Old March 25th, 2017, 21:56   #1
jshwamie
Fuel Economy: 38 mpg
Exclamation 3 Bar map upgrade & tuning? ALH 1.9
I have a new SMIC with 2.5 lower plumbing. rocketchip stage 3, VR6 Clutch, 11mm pump with lift pump. EGR Delete, Kerma TDI Long Runner intake manifold, 2.5 DP - str8 pipe. PP520 nozzles, bilstein suspension with coil overs. Running stock gt1749v turbo. I will be putting a stage 2 or 3 cam in, with head studs and would like to do something with the turbo eventually here. Maybe try to hybridize it somehow to squeeze 200hp (which is my goal for this car) out of it, or upgrade to gt1749vb which I could make 17/22 or go for 1726 instead (daily driver so like the faster spool).
With that said. I would like to upgrade to a 3 bar MAP. I read that u can't just slap it in and be done. You have to adjust some sort of tuning. Can someone explain this a little for me? Keep in mind I have a rocketchip, and I can't seem to get them to reply to me. Basically I want to know if I can buy some software or something and adjust what I need to make the 3 bar work, or would I have to get a new custom tune from say Kerma TDi. Thanks in advance.
jshwamie is offline   Reply With Quote
Old March 25th, 2017, 23:42   #2
Nevada_TDI
Your current tune is written for a 2.5 bar MAP sensor, and if you went to a 3 bar MAP sensor then your tune would need to be rescaled to use the upgraded sensor. At this point there is really no reason to upgrade the MAP sensor without upgrading to a turbo that would be happy at 24 PSI and above.
_______________
2001 Jetta GL TDI, Tinted, Vented, No Kitty, EGR-ectomy, TDTuning, HIFLO .216's, TurboLabAmerica Hybrid 15-17/56, VCDS Hex+CAN, S-B Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Koni Orange, New Paint. Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old March 26th, 2017, 10:32   #3
jshwamie
Hm. Okay. I think I'll have to upgrade my turbo soon here so might have to do just that. Can RC be scaled like that if I do? I've been finding an intermittent loss of power when I get on it. One day it's perfect and the next day you can tell it's just not all there when u punch it. I was starting to notice black smoke when under load as well. My car runs clean as heck and barely would you see black smoke, suddenly am.
Yesterday I turned my car on and my oil light came on and I was missing about 3/4 quart of oil in about 5 days. Prior never lost a drop in 2600 miles. I know I have a bad injector gasket after whomever installed the #3 left it loose. Tightened but it's still puffing black around it. So that and a faintly leaking oil filter gasket are the only signs of anything off. Im going to check my intercooler for oil (upgraded to SMIC in the past month or so) and there was little oil in the stock system. I fear there may be a lot and my turbo is on its way out...
3 Dr 2000 Volkswagen Golf TDi. SMIC with 2.5 lower pipe. 11 mm pump & lift pump, Bosio Sprint 520 nozzles, Kerma TDi Long Runner manifold so no EGR, stock gt1749v turbo, stage 3 RC, VR6 Clutch, shifter work, 2.5 DP turbo back exhaust. Spec-D head lights, Bilstein shocks & springs sitting on 17's with aftermarket leather seats.
Old March 26th, 2017, 15:58   #4
Owain@malonetuning
Sounds like you're not making optimal boost at times, hence the smoke (unless it's blue..). Turbo might be on it's way out, best to do some boost logging to see how it's behaving. Block 11 covers requested vs actual and N75 %s. This turbos good for 18 PSI or so, anything past 20 is dangerous.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Old March 29th, 2017, 09:34   #5
jshwamie
So I cleaned up that injector got a new copper ring for it and put it back in. Checked for boost leaks and see if everything was operating fine with the wastegate. All good there. I didn't get time to pull the boost pipe off the intercooler to see if there was a lot of oil in there though.
We went for a ride and kinda watched everything good. You can tell when you gun it the turbo will intermittently fall off and not create boost. So I don't know if this is the tune doing this or what. Have that stage 3 RC. Never did this before though that's why I don't get it. I can pull the MAF off and there is no change. I attempted to reach out to RC but I can't get them to respond for the life of me. At this point think I'm gunna save up and get a custom tune. Not sure what else to do.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old March 29th, 2017, 10:17   #6
flee
flee's Avatar
Fuel Economy: 40-ish
If there is no change when you disconnect the MAF then try replacing the MAF.
