Old November 13th, 2017, 12:53   #1
Machineman
Default B6 S4 bhw compound turbo build
Finally got a chance to post I thread about my build this is one of the few compound turbo build in a longitudinal setup running on the street I took a slightly different approach for Turbo placement which ended up being a very good success I'm running a tdo4 13t high pressure Turbo had a TD06 20g low pressure which is mounted to the tranny with a ultragate38 wastegate almost everything is been custom manufactured schedule 40 manifold with also a schedule 40 hot pipe the car has a Stage 5 South Bend clutch 240mm and I will be running firad160 nozzles power goals are kind of unknown at this point I have about 900 CFM of air to play with so we'll see where that takes me I'm guessing somewhere around 350 awhp would be acceptable very excited to get this going as I've never done a street driven compound setup and I have ran the tdo4 as a single before and it's very responsive so as compounds that should be very good .
Machineman is offline   Reply With Quote
Old November 13th, 2017, 12:55   #2
Machineman
gif upload 20mb
Old November 13th, 2017, 12:59   #3
Machineman
gif upload 20mb
Old November 13th, 2017, 13:06   #4
Machineman
gif upload 20mb
Old November 13th, 2017, 13:10   #5
Machineman
gif upload 20mb
Old November 13th, 2017, 13:12   #6
Machineman
gif upload 20mb
Old November 13th, 2017, 13:15   #7
Boyka
Boyka's Avatar
Good job!!!!!!
Do not drink, do not smoke, do not go out with girls, I'm going to bed at 22:00, wake up at 6.00. Quiet, obedient ... But when you leave jail, everything will change dramatically!!
Boyka is offline   Reply With Quote
Old November 13th, 2017, 13:16   #8
Machineman
gif upload 20mb
Old November 13th, 2017, 13:18   #9
Machineman
gif upload 20mb
Old November 13th, 2017, 13:49   #10
Machineman
Also this project would have been possible without the use of V bands for everything it makes installation so much easier it allows for tighter clearance
Old November 13th, 2017, 14:17   #11
1.4TDI PD
Really nice build the attention to details is amazing i like the biturbo setup. Is this a PD engine and if it is what injector pumps are you using.
1.4TDI PD is offline   Reply With Quote
Old November 13th, 2017, 15:13   #12
Machineman
Thank you yes this is 2-liter PD it uses the stock unit injectors with upgraded nozzles
Old November 13th, 2017, 21:21   #13
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Nice fab work! Interested to see how it runs.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old November 14th, 2017, 01:48   #14
1.4TDI PD
Are you using a FMIC or some sort of water to air intercooler setup.
Old November 14th, 2017, 06:01   #15
Machineman
Yes it will be using fmic that is my next thing to do I'm making from scratch it's going to be a lot of work
Need advice on compound turbo build Mahliloltdi TDI Power Enhancements 25 June 16th, 2017 22:03
I want to build a B6 S4 avant Quattro 6speed TDI. Possible? Celco TDI Conversions 2 March 22nd, 2016 13:54
Just another compound build.... fouckhest TDI Power Enhancements 574 December 27th, 2014 14:29
BEW into B6 S4 nitec TDI Conversions 3 October 26th, 2012 10:17
Audi A4 B6 Avant 130 Sport -> S4 project Phill Other TDI/Diesel Picture Gallery 2 October 13th, 2012 15:06
Page generated in 0.19364 seconds with 11 queries
[Output: 123.67 Kb. compressed to 103.15 Kb. by saving 20.52 Kb. (16.59%)]
