Old February 25th, 2018, 14:41   #46
Steamroller69
Fuel Economy: avg 45.5
I need to save this thread forever. Thanks for the helpful info
Steamroller69 is offline   Reply With Quote
Old January 16th, 2019, 03:22   #47
pdtdiarl
TDI(s): golf4
Is the injector lash, on 2.0 16v also 180? BMN (aka BKD).
pdtdiarl is offline   Reply With Quote
Old July 25th, 2019, 05:56   #48
fakitol
Yes it is, 180.
fakitol is offline   Reply With Quote
Old July 25th, 2019, 06:03   #49
fakitol
Hi,
my BKD engine had cold start problem. All 4 injectors were not seating correctly. The problem was successfully fixed. Car starts fine in the mornings, but now I've got low rev.
torque problems. Is it injector adjustment problem or what?
Injection qty at idle is 5,8mg/str, Torsion 0.0. Cyl. deviations are slightly above/below 0.0.
Old November 10th, 2019, 13:58   #50
540ess
Originally Posted by Tyanu888 View Post
It is very confusing. I had my injectors reconditioned and cleaned by a bosch authorised garage and they told me to lash the injectors I must turn back 270degrees. Here they say 180 degrees. Did they say 270 because they spray heavier atomised diesel? I times the injectors at 180 degrees and result is no power until 2800revs and lots of vibration until the engine boosts. Dmf is new and all vacuum pipes are new. Turbo is perfect also. I guess it is all about the injector/Rocker arm clearance. 180, 225 or 270 degrees?? I have a 2.0ltr tdi 16v BKD 2006 model. Any help would be appreciated. Tyanu888@hotmail.com
Thanks.
Hi there. I am working as a mechanic in a indy shop, an to help a friend I changed the camshaft on his 2005 1,9 tdi AVF B3 Passat. This is a 130 hp engine, but after my work it feels like 75ish.., just like Tyanu888 cars above.
I set the injectors at 180 degrees like described,
When I am driving with VCDS all the values look normal,torsion value at 0, putting the pedal to the flor in 3.gear-turbo pressure over 2000, maf 8-900, injection time 35-40 m/s ,so the thing should be running fine, but not untill 2800 rpm it starts to pull.
Can a injector setting using the old 270 degrees help? Anything else?
540ess is offline   Reply With Quote
Old November 10th, 2019, 16:01   #51
PakProtector
Now this has me a bit confused...
It makes sense that the injectors would be adjusted at maximum stroke( rockers pushing them down ), then backed off half a turn. Brought down to interference, and then backed off at maximum 'lift'.
How wide is the nose of that cam lobe? I can see the need for an indicator, as if you are not at the real max lift point then setting like it is will result in an interference.
I don't see how adjusting to interference on the base circle will result in anything but disaster when( IFF ) the engine gets rotated.
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is offline   Reply With Quote
Old November 10th, 2019, 17:22   #52
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Injector rocker lash adjustment doesn’t make much difference. As long as there’s enough clearance, it doesn’t really matter if there’s a bit too much (within reason). I’ve messed with that setting a little bit and it barely makes any difference that you would notice.
If the car is severely lacking power it’s probably not the injector adjustment unless it’s too tight and damaged the injectors.
It’s probably something else.
A torsion value of zero can mean that it’s too far out of range. I would try adjusting it until you can get a reading other than zero, like 0.5 for example, and then go from there trying to adjust it to zero.
When you were setting the torsion value if you found that you got to zero very easily then it’s probably wrong. It usually takes many adjustments to get it to zero once you can get it reading something within range.
Make a very tiny adjustment. If it still says zero after that then you’re way off.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old November 17th, 2019, 13:10   #53
540ess
Thanks for help guys, I will check the car again this week, do the settings all over again
Injector Fault and Setting Timing Suzuki TDI 101 6 March 13th, 2009 07:18
Need help setting injector timing - Seattle Jimwsea VW MKIV-A4 TDIs (VE and PD) 2 August 12th, 2005 18:45
TB Change Need help setting the injector pump Da_Body VW MKIV-A4 TDIs (VE and PD) 3 November 4th, 2003 20:46
injector pump setting GoFaster VW MKIV-A4 TDIs (VE and PD) 1 November 30th, 2002 01:37
Pumpe Duese or PD 101 (Simplified Version) Turbo Steve VW MKIV-A4 TDIs (VE and PD) 13 November 29th, 2000 20:46
Page generated in 0.13767 seconds with 11 queries
[Output: 87.16 Kb. compressed to 75.43 Kb. by saving 11.74 Kb. (13.46%)]
