Old January 29th, 2014, 19:03   #1
intertan
Default costco batteries
any body use the costco battery?
730cca on the battery
intertan is offline   Reply With Quote
Old January 29th, 2014, 19:27   #2
curtludwig
Fuel Economy: '98 - 47-53mpg, '05 - 44-48mpg
Almost certainly made by Johnson Controls as are like 90% of all the batteries in North America.
I'd guess that battery to be an H6 which will work, maybe, except in the very cold. An H8 gets you 800cca, Autozone's website says for an extra $18. My local Car Quest beat Autozone by $50 for an H7.
I've got an MkIII Jetta and an H8 (the old Group 49) battery will just barely fit, its 900cca. I don't know if that'll fit your MkIV but if it does I'd get it considering you live in the frozen north you can use all the power you can get. In lead acid batteries nothing trumps size and weight for capacity and in the real cold nothing beats capacity for getting your car started. This is not a place to skimp, you don't want to be in the dead of night when you absolutely have to get somewhere and have the car not start.
My blog about everything: http://curtsotherblog.blogspot.com/
curtludwig is offline   Reply With Quote
Old January 30th, 2014, 10:21   #3
T_D_I_POWER
T_D_I_POWER's Avatar
The Ah battery weakness vs the CCA battery strength in cold weather.
So get the battery with highest CCA you can fit under the hood.
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old January 30th, 2014, 11:01   #4
3turboz
3turboz's Avatar
Fuel Economy: 37/42/48
Costco here sells Interstate, probably the best quality out there.
Good advice given on other posts considering your location. My ALH golf is fine with 700 CCA, but it rarely dips below freezing here. A wider battery would easily fit FWIW.
Carl - GOLF TDI, 280Z Turbo
3turboz is offline   Reply With Quote
Old January 30th, 2014, 11:19   #5
Powder Hound
Powder Hound's Avatar
Along with CCA, a VERY important factor is reserve capacity (since Ah ratings seem to be nearly impossible to get). I'd go for 150 rc at a minimum.
Think of it this way: CCA tells you how much oomph is available in the cold. Ah or RC will tell you how long it will be available. If your battery is marginal, then the CCA will fade quickly - during the glow plug warm up - leaving you without sufficient amps to start the engine.
A 94R battery case will fit in the '03 Jetta, and it probably will get you more battery capacity as well. So what if it lops a little outside the official footprint - like the above posters have said, the more battery the better.
If you have a Sam's nearby (yuk - I hate recommending that company for anything, but it is the best battery and deal I found) check out the 49 (H8) batteries under the Duracell name (made by EastPenn, a very good battery company). H8 fits nicely in the Golf/Jetta chassis and you can select enough amps to fulfill your needs.
Costco diesel Yankinwaoz Fuels & Lubricants 98 September 30th, 2017 15:10
Anyone know where Costco gets their gas? EMSbyDay Ontario 9 October 16th, 2011 08:24
Costco and Biodiesel? torifile Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 7 June 21st, 2006 06:11
"Batteries Plus" car batteries? dkuster VW MKIV-A4 TDIs (VE and PD) 7 January 17th, 2006 12:46
Costco Crap? jhedrich VW MKIV-A4 TDIs (VE and PD) 16 September 14th, 2001 12:09
Page generated in 0.13204 seconds with 11 queries
[Output: 71.55 Kb. compressed to 63.31 Kb. by saving 8.24 Kb. (11.51%)]
