Old February 19th, 2015, 14:02   #16
donh
Finally getting around to an update. Dealer removed 250 ml. of oil and the problem has disappeared. originally the dipstick showed at the top of the safe level. Dealer was vague about the problem stating only that VW will do something about it in the future. It looks like the explanation Stew 2015 got fits. Now lets wait for the software update.
donh is offline   Reply With Quote
Old February 20th, 2015, 07:26   #17
Tremulant
TDI(s): MK7 Golf TDI
Good to know. Mine's currently in the shop - Dropped it off this morning and will report back with what they've found.
Tremulant is offline   Reply With Quote
Old February 23rd, 2015, 07:28   #18
Tremulant
Update -
They took oil out as well. Said there was nothing wrong with the sensor or the ECU.
But...
This morning, on my way to work it happened again. I called the dealer and it's being dropped off at noon. Not impressed.
Old September 23rd, 2015, 12:22   #19
TDI73
TDI73's Avatar
Hi Tremulant,
what was the resolution? It happened to my 2015 Golf as well.... "reduce oil level" message after 15,000 KM service
15 Golf TDI 6MT
Past:
06 Jetta TDI 5MT (BRM)
99 Jetta TDI MKIII 5MT(ALH)
97 Golf MKIII 5MT
TDI73 is offline   Reply With Quote
Old September 23rd, 2015, 12:37   #20
no-blue-screen
TDI Nut
TDI(s): TDI
Check your work order. 5.5L or 5.8 quarts . The oil is overfilled.
no-blue-screen is offline   Reply With Quote
Old September 23rd, 2015, 12:46   #21
Smokn337
Originally Posted by TDI73 View Post
Hi Tremulant,
From reading the thread, sounds like too much oil was put in and you need some removed to reduce the oil level.
Smokn337 is offline   Reply With Quote
Old September 23rd, 2015, 15:14   #22
Matt927
Matt927's Avatar
TDI(s): several
How long after the service did the message appear?
Matt927 is offline   Reply With Quote
Old December 3rd, 2015, 06:55   #23
ddorrer
Default Same Here
After my first oil change, I too, have the "Reduce Oil Level" MIL. 6500 miles
2015 GSW Tdi (Working a GTD Clone)
_______________________
ddorrer is offline   Reply With Quote
Old December 3rd, 2015, 07:25   #24
dieseldorf
top post dawg
dieseldorf's Avatar
I've seen this problem on our Audis immediately following an oil change. Oil level is correct, not over-filled. Warning message disappears within a day or so.
Old December 4th, 2015, 06:24   #25
ddorrer
Default Update
Update: Took my VW to the dealer. They actually removed some oil and cleared the CEL. Doesn't sound good for a car with 6500 miles.
Old December 28th, 2015, 18:11   #26
jemccoytx
Fuel Economy: avg 45 mpg per tank
I am having a similar issue with my 2015 Jetta TDI SEL where warning light comes on and "oil change needed" stated in MFI. Oil might have been filled a little high within the past 2000 miles after a oil pan gasket replacement, but no warning until a few days ago at 8400 mi and the orange light oil light came on. I thought the oil might be a little high after reading above posts so I removed some today and light still comes on. I checked on VCDS but no faults codes were found. I now think that it is just counting down to the 10,000 mi scheduled oil change since it gives the miles to 10,000 after the warning upon startup, but the owners manual does not say the oil light comes on for that. Does this sound like a faulty sensor?
jemccoytx is offline   Reply With Quote
Old December 28th, 2015, 18:43   #27
meerschm
meerschm's Avatar
"oil change needed" sounds to me like a service interval was not reset.
Try the oil reminder resets as explained in your owners manual.
Where does the oil level on your dipstick read?
When do you plan to change the oil?
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old December 29th, 2015, 18:54   #28
jemccoytx
I reset the service interval today but warning was still there. Yesterday the oil on dipstick was on the high side so I lowered it a little but no difference.
However, I took it to the dealer today and according to them the dipstick was not fully seated (or in all the way) and that somehow caused the warning. I find that hard to believe with all the level checking that I did but they seemed to have solved it quickly. There must have been some type of blockage keeping me from it snapping in place. Problem solved for now.
Old February 9th, 2016, 22:24   #29
gingerbarry62
TDI(s): 2015 GSW TDI
The "Reduce oil level" warning triangle popped up on my GSW TDi 2015 on 5 separate occasion over the past weekend.
Just hit 15000km and had it serviced 3 days ago...
Was driving on a road trip and as it was the long weekend, so I didn't stop by a dealer, but will be dropping it off at the dealer this week.
A couple things to note:
If I stopped and let it cool for 5/10 minutes and simply restarted, the warning would pop right back on, however if I pulled out the dipstick, wiped it and put it back in with minimal "cooling" period, the warning light was gone.
There was no rhyme or reason to the warning coming on. Was coasting at one point, driving up an extended hill, driving on flat area for miles, no consistency with the warning.
Oil was never hot.
Maybe it was that the oil was actually "overfilled", guess I'll find out soon enough.
gingerbarry62 is offline   Reply With Quote
Old February 10th, 2016, 05:41   #30
dmarsingill
Fuel Economy: 34.5 mpg 135000 miles
A dipstick is just a reference. It should hold 4.3 Liters(4.5 Quarts)
After an oil change (with the correct amount), check your dipstick level. This should be your "normal" level. If you are having the dealer do it, make sure they are only putting in 4.3 Liters.....not 4.8 like their computer might say.
Donald
dmarsingill is offline   Reply With Quote
Coolant Level Warning azhockey VW MKV-A5 Golf/Jettas 8 May 8th, 2016 12:10
Oil Level warning on FIS, turn off? tongsli OBD Scanners 7 February 24th, 2013 08:07
Oil Level Warning Light SmokingSoul TDI 101 16 August 3rd, 2012 08:34
Funny oil level and my blue/white smoke issue! blackcat_78uk VW MKIV-A4 TDIs (VE and PD) 1 May 15th, 2011 17:08
check coolant level warning?? sps VW MKIV-A4 TDIs (VE and PD) 9 November 18th, 2009 14:34
Page generated in 0.18432 seconds with 11 queries
[Output: 123.79 Kb. compressed to 103.19 Kb. by saving 20.59 Kb. (16.64%)]
