Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2007
TDIFest 2007 Discussion about TDIFest 2007 that happened in Montréal, Canada.
Closed Thread
Old June 27th, 2007, 11:20   #1
Crazy Memphis
Crazy Memphis's Avatar
Fuel Economy: 1080km/tank
Arrow where and when is the fest going on
hi guys i just saw that the 2007 fest was going on in mtl so i was woudering when is it and where it is. and can we come and see or its only a registred area only ????
might be stupid question but it my first time on a car fest.
thanks alot in advance.
vive montreal criss, les femme les char pis une tite frette
Crazy Memphis
VW TDI 1986 Army Green
VW TDI 2000 White
Modifications: 2.5" Mufflerectomy,Ventectomy,KYB Gaz Susp. with Eibach Pro-kit,Kerma's costum tune,Eurojet FMIC,R520 stg2,Oil Press.-Boost- Pyrometer Cobalt Gauges,GT1852v stg2,boost valve,99.5 clutch,11mm pump, in-tank lift pump, 3bar map,Evo skid plate,
Coming on: clutch then peloquin slip differential
161.7hp and 235.6tq
Crazy Memphis is offline
Old June 27th, 2007, 11:32   #2
Hamsterdiesel
Veteran Member & HO5G CoFounder
Hamsterdiesel's Avatar
Fuel Economy: 49/47.5 - 51 mpg once!
http://forums.tdiclub.com/showthread.php?t=178666
http://forums.tdiclub.com/showthread.php?t=164042
See these links for more info!
BUG*PWR 2008
2015 Passat SE 6spd Reflex Silver
1999 Golf - ...gone, but not forgotten!
1965 Plymouth Barracuda - with the Leaning Tower of Power!
Hamsterdiesel is offline
Closed Thread
Page generated in 0.13712 seconds with 10 queries
[Output: 50.47 Kb. compressed to 46.41 Kb. by saving 4.06 Kb. (8.04%)]
