Old October 15th, 2019, 09:21   #1
emerscape
Default When can I start using OptiLube Winter Blend?
Just picked up a 2012 TDI Touareg Lux with 70k miles. I'd like to start using an additive and IDParts (local to me) carries both the Optilube XPD and Optilube winter blend. Given that we are already in mid-october and I'm in the northeast, when can I start using the winter formula?
emerscape is offline   Reply With Quote
Old October 15th, 2019, 10:07   #2
Lightflyer1
Lightflyer1's Avatar
Any time you want I would imagine. There should be nothing wrong with using it year round if you wanted to.
Old October 16th, 2019, 12:10   #3
jerrymander
jerrymander's Avatar
I like how useful the manuals are: https://i.imgur.com/FVXyGYc.png i.e. not at all. If you even look at the fuel tank sternly, you will void your Limited Volkswagen Warranty! ****ers.
I used additives when I lived in Minnesota once the snow came. I also stopped using additives for a while that January and nothing bad happened.
jerrymander is offline   Reply With Quote
Old October 16th, 2019, 13:15   #4
Lightflyer1
That looks to have good info if you are not familiar with diesels. Don't know why you think it is so lame. I would follow their advice. At 20F and below I would use something just in case. Otherwise I wouldn't use one at all. No real need.
Old October 16th, 2019, 15:27   #5
I'd just use the XPD. It has anti-gel, certainly enough for our climate. I use it year-round. My son in Wisconsin, on the other hand, uses Winter Blend when temps get consistently below 0F.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old November 9th, 2019, 16:31   #6
ShelbyRazorback
I live in Wisconsin and I use XPD all year round. I wonder if I should get Winter formula. Hmmm...
ShelbyRazorback is offline   Reply With Quote
Winter blend & Summer blend at same station? Wankel7 TDI 101 12 January 6th, 2014 17:27
when is D2 changed from Winter blend to Summer blend? RomanL VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 20 April 2nd, 2012 14:45
OptiLube XPD: ZERO start-up clatter tdiatlast VW MKV-A5 Golf/Jettas 18 March 31st, 2012 05:55
Winter Blend Already? xracerbob Fuels & Lubricants 1 August 17th, 2006 06:43
Winter Blend in Ontario? Craig Fuels & Lubricants 2 October 31st, 1999 17:13
Page generated in 0.12616 seconds with 11 queries
[Output: 74.10 Kb. compressed to 64.81 Kb. by saving 9.29 Kb. (12.54%)]
