Old August 20th, 2019, 20:32   #16
turbobrick240
turbobrick240's Avatar
It might be related to the lowered compression ratio. Seems to run well once going. If you have a block heater, that may be worth trying.
Old August 20th, 2019, 21:03   #17
travis45
travis45's Avatar
I thought about that. But it seems to be more time related than temp related. For example, last week the car was parked outside overnight and was a little cooler. Car started fine or a tiny hiccup starting. At the time of this video, the car sat in the garage for two days.
14 Sportwagen. 267hp last time at the Dyno.
travis45 is offline   Reply With Quote
Old August 22nd, 2019, 11:10   #18
JFettig
JFettig's Avatar
Most likely the piston modifications - completely unnecessary, it'll cause more problems than it'll solve.
JFettig is offline   Reply With Quote
Old August 23rd, 2019, 17:56   #19
travis45
travis45's Avatar
But if we're the slightly lower compression ratio, I'd expect that starting after sitting outside all night and being 55F out would be the time that this issue would manifest itself. In that case it started just fine.
I wouldn't say piston modifications were completely unnecessary. The last engine had valve to piston contact.
Old August 25th, 2019, 17:24   #20
JFettig
JFettig's Avatar
Did you cut valve reliefs in the pistons? I didn't notice any.
The starting issue could be fuel leakdown maybe.
Old August 25th, 2019, 17:33   #21
travis45
travis45's Avatar
We took the outer face down an extra .5mm. If it were poor starting due to the compression ratio, id expect it to stumble more upon startup. But when it hits, it pops right off and runs perfectly.
Best theories so for are fuel pressure leak down or perhaps a stuck ASV.
Old August 25th, 2019, 17:51   #22
travis45
travis45's Avatar
This is as good as time as any to stop here and thank those who have helped me get this far. Never would have happened otherwise....
TDISynco
TDI2Micron
Kevinski
Malone Tuning
Geoff at Colt Cams
Baril Engine in Green Bay WI
Darkside Developments
Mac Radiators
VL Performance
Andre Duesk
Matt Whitbread
TDICLUB members who have commented on my posts
I'm sure I'm forgetting some, so please forgive me if you have given me your time and advice and I didn't mention your name.
Couple bugs to work on yet, but the engine is spins nice and really sings up to redline.
Old August 26th, 2019, 00:04   #23
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Camshafts ..could also give you issues on startup.
My experience with camshafts : i would never spend on camshafts again. Totally a waste of money imo with 0 benefits (2.0 CR )
If you machined 0.5mm from top piston and enlarged bowl, that may be too much.
If you put 3hole gasket ..that worsened the situation.
Since engine ran perfect before ..i dont think injectors went bad while you were building it.
These builds take a lot of time to get right. You'll get there.
CP3 Upgrade
Macradiators.com is offline   Reply With Quote
Old August 26th, 2019, 08:58   #24
travis45
travis45's Avatar
Used a 1 hole head gasket and have .915mm piston to head clearance. If it were too low of compression, I'd expect it to run poorly for a few seconds once it starts, but it runs perfectly when it starts.
Old October 13th, 2019, 20:36   #25
travis45
travis45's Avatar
Thanks to Mark Malone for the help this weekend. Progress being made!
https://youtu.be/agfXGEtvz9s
Old October 13th, 2019, 20:37   #26
travis45
travis45's Avatar
We turned on the glow plugs for every start no matter what the temp and it seems to have helped with the long crank on starts.
Old October 14th, 2019, 17:13   #27
sardo_67
TDI(s): 2003 Jetta
Fuel Economy: 38mpg (driving like i stole it)
How did you get custom cams fit into this. I thought the cams were part of the head assembly and didn’t have caps
sardo_67 is offline   Reply With Quote
Old October 14th, 2019, 19:04   #28
adjat84th
adjat84th's Avatar
This is ea189, not ea288 motor.
Nice to see this moving in the right direction..when do you go to the dyno?
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old October 15th, 2019, 10:34   #29
travis45
travis45's Avatar
Hopefully to the Dyno soon. Still fine tuning.
Old November 13th, 2019, 19:53   #30
travis45
travis45's Avatar
Baseline dyno. 243/290. Was hoping for more, but really just getting started. Low EGT's. Looks like I need more fuel on top.
https://youtu.be/WjrJo--tkgE
CJAA engine pkhoury Private TDI Items for Sale/Wanted 1 January 30th, 2019 11:28
Emission Software Update - Update on my situation NJDude VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 31 August 10th, 2015 11:18
CJAA Swap EverythingTDI TDI Conversions 2 June 28th, 2014 08:32
FS - 2010 Jetta TDI CJAA CJAA QuickTD Ontario 3 March 2nd, 2014 07:29
WTB: Engine build parts, ALH build, BHW pistons, Rosten Rods, Big stuff! 2000tdijettafast Private TDI Items for Sale/Wanted 2 February 24th, 2014 09:40
Page generated in 0.15147 seconds with 11 queries
[Output: 128.46 Kb. compressed to 106.46 Kb. by saving 22.00 Kb. (17.13%)]
