Old November 10th, 2019, 12:16   #16
GlowBugTDI
GlowBugTDI's Avatar
Fuel Economy: 43 mpg average
update, so i rechecked and it turns out it is the big bolt type thing on the end of the right side of the pump. In the center of the 4 injector lines is a big nut type thing with a smaller bolt in the center of it. The bigger nut looking thing is the part that is leaking. is there a seal in there? where do i get that seal and how do i change it?
thank you!
GlowBugTDI is offline   Reply With Quote
Old November 10th, 2019, 13:59   #17
terrydtdi
terrydtdi's Avatar
Fuel Economy: BEST 58 ( 900 mile Club ) av. 46, worst 38, Mobil 1 TDT
That should be the three sided plug. You will need to purchase the socket or you can make one out of a 6 point socket (cut three sides out). I think it was a 15/16Ē I used. There is a video somewhere on YouTube I think on whatís needed to set the pump up to do it. Itís a pretty easy task.
The seal kit from Diesel Geek has that seal in it. You can also purchase the socket from there as well.
2K jetta gl tdi 5spd 407k, RC5+, 17/22, R520's, ported head, ARP head studs, 11mm, 3" turbo back, Kerma OMI, PD150IT & race pipe, VR6 air box & MAF, Godspeed SMIC, 3 bar map, PD lift pump, 681 fift, TT LCA's, spindles, brakes, GLI rear brakes and interior, VR6 axles, mcnalley boost/egt gauge, SBC Stage 2 Endurance, bagged, Michelin Pilot Super Sports
terrydtdi is offline   Reply With Quote
Old November 12th, 2019, 08:09   #18
GlowBugTDI
GlowBugTDI's Avatar
ok that sounds good. thank you!
Old November 14th, 2019, 19:39   #19
fatmobile
Yeah, I think that's an o-ring.
fatmobile is offline   Reply With Quote
replaced seals in injector pump Johnpenner TDI 101 6 January 8th, 2014 11:51
New injector pump seals now no power. airman1 VW MKIV-A4 TDIs (VE and PD) 2 June 11th, 2012 21:01
B4 injector pump seals dweisel VW MKIII-A3/B4 TDIs 18 April 8th, 2009 12:35
Injector pump seals OSTDi Ontario 3 January 13th, 2007 14:41
Concerning leaking injector pump seals... groove TDI 101 5 December 12th, 2005 14:35
Page generated in 0.12920 seconds with 11 queries
[Output: 64.33 Kb. compressed to 57.69 Kb. by saving 6.64 Kb. (10.32%)]
