Old May 25th, 2019, 19:43   #1
travis45
travis45's Avatar
Default Build Update CJAA
https://youtu.be/fpD5HAqG4sY
14 Sportwagen. 267hp last time at the Dyno.
travis45 is offline   Reply With Quote
Old May 26th, 2019, 02:16   #2
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
Time to break those 300hp and no SMOKE!
CP3 Upgrade
Macradiators.com is offline   Reply With Quote
Old May 26th, 2019, 05:36   #3
adjat84th
adjat84th's Avatar
So the failure you had sent metal through the turbo as well, that sucks!
2872 with your mods should be a beast!
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
adjat84th is online now   Reply With Quote
Old May 26th, 2019, 06:49   #4
travis45
travis45's Avatar
Yeah isn't that just the icing on f_@(ing cake! Hahaha.
Old July 30th, 2019, 20:17   #5
travis45
travis45's Avatar
It's alive!
Old July 30th, 2019, 20:24   #6
travis45
travis45's Avatar
Old July 30th, 2019, 20:25   #7
travis45
travis45's Avatar
Old August 18th, 2019, 20:23   #8
travis45
travis45's Avatar
https://youtu.be/BYoID3_AkVs
Old August 18th, 2019, 22:01   #9
turbobrick240
turbobrick240's Avatar
Very nice! If it's making 310 lb-ft @ 5k rpm, that's like 300 hp. Impressive.
Old August 19th, 2019, 07:32   #10
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
I like it! Keep it up!
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old August 19th, 2019, 13:57   #11
travis45
travis45's Avatar
Not sure what is going on, but I think the DSG is limiting torque at 307ft/lbs. Need a DSG tune adjustment.
Old August 20th, 2019, 17:20   #12
travis45
travis45's Avatar
Having a hard start issue after the car sits for a day or two. Rail pressure is good.
Start video below. Looking for ideas.
https://youtu.be/CCtTNUhlS1Y
Old August 20th, 2019, 18:06   #13
turbobrick240
Is the in tank pump humming along? You could pull a line off the filter housing and check for flow. It shouldn't be the glow plugs at those temps.
Old August 20th, 2019, 18:50   #14
Yourbuddysatin
Fuel Economy: 32-35mpg
Has it always done that after the rebuild?
Yourbuddysatin is offline   Reply With Quote
Old August 20th, 2019, 20:24   #15
travis45
travis45's Avatar
Not sure about the tank pump, but I pulled a log and it shows rail pressure while cranking.
https://log.malonetuning.com/chart/2...w1dQAAAA%3D%3D
The half dozen or so times the the car sat more than a day or so since the first fire of the rebuild, yes, it has done this. Always starts, but something isn't working just right.
Am fortunate to have some help from some guys way smarter than me. One suggestion was to swap the pressure retention valve on the injector return line. Will give that a try and see what happens.
Thanks for your comments.
CJAA engine pkhoury Private TDI Items for Sale/Wanted 1 January 30th, 2019 11:28
Emission Software Update - Update on my situation NJDude VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 31 August 10th, 2015 11:18
CJAA Swap EverythingTDI TDI Conversions 2 June 28th, 2014 08:32
FS - 2010 Jetta TDI CJAA CJAA QuickTD Ontario 3 March 2nd, 2014 07:29
WTB: Engine build parts, ALH build, BHW pistons, Rosten Rods, Big stuff! 2000tdijettafast Private TDI Items for Sale/Wanted 2 February 24th, 2014 09:40
Page generated in 0.18256 seconds with 11 queries
[Output: 126.77 Kb. compressed to 104.69 Kb. by saving 22.08 Kb. (17.41%)]
