Old November 17th, 2019, 08:21   #1
@Tdi VW
Default Judder when pulling away
Hello
Lately i feel a lot of juddering/vibration when pulling away in first gear. It gets worse when the car gets in temperature, and it feels worse when pulling away fast(relatively high rpm) and when pulling away uphill.
The judder feels trough the whole cabin when i start releasing the cluch till i completely take my foot of the clutch. When shifting other gears feels just fine.
Any idea ?
@Tdi VW is offline   Reply With Quote
Old November 17th, 2019, 12:29   #2
Dhawk12
Following cause mine is doing the same thing, although it's not really consistent for me and seems to do it more when cold in my case. I thought my clutch might be going, which is possible, but it doesn't slip at all under load.
OP when you are up to temp, do some hard pulls in 4th and 5th gear and see if your clutch slips. If your revs rise way faster than road speed, then your clutch may be done, although like I said mine is doing the same thing with no noticeable slipping under load.
OP, did you recently do anything involving your brakes?
Sent from my Pixel 3 XL using Tapatalk
Dhawk12 is online now   Reply With Quote
Old November 17th, 2019, 14:15   #3
@Tdi VW
Hello
Car is remaped and the clutch doesnt slip. I feel it more when its hot outside and when the car is hot enough. Its just like me, doesnt like high temps
Not much time ago i replaced front brake discs, pads and brake fluid.
Old November 17th, 2019, 14:51   #4
Dhawk12
Interesting regarding the brake work. I ask because I saw another post on here today regarding weird clutch engagement and it got me thinking.
I also just had to change fluid and re-bleed the system because I disconnected the rears to swap axle beam bushing and my shudder has occurred since I did that swap, so I wonder if it could be caused by air in the system somewhere.
Hopefully others will chime in.
Old November 17th, 2019, 16:30   #5
PakProtector
My first suspect are the inner CV joints.
cheers,
Douglas
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, 366 spring, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
2004 Jetta, 5spd...stock and turning 47-48mpg
PakProtector is offline   Reply With Quote
Old November 17th, 2019, 18:25   #6
STDOUBT
STDOUBT's Avatar
Sounds like wheel-hop to me - if so, a new dogbone mount could solve it.
2003 Jetta TDI 1.9L 5-speed
Search Tip: search this site best by using Bing: tdiclub topic
STDOUBT is offline   Reply With Quote
Old November 17th, 2019, 18:25   #7
Dhawk12
cheers,
Douglas
Would the inner CV's cause the shuddering/engine stumble only when starting from a stop and display no other symptoms? That is what mine is doing, and sounds like the OP is having a very similar/the same problem.
Last time I had a worn inner CV, it was vibrating/making noise under load in all gears. This feels much more like a clutch engagement/disengagement issue as it is only when starting from a stop (at least for me).
Old November 17th, 2019, 18:28   #8
Dhawk12
I can't speak for the OP, but I don't think mine is wheel hop. My tires aren't losing traction, its rather almost like the engine is about to stall. Or maybe I don't understand wheel hop.
Old November 17th, 2019, 18:32   #9
Nero Morg
Nero Morg's Avatar
It would help if we knew what car OP is working with, his listed cars says Passat, so just wanted to clarify!
Whatever. Just use your darned blinker. And stay off your phone.
Nero Morg is online now   Reply With Quote
Old November 17th, 2019, 19:40   #10
jettawreck
jettawreck's Avatar
Fuel Economy: 52+ average lifetime '01
Rear main seal getting oil on clutch friction disk perhaps for the jutter when cold. It goes away after a bit of operation.
2001 Jetta TDI GLS Silver-current driver (salvage)permanently vented-Panzer Plate-Sprint 520s-ScanGauge-CheckTemp III-ZeroStart heater-CAT 2 filter
2003 Jetta GLS Black w/leather (New Project Car) fixer-upper w/broken TB
2004 Cadillac SLS (wife's)
1999 GMC Suburban (It's MN-you need one)
197? Shibura 2cyl diesel 4WD tractor-loader/brushhog (very handy unit)
196? International TD340 Dozer-w/Drott 4-in-1 bucket/back ripper attachment
jettawreck is offline   Reply With Quote
Old November 17th, 2019, 19:49   #11
Dhawk12
That would certainly be annoying as I just changed the rear main seal like 30,000km ago.
Old November 18th, 2019, 07:57   #12
Genesis
Fuel Economy: 53/48/42
Maybe.
But I had the same situation come up with my Jetta and from the bottom the dogbone looked a bit suspicious. I changed it and... problem gone. Hmmm....
After I pulled the old one out the difference in the condition of the rubber between old and new, and the amount of motion the old one was permitting, was REALLY obvious.
Genesis is online now   Reply With Quote
Old November 19th, 2019, 10:17   #13
Powder Hound
Powder Hound's Avatar
Fuel Economy: pretty freakin' good.
Would the inner CV's cause the shuddering/engine stumble only when starting from a stop and display no other symptoms? ...
No, the classic inner CV joint failure presents as steering wheel shimmy when your foot is pressing on the go-pedal. As soon as you lift, the shimmy stops. And the shimmy is gear independent.
Cheers,
PH
Thinking outside the box is difficult for some. They're afraid they'll fall off the edge of the box and be lost to oblivion.
Powder Hound is online now   Reply With Quote
Old November 19th, 2019, 13:47   #14
@Tdi VW
Hello
Thanks for the replies
Car is a FWD European 130 Hp PD Passat B5.5
Old November 19th, 2019, 14:06   #15
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Possibles- Failing DMF, broke motor mount.
BobnOH is online now   Reply With Quote
Judder at idle kecneb VW MKIV-A4 TDIs (VE and PD) 0 December 6th, 2018 02:12
Another Brake Judder JoshWagen VW MKIV-A4 TDIs (VE and PD) 22 March 29th, 2017 22:23
judder chubbs VW MKIV-A4 TDIs (VE and PD) 1 July 31st, 2014 18:57
Small judder when pulling off Phil1964 VW MKV-A5 Golf/Jettas 6 August 30th, 2013 08:01
clutch judder b21playa VW MKV-A5 Golf/Jettas 7 July 5th, 2010 19:45
Page generated in 0.17255 seconds with 13 queries
[Output: 127.73 Kb. compressed to 106.41 Kb. by saving 21.32 Kb. (16.69%)]
