Old November 13th, 2019, 21:33   #31
turbobrick240
turbobrick240's Avatar
You'd have made a bit more on a non awd dyno. I'd say that's a good baseline to start from. How much boost was that? Give that garage door a crack next time .
Old November 13th, 2019, 22:25   #32
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Mustang dyno are pretty reliable. You should test it in 5th gear instead of 4th.
Need to increase rail pressure ..seen the log ..+300bar minimum
more fuel on top and adjust things for lower smoke level
now its just too much smoke imo. I ran 360 smokeless , not even a haze . I had a puff of smoke at about 2000rpm then 0.
Now you really need to take it to the next level. You are close, but the difficult part starts now.
Good job anyway!
Turbo is big so it will be difficult to spool it without a lot of fuel ..need to compromise.
CP3 Upgrade
Macradiators.com is offline   Reply With Quote
Old November 14th, 2019, 05:19   #33
travis45
travis45's Avatar
Thanks for the encouragement. Hahahaha
14 Sportwagen. 267hp last time at the Dyno.
travis45 is offline   Reply With Quote
Old November 18th, 2019, 20:01   #34
GearGuy2014
Wow just ran across your build - this thing looks awesome! I'm Stage 3 and this looks like an animal in comparison! Also Im located in Northern IL, not sure where abouts in Wisconsin you are near.
2014 VW Jetta TDI
CR170 Turbo
Buzzken 2.5" DP w/ Rawtek Resonator & Catback
Malone Stage 3 Tune w/ DSG Tune
GearGuy2014 is offline   Reply With Quote
Old November 20th, 2019, 18:05   #35
travis45
travis45's Avatar
Green Bay area.
Old November 24th, 2019, 19:20   #36
travis45
travis45's Avatar
https://youtu.be/rVaylWovfnc
Old November 24th, 2019, 19:20   #37
travis45
travis45's Avatar
Engine failure.
Old November 24th, 2019, 22:37   #38
Mongler98
Looks like you passed your egt threshold by a nozzle failure. 10 bucks says the nozzle melted a hole right though the piston. Not sure what caused this, failed nozzle perhaps?
Glad to see progress.
Old November 25th, 2019, 04:20   #39
travis45
travis45's Avatar
Need to pull the head yet, but yes, looks like a failed nozzle.
Old November 25th, 2019, 20:44   #40
[486]
TDI(s): 02 golf ALH
I've been meaning to drill my manifold for 4 pyro probes, so I can watch the power balance with the junk nozzles I've been running
Maybe you should do something similar, then you'd see one was running real hot long before you'd run it hard enough to burn a piston.
[486] is offline   Reply With Quote
Old November 25th, 2019, 23:49   #41
adamss24
Fuel Economy: 35-45mpg
It really sucks mate, definitely a cracked piston, had a similar failure once due to bad nozzles that were overfueling...Hopefully not much damage done to the head and block...
adamss24 is offline   Reply With Quote
Old November 27th, 2019, 20:46   #42
travis45
travis45's Avatar
Thankful for lots of engines at local bone yards. Picking up two for $900 on Friday.
Old November 27th, 2019, 23:52   #43
adamss24
Its getting an expensive game modding the 2.0 CR tdi... I would go a4 b7 and start with a 3.0 CR tdi instead... you can fit quattro to it easily + its easy to come across parts and the bottom end can take some pounding as few on this site proved !
Old November 28th, 2019, 07:37   #44
[486]
TDI(s): 02 golf ALH
not in the US
probably around a couple thousand of them in the country
Old November 28th, 2019, 11:06   #45
travis45
travis45's Avatar
This isn't a bad idea. More data would be useful. One hot cylinder gets mixed with the rest at the collector.
CJAA engine pkhoury Private TDI Items for Sale/Wanted 1 January 30th, 2019 11:28
Emission Software Update - Update on my situation NJDude VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 31 August 10th, 2015 11:18
CJAA Swap EverythingTDI TDI Conversions 2 June 28th, 2014 08:32
FS - 2010 Jetta TDI CJAA CJAA QuickTD Ontario 3 March 2nd, 2014 07:29
WTB: Engine build parts, ALH build, BHW pistons, Rosten Rods, Big stuff! 2000tdijettafast Private TDI Items for Sale/Wanted 2 February 24th, 2014 09:40
Page generated in 0.16383 seconds with 11 queries
[Output: 126.35 Kb. compressed to 104.84 Kb. by saving 21.51 Kb. (17.03%)]
