Old September 23rd, 2019, 14:05   #226
Owain@malonetuning
I'd start by removing the resistor mod (tuning box) so that your ECU can actually see the correct sensor values. These devices aren't comparable to an ECU tune.
flashing glow plug is normally boost related, or it could be rail pressure since you're likely modifying the wiring to that sensor. Would hook up VCDS and go over rail request vs actual and boost request vs actual after that.
Owain@malonetuning is offline   Reply With Quote
Page generated in 0.12923 seconds with 10 queries
[Output: 45.39 Kb. compressed to 42.75 Kb. by saving 2.63 Kb. (5.80%)]
