Old January 20th, 2015, 08:21   #31
Drivbiwire
Zehntes Jahr der Veteran
Keep in mind you have the lowest pressure VE pump in you B4, upgrade to the AHU and you are in the running to break 220+
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old January 20th, 2015, 12:20   #32
raidaru
TDI(s): 1.9
maybe KERMA or other tdi guru could lighten us what's the advantage of using a 11mm head over the stock 10mm head, if they both can achieve powers like 250hp ?
raidaru is offline   Reply With Quote
Old November 7th, 2019, 16:03   #33
limenger
TDI(s): afn|1z
Who owns the information, please share. Need to provide 2260vklr fuel ... 300hp target.
limenger is offline   Reply With Quote
Old November 7th, 2019, 17:54   #34
Yourbuddysatin
Fuel Economy: 32-35mpg
Guys from Finland make over 300hp with 10mm pumps.
Yourbuddysatin is offline   Reply With Quote
Old November 8th, 2019, 16:05   #35
limenger
TDI(s): afn|1z
Is this reliable information?
Old November 8th, 2019, 19:53   #36
Yourbuddysatin
Yucca is the members name that told me they did it. Can’t remember the thread that he said it on. He posted a video of a car doing it on a dyno.
Old November 9th, 2019, 02:22   #37
Markus L
11mm is way better for 300 bhp with such small turbo like 2260vklr. Needs also min 5x0.30mm nozzles.
Markus L is offline   Reply With Quote
Old November 9th, 2019, 05:03   #38
PakProtector
Mind the fuel pressure at the inlet. The VE pumps on the Cummins-es do not take well to much over 10 psi on the inlet as it can push the front seal out...then for the gear driven beast we have No.2 going into the crank case diluting the oil.
Do we have the same sorts of limit/congenital defect on the pump seal? Running a Carter 4601 on my 6BT Dodge, and have had no issue with the seal.
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is offline   Reply With Quote
Old November 9th, 2019, 06:53   #39
Yourbuddysatin
Of course an 11mm is better but I know there was a thread that one of you gents from over seas made 300hp on a 10mm. I watched a video of it.
Old November 9th, 2019, 12:41   #40
limenger
TDI(s): afn|1z
https://youtu.be/j2uD6NCF_HY?t=203 ???
Old November 9th, 2019, 12:55   #41
Yourbuddysatin
There it is! I think there is another car built that made over 300 at the wheels or maybe it was the tractor they built for pulling.
Old November 10th, 2019, 04:32   #42
Yucca
I would use 11mm pump any +250bhp setup.
Not all 10mm pump are same. I would not use 1Z pump any +200bhp setup, AFN pump are good upgrade for those motors.
Yucca is offline   Reply With Quote
WTB Good 10mm Injection pump stevekris Private TDI Items for Sale/Wanted 0 January 27th, 2011 21:03
WTB Low Miles good condition ALH 10mm FI Pump tothemax Private TDI Items for Sale/Wanted 4 October 14th, 2010 11:57
I've got a 11mm pump and want a 10mm alh pump kooyajerms Private TDI Items for Sale/Wanted 6 February 3rd, 2009 12:07
WTB: 10mm or 11mm pump camplate from parts pump RabbitGTDJoe Private TDI Items for Sale/Wanted 0 August 22nd, 2006 17:05
max hp with 10mm pump on 1.6td??? CADDY Quebec 0 September 22nd, 2003 06:46
Page generated in 0.15181 seconds with 11 queries
[Output: 105.66 Kb. compressed to 89.12 Kb. by saving 16.54 Kb. (15.65%)]
