Old November 15th, 2019, 12:53   #4426
Nero Morg
Nero Morg's Avatar
Did a compression test this morning, 460psi across the board. Not bad for 330k.
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is offline   Reply With Quote
Old November 16th, 2019, 13:56   #4427
sriracha
Fuel Economy: 40mpg+/-
Originally Posted by BakoTDI View Post
Let me know how you like it! I totally like mine
Still in the break-in period with the clutch, so haven't really gotten into'er, but so far, it's really smooth and holds without slipping going up the grades on the 101.
On a side note, discovered that my EGR Flex Pipe has a crack and is the cause of my engine bay exhaust leak and faint whistle noise. Also, found out that I have a weeping valve cover gasket. Need to replace the EGR Flex Pipe and VC gasket. Any knowledge I should know, before purchasing parts?
2005 Jetta Wagon 5mt Graphite Blue Metallic, Malone Stage 1.5 w/ Dynamic EGR
sriracha is offline   Reply With Quote
Old November 16th, 2019, 14:55   #4428
Read this: http://forums.tdiclub.com/showthread.php?t=263090
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old November 16th, 2019, 17:49   #4429
romad
romad's Avatar
Note: The link in post 6 of the above thread now takes you to a site called "Unlimited Books Library".
The fleet:
romad is offline   Reply With Quote
Old November 17th, 2019, 04:19   #4430
That's unfortunate. We have it, too, along with the bolts. https://www.idparts.com/egr-cooler-b...ew-p-2201.html
Old November 17th, 2019, 11:35   #4431
sriracha
I installed the stainless steel Audi TT pedals and dead pedal footrest set today. Pretty nice looking and the rubber tread on the pedals provides better grip.
Old November 17th, 2019, 20:37   #4432
WildChild80
WildChild80's Avatar
Finished up HIDs on my 2000. Threw the relay kit away. Decided to use an 8A diode and cross paths with the high and low beam, ballasts stay on and shutters work.
Sent from my Pixel XL using Tapatalk
WildChild80 is offline   Reply With Quote
Old November 17th, 2019, 21:43   #4433
Nero Morg
Nero Morg's Avatar
Helped a buddy trailer a new to him 2002 wagon tdi, stack of receipts from fix um hauns in it, supposedly needed an injection pump, turns out it just needed reprimed! Runs super smooth, but rear brakes are stuck, hatch lid is damaged, headliner is sagging, both bumpers damaged... It'll be a project, but not bad for $500!
Old November 18th, 2019, 10:36   #4434
Black00Jetta
Black00Jetta's Avatar
Fuel Economy: 51.1/45.2/39.6
After 304k, replaced original starter that was getting weak (really weak in MN weather at 5 degrees!). Also replaced another window clip when that decided to drop the window while in the northern tundra!
2000 Jetta GLS TDI 5spd manual, 299k[/SIGPIC], chipped, Frost heater, metal skid plate, Metalnerd brake tool, ventectomy, VCDS(but need to learn how to use it). Scangauge II
Black00Jetta is offline   Reply With Quote
Old November 18th, 2019, 11:24   #4435
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
That's it, I'm calling the cops, your buddy is a thief!
Seriously though, good job keeping another one alive!
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is online now   Reply With Quote
Old November 18th, 2019, 12:54   #4436
Nero Morg
Nero Morg's Avatar
Haha yeah it's a hobby at this point. It'll sit for a bit due to financial constraints, it's due for a timing belt and probably a trans valve body.
Old November 18th, 2019, 17:20   #4437
Trgreen
TDI(s): 2001 Jetta
Default Heater core change on MK4 now immobilizer issue ugh
Need help no start after heater core replacement starts for a couple seconds and then dies, checked all fuses and connectors now what!
Trgreen is offline   Reply With Quote
Old November 18th, 2019, 23:08   #4438
STDOUBT
STDOUBT's Avatar
Camp here:
http://forums.tdiclub.com/showthread.php?t=503513
2003 Jetta TDI 1.9L 5-speed
Search Tip: search this site best by using Bing: tdiclub topic
STDOUBT is online now   Reply With Quote
Old November 19th, 2019, 17:05   #4439
WildChild80
I began the lengthy process of taking all of the giddyup parts off of one car and on to the other. I really want to leave the cam and pump on it to avoid the pains of a timing belt job...I'm only 30k from needing to do it anyway.
Not sure when they will go on the other car...maybe this weekend. I think I'm gonna have an issue, have a tune on the 2001 and want to swap the ECU to the 2000 they are going on. Man I hope I don't have immo issues...
Old November 20th, 2019, 14:22   #4440
Powder Hound
Powder Hound's Avatar
You won't if you have an immobilizer delete as part of the tune!
Cheers,
PH
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
TornadoRed
I saw a TDI CC today in Denver today 9/14/2012 rotarykid Sightings 2 October 2nd, 2012 19:30
MKIV 6 disc, Yakima Q103 clips, MKIV 4 spoke airbag Reifenberger Private TDI Items for Sale/Wanted 3 May 21st, 2012 16:42
What have you done to your MkIV today???? Kymerik VW MKIV-A4 TDIs (VE and PD) 3 October 7th, 2009 07:24
FA: MKIV Jetta Original Floor Mats (Ends Today) jtroyce Private TDI Items for Sale/Wanted 0 October 29th, 2002 06:19
Page generated in 0.22024 seconds with 11 queries
[Output: 133.41 Kb. compressed to 111.83 Kb. by saving 21.57 Kb. (16.17%)]
