Old March 31st, 2017, 16:08   #16
Vince Waldon
Vince Waldon's Avatar
Originally Posted by jshwamie View Post
All I know, I bought this car with the rc already applied and it hauled ass. Just now is bogging.
That's a clue. The tune has clearly not changed, but the car is performing worse. Suggests the engine has developed a technical problem... one that a tune from someone else won't likely resolve.
If you lost a quart of oil you should probably track it down... and if it is in your intercooler you'd probably better drain it before the engine ingests it and bends a rod or two.
And, if it's in your intercooler it likely got there from the turbo seal on its way out.... which means the turbo is on borrowed time before it *really* lets go and bends a rod or two.
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline   Reply With Quote
Old March 31st, 2017, 19:58   #17
jshwamie
Fuel Economy: 38 mpg
This is true. My problem is gaining access to a lift. That's what has been slowin me down. I should be able to get to the shop and check it out tomorrow. Ive been thinking about my car pulling a runaway on me too.. . I'll get back with the results of logging. Thanks for sticking with me all.
3 Dr 2000 Volkswagen Golf TDi. SMIC with 2.5 lower pipe. 11 mm pump & lift pump, Bosio Sprint 520 nozzles, Kerma TDi Long Runner manifold so no EGR, stock gt1749v turbo, stage 3 RC, VR6 Clutch, shifter work, 2.5 DP turbo back exhaust. Spec-D head lights, Bilstein shocks & springs sitting on 17's with aftermarket leather seats.
jshwamie is offline   Reply With Quote
Old April 1st, 2017, 09:53   #18
flee
flee's Avatar
Fuel Economy: 40-ish
Harbor Freight has ramps for about $30 or so. Plenty of space to slide under and work.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old April 1st, 2017, 15:00   #19
jshwamie
Originally Posted by Kevinski4 View Post
Well your clutch is slipping, that much is obvious. Without posting a Group 11 log of a 3rd gear pull there's not much else we can help you with.
Okay well I have some logs here. Looks like they are in excel format. What is the best way to share files? Not seeing an attachment file button or anything. I have logs for 001 003 004 008 & 011.
Old April 1st, 2017, 16:06   #20
jshwamie
I installed a vacuum gauge to the line that goes to the actuator on the turbo to see what the n75 valve is actually doing to the turbo and making sure it's working properly.
Here is a video of me driving. The pressure goes steadily below 5. Is this normal? I'm thinking not.
https://youtu.be/ILi9OGmOXtw
Old April 1st, 2017, 16:19   #21
jshwamie
Here is a pic of my 011 log.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old April 1st, 2017, 16:41   #22
Enabled
19.5psi when requested is 17.7psi will shorten your turbo's life.
Make sure the actuator is adjusted correctly.
-2003 Jetta TDI GLS Manual (Mods: SBC II Daily, .681 5th, VNT17 & PP520, Self Tuned)
-BMW 328is Manual (heavily modded 220whp, track toy)
-BMW Z3 Roadster (Fun in the sun car)
-BMW Z3 M Coupe (1 of 36)
-BMW 328d wagon (Self tuned ~230hp)
Enabled is offline   Reply With Quote
Old April 1st, 2017, 18:12   #23
jshwamie
Here are the others.
003 MAF
001
008
004 (this one came out weird. Might have to do another)
Old April 2nd, 2017, 19:30   #24
Kevinski4
Kevinski4's Avatar
While you are right on the first part, every ALH out there has a puddle of oil in the intercooler and it's not from the turbo. It's from the CCV. It collects at the lowest point and there's always some in there. Waaay too many people have replaced turbos for no reason. I'm running one of those turbos that someone was throwing away on one of my cars. I've put 60k miles on it since the previous owner replaced the turbo because of oil in the intercooler.
Kevinski4 is offline   Reply With Quote
Old April 2nd, 2017, 19:54   #25
jshwamie
Yeah I at least know that much! Heh. I do think it's something mechanical at this point. Something is just off. I'm going to try taking off the stock air box and just let the pips vent open and drive on some pavement for a mile or so. See how it performs.
Does anyone know how to interpret those logs? I'm not sure really what I'm looking at as far as reading them and understanding what should be what, and when.
Old April 2nd, 2017, 20:58   #26
Vince Waldon
Just my opinion, but if someone loses 3/4 of a quart of oil in one week (per the OP's second post), and finds it sitting in their intercooler...well... my money's on it coming from the turbo, not the CCV. That would be awfully thick blowby.
Old April 2nd, 2017, 21:47   #27
jshwamie
Thanks for the input. I will check this out. I know I have checked it and can see it went up and down a little, but haven't checked full motion. I took some pics, and there was a little oil between the exhaust and compressor housings. I'm thinking that shouldn't be there... Also the oil return line has oil on it.
Pic of oil return line.
Old April 3rd, 2017, 13:45   #28
flee
flee's Avatar
Does anyone know how to interpret those logs? I'm not sure really what I'm looking at as far as reading them and understanding what should be what, and when. Sent from my SAMSUNG-SM-N920A using Tapatalk
Your problem isn't with the airbox as long as there is no obstruction.
Did you swap the MAF yet?
Old April 3rd, 2017, 22:28   #29
swetbak
swetbak's Avatar
If you've checked for oil in your intercooler I've missed it. If you haven't yet checked this off your list, just drill a small hole in the smallest point of the intercooler pipe and see what drips out. When done put a small screw in the hole to close it. You can periodically check for oil this way.
03 Jetta Wagon, 5sp, Bosio 1019's (by DBW), Kerma Tune, 2.5" exhaust, short shifter, PD150 Intake, VNT17, OMI, VR6 clutch, hitch, Limo tint, BBS wheels. Interior blue LED's.
As long as they say "that's the quickest little station wagon I've ever seen!"
2010 335d Sport, abc delete, 2.8 JR tune, ATM intercooler and intake
swetbak is offline   Reply With Quote
Old April 4th, 2017, 13:10   #30
jshwamie
Thank you for the input. I checked for this, this past weekend. No significant pooling. So not sure where that oil went.. I'm guessing it burnt up I guess, because there are no significant leaks. I'm hoping someone can help me understand those logs and offer some insight.
3 Bar map upgrade tuning? jshwamie VW MKV-A5 Golf/Jettas 4 March 6th, 2017 22:01
17/22 wanted piping for upgrade 3 bar map sensor too Moesauction! Private TDI Items for Sale/Wanted 3 March 15th, 2015 14:12
3 Bar Map for ALH droppedjet Private TDI Items for Sale/Wanted 11 December 3rd, 2009 06:33
3 bar MAP sensor + stock tuning/turbo... DBDieseler TDI Power Enhancements 12 January 14th, 2009 23:55
3 bar map sensor upgrade? danielhf TDI Power Enhancements 3 November 12th, 2007 04:56
Page generated in 0.17577 seconds with 11 queries
[Output: 140.03 Kb. compressed to 118.40 Kb. by saving 21.63 Kb. (15.45%)]