You're not using a K&N, are you?
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Old March 29th, 2017, 10:26   #7
jshwamie
Hello,
No k&n. Stock airbox, which from what I understand will flow enough air to get me to my 200ish hp goal. I took out the snowscreen and that tube all together. I have checked the box for contamination and debris.
As for the MAF. What I could do maybe is borrow my friends from his car that is running good. That should do it hey. If it works better I'll know.
There is still the mystery of where that nearly quart of oil went. But Im assuming it's in my intercooler. Question is. Why.
Old March 29th, 2017, 10:29   #8
jshwamie
Im going to do this this weekend. I should have time. I'll get some graphs and we'll see what happens. At least have some definitive proof. Then just need to see why.
Old March 29th, 2017, 12:23   #9
jshwamie
Here is a video of me accelerating. It has lack of power all across and isn't accelerating as quick as it should. You can see when I'm in fifth gear and slow down to 2k and floor it. It drops RPM's and picks back up. That's where I'm losing my boost and my turbo is none existent. Same results with or without MAF plugged in.
https://youtu.be/E6SCgjD-kew
Old March 29th, 2017, 14:15   #10
hankymurphy
hankymurphy's Avatar
Fuel Economy: not 50mpg anymore
Is that a clutch slip at the end or the motor stuttering? Possible the vanes on your turbo are sticking too. there are a few threads on here about how to clean that up, but if you are planning to upgrade the turbo soon, maybe don't even bother. Do you have VAGCOM?
'14 A6 TDI - stock/"fixed"
'02 Jetta: Ported head, stage 2 cam, 11mmIP, VNT 17
'01 Golf: 287k+ miles, Stage 4 . 900 mile club - SOLD
hankymurphy is offline   Reply With Quote
Old March 29th, 2017, 18:41   #11
Kevinski4
Kevinski4's Avatar
Well your clutch is slipping, that much is obvious. Without posting a Group 11 log of a 3rd gear pull there's not much else we can help you with.
Kevinski4 is offline   Reply With Quote
Old March 29th, 2017, 22:46   #12
jshwamie
You think that's the clutch slipping? I noticed that for the first time yesterday. It doesn't feel like a clutch slip, but Im no mechanic. Ive always experienced clutch slippage when shifting into a gear or starting from a stop. I had it in 5th, let it drop RPM and throttled it. This clutch was put in at 134k miles. I'm at about 230k now. It's Def probably about time for it to start going.
Hankymurphy I do have access to VAG. I'm going to get some recordings here this weekend. See what we come up with. Thanks for your input this far everyone. Cannot thank you enough. Having a hard time figuring this out so, your help is essential to fixing my problem.
Old March 29th, 2017, 22:54   #13
jshwamie
Im going to be getting a custom tune here. This RC is just too cookie cutter. I need to be able to adjust it and have a tune from somewhere that will actually reply to my emails.. I know my friend has a kerma tune, which he seems to like. But the Malone tune I've read and heard a lot of good as well. I live right in your area as well - Iron Mountain, MI.
Old March 30th, 2017, 18:53   #14
Kevinski4
Kevinski4's Avatar
No need for a "custom" tune, the RC3 you have is great. You have a mechanical issue with your car that needs to be fixed.
Old March 31st, 2017, 15:49   #15
jshwamie
Think so? I mean everyone is telling me to get a custom tune. All I know, I bought this car with the rc already applied and it hauled ass. Just now is bogging. Should be able to get some logs tomorrow.
3 Bar map upgrade tuning? jshwamie VW MKV-A5 Golf/Jettas 4 March 6th, 2017 22:01
17/22 wanted piping for upgrade 3 bar map sensor too Moesauction! Private TDI Items for Sale/Wanted 3 March 15th, 2015 14:12
3 Bar Map for ALH droppedjet Private TDI Items for Sale/Wanted 11 December 3rd, 2009 06:33
3 bar MAP sensor + stock tuning/turbo... DBDieseler TDI Power Enhancements 12 January 14th, 2009 23:55
3 bar map sensor upgrade? danielhf TDI Power Enhancements 3 November 12th, 2007 04:56
Page generated in 0.16543 seconds with 11 queries
[Output: 133.90 Kb. compressed to 112.64 Kb. by saving 21.26 Kb. (15.88%)]
