Old November 4th, 2019, 05:38   #346
deaster
@Braddman I sent you a PM.
Originally Posted by Braddman View Post
I found a great solution to the issue of not having enough transmission input shaft engagement in the pilot bearing. I bought an HK1522 (21mm OD, 15mm ID, 22mm long) drawn cup needle bearing and a 21mm OD, 15mm ID, 3mm width oil seal to keep the grease in the bearing and the dirt out. I got the seal and bearing from a local bearing supplier for about $7 each. The original pilot bearing is 16mm long with a built in oil seal which reduces the amount of the rolling element length to about 15mm. I took a piece of mild steel drilled it 20mm deep with an 11/16Ē bit bored it to 14mm deep about 20.95mm diameter (basically just a press fit for the bearing.) Turned a 45 deg. chamfer 4mm from the end of the bar stock to support the bearing inside the chamfer in the crank. I turned the diameter of the material to 0.25mm smaller than the flywheel bore which is around 35mm +-5mm (I donít remember the actual size). I parted the bar stock off at 17mm long. This gives me 11mm of bearing engagement in the crank and 11mm in the bearing and seal retainer I made. The total input shaft support is about 14.5mm. I installed the oil seal with the numbers facing the bearing to prevent dust getting in the bearing. I have not had a chance to run my car after installing the new clutch but I sure this bearing setup will work great.
deaster is offline   Reply With Quote
Old November 9th, 2019, 07:26   #347
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
I'm considering selling my 6 speed wagon complete and AWD parts as a package deal:
Body is rusty - but mechanically very good. Runs and drives except for a broken front spring.
BHW w/350K kms (stock BSM)
Malone Tuned ECU for 6 speed
01E 6 Speed (GVS)
Car has stock DMF 240mm installed currently
New in box: LUK DMF & Sachs SRE clutch kit
01E AWD trans (GLX / 3.89 R&P)
Matching rear diff from W8 Auto (3.89 R&P)
Send me a PM if you are serious. Only offering as a complete package.
Optional: 2003 Passat W8 Wagon - runs & drives, needs fenders/hood/windshield
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old November 11th, 2019, 11:46   #348
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Stupid question - is the W8 a manual or auto?
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old November 11th, 2019, 18:30   #349
Uberhare
Uberhare's Avatar
TDI(s): Too many.
It's an auto. Otherwise you would have to pry it from my cold dead hands.
Old November 11th, 2019, 20:06   #350
86turbodsl
Fuel Economy: 43 avg - former, 24.3 mpg now
Aren't those unicorns?
Sent from my LG-TP450 using Tapatalk
2004 Audi A4Q USP
1986 F250 XLT Turbo 6.9
More diesel engines here than you can count on two hands and two feet...
86turbodsl is offline   Reply With Quote
Old November 12th, 2019, 08:30   #351
Syncrogreg
they have w8 manuals. just rare
Syncrogreg is offline   Reply With Quote
Old November 12th, 2019, 15:56   #352
Windex
Windex's Avatar
Even more rare to be a manual W8 in a wagon, or so the legend goes...
Old November 12th, 2019, 18:46   #353
Uberhare
Uberhare's Avatar
TDI(s): Too many.
My plan was to use all the bits listed above to build a nice BHW / AWD car with the 01E manual. However I am not so ambitious these days and plans have changed. I'll just keep driving my other W8 wagon till something expensive breaks....
Old November 15th, 2019, 21:44   #354
vwztips
vwztips's Avatar
It will never break. Because you want it to.. lol
vwztips is offline   Reply With Quote
Planning 6-speed swap, so 5-speed swap is for sale Redneck Truck Private TDI Items for Sale/Wanted 0 February 13th, 2013 14:14
Coding/Login for BHW Manual Swap? alphaseinor OBD Scanners 2 August 10th, 2011 06:01
BHW Blown swap in another PD Engine? mogly VW B5 Passat TDIs 10 June 4th, 2010 13:31
BRM engine swap for BHW? TomB VW B5 Passat TDIs 31 October 28th, 2009 13:30
Does anyone know BHW manual trans swap FollowTheBlackRabbit VW B5 Passat TDIs 59 July 21st, 2009 11:33
Page generated in 0.15755 seconds with 11 queries
[Output: 96.10 Kb. compressed to 82.64 Kb. by saving 13.46 Kb. (14.00%)]
