretched causing this rough start.
I checked it via VCDS
Old October 31st, 2019, 16:28   #4
Fahrvegnugen
A couple of cranking seconds on cold start makes me wonder about or starter or battery. Of course it could be something else but that would be checked later
Fahrvegnugen is offline   Reply With Quote
Old October 31st, 2019, 16:39   #5
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
The fact that it runs rough for 10 seconds makes me think maybe there is a small leak in the fuel system. Once running the air dissipates.
Old October 31st, 2019, 18:48   #6
jmodge
Have you gone to advanced measuring blocks checked your speciified against actual timing during this period.
The more I find to learn, I find there's more to learn
jmodge is offline   Reply With Quote
Old October 31st, 2019, 18:53   #7
jmodge
As mentioned above, it does start on static timing before the ecu takes over. Maybe bump it around and see what happens
Old October 31st, 2019, 19:38   #8
WildChild80
WildChild80's Avatar
Diesel purge, closed loop system and see if that helps
Sent from my Pixel XL using Tapatalk
WildChild80 is online now   Reply With Quote
Old October 31st, 2019, 22:37   #9
turbotuff
Maybe I wasn't clear. It fires off right away and just runs rough once it's started. It doesn't have a starting issue, more a running issuem
No, I've yet to explore the advanced measuring blocks but I'll have to do that.
Already done that with no improvement
Old November 1st, 2019, 00:20   #10
Nero Morg
Nero Morg's Avatar
Sounds like your fuel return system is bleeding down. Mine did the same thing, same symptoms and all. The thermo t wasn't sealing correctly, poorly manufactured filter. Replaced the filter and it fixed it right up. Mind you, when the fuel return system leaks, typically it'll let air in when cold, rather than leak fuel. Starts from #1 injector, goes to IP, then fuel filter thermo t. Check all the lines, and replace as necessary. Good luck.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old November 1st, 2019, 00:23   #11
turbotuff
I've already bypassed the thermostatic tee and have a filter mount for a standard spin-on filter. All the lines under the hood are new with the exception of the injector return hoses, which are next to be replaced.
Old November 1st, 2019, 03:36   #12
Tdijarhead
Try moving the IQ to 4-4.5 and see what happens.
The only other thing I notice is your glow plugs are a little high on the ohm scale. They should be in the 0.5-0.7 area, however if they are all about the same and you have no glow plug codes I would leave them alone for now. They shouldn’t affect your idle.
Tdijarhead is online now   Reply With Quote
Old November 1st, 2019, 06:31   #13
turbotuff
Hammer mod or via VCDS?
Old November 1st, 2019, 06:38   #14
WildChild80
Hammer mod but if you wanna try it with vcds to see if it makes a difference, I don't think that would hurt
Old November 1st, 2019, 06:41   #15
turbotuff
Hammer mod
Hot idle correct?
Cold start issue on ALH Metalnerd VW MKIV-A4 TDIs (VE and PD) 27 January 19th, 2018 07:27
ALH TDI "Cold" Start Issue AceTdi VW MKIV-A4 TDIs (VE and PD) 27 October 24th, 2017 19:03
ALH Cold Start Issue T_J_C TDI 101 9 February 16th, 2017 00:15
ALH Cold Start Issue Schuttsr1 VW MKIV-A4 TDIs (VE and PD) 2 August 29th, 2014 09:48
Cannot figure alh cold start issue 2002tdi VW MKIV-A4 TDIs (VE and PD) 6 May 5th, 2014 14:03
Page generated in 0.17928 seconds with 11 queries
[Output: 127.00 Kb. compressed to 105.69 Kb. by saving 21.31 Kb. (16.78%)]
